Making in walls out of SDA 1C's
Have my original SDA's from 1987 and have enjoyed them for many years. Time for a change so l'm trying something different by converting them to in walls. I cut the enclosures off from the faceplate that houses the drivers. Installed tongue and groove panels on an angle in each front corner. Eliminated the interconnect cable and re wired the crossovers to a standard 3 way speaker. I will upload pics. They are on another device. Lost some bass due to the size of the corner panels. But I'm using a subwoofer so no big deal. Actually very surprised and happy with the sound they still produce.
    pitdogg2 Posts: 26,934
  • Gardenstater
    Gardenstater Posts: 4,742
    I have to know.....were you really tired of having good imaging and soundstage OR was it wife problems?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • kabory
    kabory Posts: 17
    The speakers are 34 years old and were about to be a yard sale. I plan on replacing them with klipsch in Wells. So this is just a project that save me around 500 bucks. They still rock and sound amazing
    Sorry man you will get no sympathy for that...
    I really want to know how you worked the XO
  • kabory
    kabory Posts: 17
    I wire the dimensional drivers the same as the stereo drivers. So they are in series instead of parrarell
  • rooftop59
    rooftop59 Posts: 8,121
    Well all I can say is say is that the setup looks really cool! I love the natural wood paneling and the light sea foam green paint. The floating cabinet is really modern looking but the paneling and curtains give it a very light, bright, airy and welcoming feel. And compared to like 98% of American setups, I’m sure it sounds awesome. Nice job!
    And nice Congas! You play any other instruments?
    Game Room 5.1.4:
    Bedroom 2.1
  • kabory
    kabory Posts: 17
    Yes I also play drums.
  • invalid
    invalid Posts: 1,443
    I think you should have used a different speaker for that in wall set up, but it does look cool.
  • Gardenstater
    If I understood correctly he is planning to replace them with Klipsch In Wall Speakers, like these I suppose:
    https://www.klipsch.com/in-wall-speakers
    I suppose you can sell the Polk drivers as individual units. The crossover won't have any value after your mods. The SDA 1C's would've been worth more uncorrupted.
    Are the corner unit boxes sealed or open at the top and bottom?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited October 2020
    I should've also said that I agree the room does look very nice. Good use of the knotty pine.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,679
    Ugh
  • kabory
    kabory Posts: 17
    They are sealed and have batting in them
  • kabory
    kabory Posts: 17
    Yes. I’m still considering the klipsch 5502’s. They are currently out of stock. One of the reasons I decided to go this route for now.
    I was never concerned about making any money by selling the sda’s. I’ve gotten plenty of use out of them. The crossovers are fully intact I just re-directed the internal wiring
  • Honestly some VERY nice quality work, I would like to hear this set up!
    And I get why some purists balk at dismantling an older vintage speaker, but if the OP is happy, why not?
    At least it is not some total hack job, some class and work to what he did!~
  • gyosa
    gyosa Posts: 769
    edited October 2020
    That’s definitely thinking “outside the box”....
    When you’re ready to ditch them , let us know , instead of pitching them to the curb ....
    Someone here may want those mid-woofer drivers as spares - like me !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • The designer/fabricator in me, is curious what actual interior volume those corner boxes would measure?
    They seem a good bit larger than the original box for sure.
    That would account for much of the loss of bass, exempting sealing issues.. If the box is far larger than the original design (which this visually seems to be) that would drastically lower the box tuning to the point where the passive would not contribute much to the bass, as originally designed.
    I'd have to agree to that assessment. They used a 15" passive in the bigger SDA SRS 2 which used the same drivers.
  • kabory
    kabory Posts: 17
    Hansvelton wrote: »
    during the intial trial with no sub, I noticed the bass loss. So I packed the upper and lower sections of corners with batting. I left the area behind the 4 drivers down to the passive open. That brought back some bass and it is more than enough when used in conjuction with my sub.
  • kabory
    kabory Posts: 17
    gyosa wrote: »
    Bk
    I see you have B&K amp. I have a ton of equipment including B&K 654 amp, pro 5 preamp and tuner. Denon 4400 mono blocks and alot more just collecting dust in storage. To simplify, I switched over to Pioneer Elite recievers and couldnt be happier.
  • kabory wrote: »
    Hansvelton wrote: »
    Something you may (or may not) want to try, is to see how well sealed the "Box" is, by pushing carefully on the middle of the passive, then release it and watching how slowly or quickly it moves back to the normal position.
    That will give you a fair idea (outside of running an impedance sweep) of how much air loss is occurring or not.
  • kabory
    kabory Posts: 17
    Hansvelton wrote: »
    kabory wrote: »
    Hansvelton wrote: »
    It moves back fairly quick
    edited October 2020
    Hansvelton wrote: »
    kabory wrote: »
    Hansvelton wrote: »
    That is NOT the way you test, that will tell you nothing.
    Passive test is
    1. push quickly in until bottoms out and hold there and watch mid-woofers hold until MW are back at resting position
    2. count time it takes MW to recede to resting position
    3. the longer the better report back
  • lightman1
    lightman1 Posts: 10,796
    kabory wrote: »
    gyosa wrote: »
    Bk
    4400 mono blocks you say?
  • kabory
    kabory Posts: 17
    lightman1 wrote: »
    kabory wrote: »
    gyosa wrote: »
    Bk
  • kabory
    kabory Posts: 17
    Hansvelton wrote: »
    kabory wrote: »
    Hansvelton wrote: »
    Passive test is
    MW recede quick
    I did run a 5 to 200 Hz test off of YouTube through my sound system with the sub disconnected and the SDA1C’s were audible starting at 40 Hz
    audioluvr Posts: 5,877
    lightman1 wrote: »
    kabory wrote: »
    gyosa wrote: »
    Bk
    Right next to the VCR
  • lightman1
    I've got a soft spot for old Denon iron
  • pitdogg2 wrote: »
    Hansvelton wrote: »
    kabory wrote: »
    Hansvelton wrote: »
    Passive test is
    Wow, thanks, great catch.
    Was trying to do that from a mobile device while out, complete mess up of explanation.
