CS350-LS Center channel speaker to pair with SDAs
Hello again folks.
Finally got a chance to pick up the CS350 center channel project again. I was able to locate a CS350 on CL, and here are some photos of the crossover.
Looks like I have the old sandcast resistor?
Is there enough info in these photos to determine if there would be much benefit to the crossover upgrade?
Thanks again!!!
I have both with and without the resistor, the one without sounds a little better. So you might try and jump the resistor and see if you like it that way.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
drumminman wrote: »FYI for what it's worth, I bought the LSiM 704 last christmas, using it with CRS+ L-R fronts. It's a great match.
+1 if you find that the CS isnt what you are looking for try the LSiM 704 or 706.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Remove the resistor and install a jumper. Install a 5.8uf Sonicap in place or the purple electrolytic. Easy upgradeHome Theater/2 Channel:
dhsspeakerservice.com/ -
Rookie guy here. I have this speaker and the far left speaker is missing the cnter..can I replace it with another or what would anyone recommend..still sounds good except a low volume slight rattle. Thanks!
How do they compare?
Does the tweeter in the LSiM centers sound like the tweeter in the Legend line?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
The tweeter's are similar, yes. I would guess that CS400 or the CS350i would be better matches for your mains, I know that @EndersShadow among several others use oneof those with SDAs...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
