CS350-LS Center channel speaker to pair with SDAs
Hello again folks.
Finally got a chance to pick up the CS350 center channel project again. I was able to locate a CS350 on CL, and here are some photos of the crossover.
Looks like I have the old sandcast resistor?
Is there enough info in these photos to determine if there would be much benefit to the crossover upgrade?
Thanks again!!!
I have both with and without the resistor, the one without sounds a little better. So you might try and jump the resistor and see if you like it that way.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
drumminman wrote: »FYI for what it's worth, I bought the LSiM 704 last christmas, using it with CRS+ L-R fronts. It's a great match.
+1 if you find that the CS isnt what you are looking for try the LSiM 704 or 706.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
Remove the resistor and install a jumper. Install a 5.8uf Sonicap in place or the purple electrolytic. Easy upgradeHome Theater/2 Channel:
dhsspeakerservice.com/ -
Rookie guy here. I have this speaker and the far left speaker is missing the cnter..can I replace it with another or what would anyone recommend..still sounds good except a low volume slight rattle. Thanks!
How do they compare?
Does the tweeter in the LSiM centers sound like the tweeter in the Legend line?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
The tweeter's are similar, yes. I would guess that CS400 or the CS350i would be better matches for your mains, I know that @EndersShadow among several others use oneof those with SDAs...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
