CS350-LS Center channel speaker to pair with SDAs
  • H2OH2O Posts: 2
    Hello again folks.
    Finally got a chance to pick up the CS350 center channel project again. I was able to locate a CS350 on CL, and here are some photos of the crossover.
    Looks like I have the old sandcast resistor?
    Is there enough info in these photos to determine if there would be much benefit to the crossover upgrade?
    Thanks again!!!
  • I have both with and without the resistor, the one without sounds a little better. So you might try and jump the resistor and see if you like it that way.
    Yamaha RXA1030, Yamaha CD, Bluesound node 2i, Tidal
    Polk SDA2btl highly modded
    Polk SDA 1C
    Polk CS350 LS x2
    Polk m5jr
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • dpowelldpowell Posts: 2,851
    drumminman wrote: »
    FYI for what it's worth, I bought the LSiM 704 last christmas, using it with CRS+ L-R fronts. It's a great match.
    +1 if you find that the CS isnt what you are looking for try the LSiM 704 or 706.
    polkaudio Fully Modded SDA SRS 2.3TL's + Dreadnaught, LSiM706c, 4 X TC265i Rears, SVS PB13 Ultra x 2
    Pass Labs X1, Pioneer Elite SC-67, Sunfire Signature Cinema Grande 400, Oppo BDP-83SE, Sony SCD-C333ES
  • Remove the resistor and install a jumper. Install a 5.8uf Sonicap in place or the purple electrolytic. Easy upgrade
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
  • Rookie guy here. I have this speaker and the far left speaker is missing the cnter..can I replace it with another or what would anyone recommend..still sounds good except a low volume slight rattle. Thanks!
  • NightfallNightfall Posts: 9,482
    dpowell wrote: »
    drumminman wrote: »
    How do they compare?
    Does the tweeter in the LSiM centers sound like the tweeter in the Legend line?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59rooftop59 Posts: 6,900
    Nightfall wrote: »
    dpowell wrote: »
    drumminman wrote: »
    The tweeter's are similar, yes. I would guess that CS400 or the CS350i would be better matches for your mains, I know that @EndersShadow among several others use oneof those with SDAs...
    Living Room 2.1: Dynaudio Contour 1.3mkii; Martin Logan Grotto sub; Musical Fidelity A308; Marantz SA 14S1; Sony UBP-x1000es
    Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology StudioMonitor350; Mirage Nanasats; Sub - HSU VTF-2 MK5
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology promonitor 800; ACI Titan Subwoofer
  • EndersShadowEndersShadow Posts: 17,218
    @rooftop59
    Close....
    I have the 400i for my SDA 2As.
Howdy, Stranger!
