199100102104105200
  • I went from this:
  • Wardsweb
    Wardsweb Posts: 942
    edited September 2020
    To This, after giving the quads and turntable to my son. Speakers are '63 Pioneer that I refinished.
  • BlueFox
    BlueFox Posts: 15,250
    Quite a difference. What difference is there in the sound?
  • BlueFox wrote: »
    It is huge. The Quads are a spectacular speaker. The speed and dynamic range are awesome. They also have incredible bass, that I never got from my Martin Logan CLS or Prodigy electrostats. With that said, the vintage Pioneers have great imaging and midrange, but lack the really low end bass. Still they will be great for jazz and classical in my office at work.
  • indyhawg wrote: »
    I joined the streaming club today. A Lumin U1 Mini showed up at my doorstep. Easy set up. Now I am wondering what took me so long.
    It is addicting. Very easy to use the app as well. Enjoy!
  • GlennDog
    GlennDog Posts: 3,152
    indyhawg wrote: »
    Great product. I Love my Mini 😳
    In case you weren’t aware, AS has an interesting and informative Lumin thread
    https://audiophilestyle.com/forums/topic/14016-lumin-audiophile-network-music-player/page/119/?tab=comments#comment-1088146
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    indyhawg wrote: »
    Congrats! That is awesome!
  • Milito
    Milito Posts: 2,003
    Nice!
  • Mike Reeter
    Mike Reeter Posts: 4,315
    stangman67 wrote: »
    Just jamming out and drinking many beers! Also decided I need to pick up the modwright PH 9.0 phono, this rega fono mc is too noisy!
    I've had the PH 9.0 for quite some time, I think you'll be happy.
  • joecoulson
    joecoulson Posts: 4,943
    Gerres26 wrote: »
    Just added this monster to the 2 channel rig...a Rythmik E15HP. This is my first step into the subwoofer world so we shall see how it goes.
    My bet is you’ll love it.
  • invalid
    invalid Posts: 1,490
    I turned my gear off and unplugged it for the first time in a month. I usually leave it on 24/7 even the tube preamp with separate power supply, I'm going away for a few days. Hopefully it doesn't take too long for my solid state amp to sound great again.
  • Gerres26
    Gerres26 Posts: 874
    joecoulson wrote: »
    Gerres26 wrote: »
    I’m reading up on proper implementation to try to learn as much as I can since this is new territory for me...and tips are welcome.
  • indyhawg
    indyhawg Posts: 1,672
    Gerres26 wrote: »
    Nice. I added an F12 a few months ago. It was a great upgrade. Enjoy.
  • gp4jesus
    gp4jesus Posts: 2,019
    Gerres26 wrote: »
    please chime in Brother Polkies if missed something - sorry for the long post
    You will need:
    a.time, - at least an uninterrupted afternoon.
    b. patience,
    c. music* or movie* soundtrack w/heavy bass
    d. ears.
    Look for a Polk thread of “bass bustin*’” program material as not a lot of effective “sub 30hz/40hz” material available. A free iPhone app called “Sonic” produces single tones down to 20hz can be helpful to tweak (EQ) your sub - best used for another session; see below. While helpful, you won’t need any equipment.
    a. Turn off or disconnect all other channels from the amp/AVR end,
    b. Place sub in your preferred seating.
    c. Play “c” (above) at preferred XO - 100hz?
    d. Crawl around the room w/your head less than 12” from the floor, listening for the smoothest response - you may find several😊
    Note: moving your head 1-3 inches in any direction can produce radically different results
    e. Where it sounds the smoothest, is the best place - may have low a SAF😢
    f. go to “c” drop the frequency to the next lower setting* 80hz? 60hz? ...repeat d & e...
    ...until you are satisfied you found “e” w/an acceptable SAF (compromise)
    * 40 and below may be a challenge though your sub’s specs suggests above average robustness in the lower registers.
    After you have settled on the location for your sub, you can tweak. If your AVR/prepro has EQ for the sub, think as a wood or stone carver - If you were carving a face, how do you “fill in a nose?” REMOVE the peaks or the louder portions of of your sub’s frequency range - NEVER fill in a dip.
    You will likely hafta turn up your sub a click or two, as the final adjustment
    Hope this helps - so sorry, so long... Tony
    *all connected w/Premiere ICs
  • Gerres26
    Gerres26 Posts: 874
    No need for a sorry, thank you for that post!
    So far, lucky for me the response is very smooth when the sub is placed on the front wall close to the corner of the room(so max WAF there lol...not that she cares much).
    I’m surprised how low I have the volume knob on the sub to have it fill in the bottom registers nicely without being overbearing.
    I’m not using an AVR, this is straight from my amp via High Level inputs so I guess next step is to tweak the phase/delay and make sure I’m not canceling waves from the main speakers...is this correct?
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Last night and this morning, I fabricated a new power cord for my PS Audio PerfectWave Transport from"leftovers from previous power cord DIY projects.
    Just a bit of diversion during my Covid-19 "hibernation."
    This upgrade from the stock cable appeared to improve SQ. The clarity and presence of the various instruments improved, as did the quality of the bass.
    However, I had not had a lot of experience with this transport in this system.
    I know that when I replaced the stock power cord on my Cambridge Audio CD player in the system I have in my NJ condo with a similarly constructed power cord, the improved SQ surprised both my wife and me. [I use the CA Azur 840C only as a transport, because I have a PS Audio DirectStream DAC in this system.]
  • verb
    verb Posts: 10,176
    So one of my PASS ACA monoblocks shite the bed the other day. Left channel getting a loud hum. In the meantime, I swapped in a pair of Antique Sound Labs tube mono's.
    Great to have back-ups! :)
    Had to do a little re-arranging too. Moved the EAR CD player to the top of the riser.
  • jdjohn
    jdjohn Posts: 3,366
    Working on an Akai GX-77 R2R from my dad's collection.
    It isn't working correctly, so had to dig in. Rear guts:
    Ultimately got the main cam out, and then cleaned and re-lubed it. If you've ever worked on a R2R, maybe you can appreciate the effort to get this bad boy out.
    Now I've got the front exposed for closer inspection.
    mhardy6647 Posts: 35,093
    edited November 2020
    ^^^ Re: the AKAI deconstruction: I wouldn't even try :o Most impressive, young Tapedeckwalker.
    Re: @verb and his ACA monoblock's untimely boudoir defecation ;) -- on the bright side, there ain't too much to go wrong with one
  • jdjohn
    jdjohn Posts: 3,366
    Ha, perhaps young enough to foolishly make an attempt, and old/stubborn enough to not give up...but, I am done with it now.
    The GX-77 was one of Akai's last desperate home-run swings. It has auto-reverse (six heads in total :o ), and a compact design thanks to the 'loading roller', which is controlled by a large plastic cam - much akin to auto turntables. Old waxy lube is a typical culprit in servicing these. Did I mention the similarity to old auto tt's? One of the major deficiencies in this deck is/are the weak DC reel motors.
    I successfully serviced the main cam, all major levers, and DeOxit'd all pots and switches. I replaced the capstan flywheel belt, and both reel motor drive belts. Also cleaned and polished front faceplate surfaces and knobs.
    In the end, I have this one 'mostly' working. 'Parts only' units sell for $300-400 on eBay, with fully-functional tested units selling for over $1,000, so I figured it was worth the effort. My dad probably paid $20 or less for this unit as-is. I seem to be doing all the work he had planned on doing ;)
  • jdjohn
    jdjohn Posts: 3,366
    Another clean-out trip at my parents' house last weekend, so another installment to share.
    Yamaha C-60 preamp and Kenwood KM-992 power amp:
    I'd been eye-balling that Kenwood power amp for awhile on a storage rack, and was finally able to dig it out. It's a great piece IMO, and the light meters even work! I initially thought the Yamaha preamp had a channel out, but after a couple of days, I finally discovered the balance wheel that protrudes from the underside of the faceplate, and hey [cough], both channels actually work! :# Great little combo here!
    The Yammie still needs a good cleaning, which is evident from the pic. The Kenwood cleaned-up pretty well B)
    Pioneer RT-707 tape deck:
    Nice direct-drive R2R here with auto-reverse. The left channel is out, as you can tell by looking at the meter readout in the pic. Hopefully I can get that remedied since this is otherwise a very nice, compact R2R. This unit was sitting over on a workbench, away from most other gear, stuffed into a couple of plastic bags. Oh, Pop :(
  • joecoulson
    Good stuff Jody.
  • jdjohn
    jdjohn Posts: 3,366
    Thanks guys. BTW, it looks like I will be coming into a treasure trove of big band, swing, and oldies mix tapes in reel format. PM me if interested ;)
  • Willow
    Willow Posts: 11,237
    We actually used ours last night. Ever since it moved to the new basement it has not seen much action as we are waiting for the new furniture to arrive. We all sat down and watched the original Grinch.
    jdjohn wrote: »
    Two comments:
    1) I like those Yamaha preamps (FWIW) -- aesthetically & sonically.
    2) That RT-707... and this is gonna sound random... but, did you try the headphone output? I have a CT-F1000 that happily outputs stereo from the headphone jack but not the line-level outputs. If memory serves, there is a transistor that fails (perhaps in the output buffer?). Of course, the RT-707 ain't a CT-F1000, and vice versa. but they're both roughly contemporaneous products of the same engineering teams -- and corporate bean-counters. ;)
    Otherwise, you know the usual suspects for that sort of issue. B)
    edited December 2020
    One can test tubes (in this case 6922s 6DJ8s).
    or
    One can test tubes.
    In fairness, if one has a good, calibrated transconductance tester, one can do a pretty good job of determining the true operating condition of a given tube, and of course match tubes (or sections of tubes, like the pair of twin triode tubes in the Paramour phono preamp above). I, sadly, haven't managed to convince myself to spend the $$$ for a good transconductance tester in good, calibrated working order. :(
    I am fortunate enough to have my father's workhorse Sencore Mighty Mite III, and it still serves well for basic testing (emission, grid leakage, and shorts).
