Who uses tone controls
Don’t scoff .. I want to know if anyone uses them. In my existing Parasound stack I have them but never use them.
I am close to finally making a decision ( yes I move slow) on a MF M6Si which doesn’t have them. Wondering if I will miss not having on this unit, why start now.
With that said who uses tone controls?
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
«13
    nooshinjohn Posts: 25,966
    I haven’t used tone controls in a home setup in twenty years. You won’t miss them. The only reason they exist is to compensate for bad gear, bad speakers or bad ears. I think that they ma actually degrade the sound of a piece of gear whether they are used or not, as they interfere with the signal path.
    F1nut Posts: 51,912
    Not me.
  • TEAforONE
    TEAforONE Posts: 1,069
    Nope. Not me.
    msg Posts: 10,452
    I don't on main systems, but toy with Schiit's EQ with headphone stuff. Mostly flat everywhere, otherwise.
    The only time I've used tone controls in systems since I've gotten into "more serious" audio was early on to try to correct for edgy or bright sound which was mostly due to bad speakers, like John mentions above.
    audioluvr Posts: 5,977
    Mine doesn't even have them
  • No tone controls. When I previously owned a TOTL Kenwood Integrated with tone controls I always used the "defeat" option.
  • invalid
    invalid Posts: 1,510
    I use tone controls, it's called tube rolling.
    pitdogg2 Posts: 27,189
  • joecoulson
    joecoulson Posts: 4,943
    I have a Parasound stack with the same, when I tried it for ghits and siggles, it didn’t do anything except make the sound come through unnatural
    I find using gear/speakers/wire/power is the best way to dial in those tones.
    mhardy6647 Posts: 35,170
    edited September 2020
    What is this tone control of which you speak?
    Fug, I don't have a balance control -- although there are absolutely times that I wish I did.
    47442002372_bd84dc7c3c_b.jpgDSC_4263 (3) by Mark Hardy, on Flickr
    47502189721_48d0222575_b.jpgDSC_4274 (2) by Mark Hardy, on Flickr
  • BlueFox
    BlueFox Posts: 15,250
    I probably did a little when I first started back in the 70s, but haven’t for years now. I don’t remember what last piece of gear even had tone controls. The volume and balance controls do get a workout.
  • joecoulson
    ^drooling over the Magicos
  • BlueFox
    Don’t get them wet. :)
  • joecoulson
    They were one of two end game speakers for me that I got to experience at Axpona. The others were YG Acoustics.
    One of those two will be my end game brands.
  • Emlyn
    Emlyn Posts: 4,796
    Everything in an analog stereo system is a tone control. Toeing in a speaker or moving it closer to a wall affects the treble and bass, is one example. Tube rolling in a tube preamp is another.
    Using a tone circuit in an analog preamp is a cop out. The degree to which it affects the purity of the preamp’s output depends on the preamp. There are even digital processor stereo preamps now that have room correction capability built in. Anthem makes an interesting one which helps integrate subwoofers into a stereo. :)
  • afterburnt
    afterburnt Posts: 7,892
    Grandpa said "said son, don't you ever eat no beaver" now I want to use tone controls!
    But seriously, I think my Parasound P-5 has them??? But my Marantz something 8006 has them and Zero Fidelity said he doesn't like it in bypassed to defeat the tone knobs like (purulent) mode. I think I agree, however we are talking about all of them set to neutrino. This piece is dedicated to my cheap vinyl system now and it ain't been hooked up to a TT so I may very well use the tone controls. I am anxious to see how it pairs with the part time Emo monoblocks.
  • mlistens03
    mlistens03 Posts: 2,767
    I use them very occasionally for quite poor recordings. On some radio stations it is almost a necessity as well.
    Now in my Buick... the stereo is so bad that when the bass is all the way up and the treble all the way down, it sounds like just the opposite. I can't describe how terrible it is.
    Post edited by mlistens03 on
    Viking64 Posts: 7,598
    I haven't used them since listening to "KISS Alive II" in 1978. :o
  • Dr_Wu
    Dr_Wu Posts: 356
    I still have a Soundcraftsmen EQ, as well as an NAD preamp with tone controls. I never used the preamp controls, and haven't used the EQ since upgrading my power and cabling situation.
    Viking64 wrote: »
    You can't hear anything after a KISS concert...
  • Thanks all this makes me feel good about ordering a piece that doesn’t have them.
    Living Room
    Office
  • Using "tone controls" is like going to a fine restaurant and telling the chef to leave off one or more of the main ingredients in a signature dish.
    Harry / Marietta GA
  • joecoulson
    Or dumping salt and pepper on that fine meal.
    unless that ingredient is spinach...
  • halo
    halo Posts: 5,618
    I have the MF2si and it replaced the Cambridge Audio CXA60 in my main setup. While the CXA60 has tone controls and a balance control, I didn’t use them. But, I’m not against using them and experimenting with them to see if they fit you, your room, or your setup. If they don’t flit your boat, you can always zero them out/bypass them on the Parasound gear. Experimenting can be fun, especially when it’s so easy to go back to where you started. That said, the MF2si provides a really wonderful sound in my setup that I have no desire to change or modify.
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
    afterburnt wrote: »
    Have what?
    The first rule about tone controls is that you don't talk about tone controls.
    Actually, more like slathering ketchup over the dish. :#
  • Does using a sub to assist the low end count? If so then I'm guilty.
