Making in walls out of SDA 1C's
    audioluvr Posts: 6,013
    edited October 2020
    Refreshed, those 4400's would probably sound sweet
    F1nut Posts: 52,164
    kabory wrote: »
    Hansvelton wrote: »
    kabory wrote: »
    Hansvelton wrote: »
    The designer/fabricator in me, is curious what actual interior volume those corner boxes would measure?
    They seem a good bit larger than the original box for sure.
    That would account for much of the loss of bass, exempting sealing issues.. If the box is far larger than the original design (which this visually seems to be) that would drastically lower the box tuning to the point where the passive would not contribute much to the bass, as originally designed.
    during the intial trial with no sub, I noticed the bass loss. So I packed the upper and lower sections of corners with batting. I left the area behind the 4 drivers down to the passive open. That brought back some bass and it is more than enough when used in conjuction with my sub.
    Something you may (or may not) want to try, is to see how well sealed the "Box" is, by pushing carefully on the middle of the passive, then release it and watching how slowly or quickly it moves back to the normal position.
    That will give you a fair idea (outside of running an impedance sweep) of how much air loss is occurring or not.
    That is NOT the way you test, that will tell you nothing.
    Passive test is
    1. push quickly in until bottoms out and hold there and watch mid-woofers hold until MW are back at resting position
    2. count time it takes MW to recede to resting position
    3. the longer the better report back
    MW recede quick
    I did run a 5 to 200 Hz test off of YouTube through my sound system with the sub disconnected and the SDA1C’s were audible starting at 40 Hz
    You have massive air leaks, which doesn't surprise me a bit.
  • DaveHo
    DaveHo Posts: 3,583
    Well, that's unique. Nice craftsmanship on the woodwork. But you really trashed a great pair of speakers.
  • kabory
    kabory Posts: 17
    Sorry man you will get no sympathy for that...
    I really want to know how you worked the XO
    Here is how I worked the crossover
  • ken brydson
    ken brydson Posts: 9,060
    I would have built the wife into the wall but that's just me.... B)
    gudnoyez Posts: 8,183
  • DaveHo
    DaveHo Posts: 3,583
    edited October 2020
    Not enough volume, for some...
  • BlueBirdMusic
    One of your best, Ken.
    Harry / Marietta GA
