CS350-LS Center channel speaker to pair with SDAs
  • H2O
    H2O Posts: 2
    Hello again folks.
    Finally got a chance to pick up the CS350 center channel project again. I was able to locate a CS350 on CL, and here are some photos of the crossover.
    Looks like I have the old sandcast resistor?
    Is there enough info in these photos to determine if there would be much benefit to the crossover upgrade?
    Thanks again!!!
  • I have both with and without the resistor, the one without sounds a little better. So you might try and jump the resistor and see if you like it that way.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • dpowell
    dpowell Posts: 3,081
    drumminman wrote: »
    FYI for what it's worth, I bought the LSiM 704 last christmas, using it with CRS+ L-R fronts. It's a great match.
    +1 if you find that the CS isnt what you are looking for try the LSiM 704 or 706.
  • Remove the resistor and install a jumper. Install a 5.8uf Sonicap in place or the purple electrolytic. Easy upgrade
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Rookie guy here. I have this speaker and the far left speaker is missing the cnter..can I replace it with another or what would anyone recommend..still sounds good except a low volume slight rattle. Thanks!
  • Nightfall
    Nightfall Posts: 10,084
    dpowell wrote: »
    drumminman wrote: »
    How do they compare?
    Does the tweeter in the LSiM centers sound like the tweeter in the Legend line?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,121
    Nightfall wrote: »
    dpowell wrote: »
    drumminman wrote: »
    The tweeter's are similar, yes. I would guess that CS400 or the CS350i would be better matches for your mains, I know that @EndersShadow among several others use oneof those with SDAs...
    Game Room 5.1.4:
    Bedroom 2.1
    EndersShadow Posts: 17,707
    @rooftop59
    Close....
    I have the 400i for my SDA 2As.
