Custom SDA Circuit Boards
Last chance to get your 4th & 5th Gen SDA/SDA SRS boards, I sent David (@westmassguy) at DHS Speaker Service the last of my boards. So when there gone they will be gone for Good.
Just a refresher:
These are bare boards (no components) and were designed to use bigger Caps & Resistors like Sonicap & Mills and will only work for the following 4th & 5th Gen SDA/SDA SRS's with a single board crossover and a Pin/Blade I.C. cable.
(* denotes early transitional model.)
*SDA 2B (1987 Blade/Blade I.C. with single board crossover)
SDA 2B/CRS+ (Pin/Blade I.C.)
*SDA 1C (1987 Blade/Blade I.C. with duel board crossover)
SDA 1C
SDA SRS 2 (1987 Pin/Blade I.C. with single board crossover)
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Check with David (@westmassguy) at DHS Speaker Service David can even build them for you, You would need to contact David at DHS Speaker Service about doing this and the cost. His work and reputation are above reproach. He is highly recommended.
Also check out the support the support site www.gimpod.com for parts list, parts placement guide, assembly tips, schematics and more.
A Big thanks to David (@westmassguy), Trey (@VR3), Polk for there help & letting me do this and of course everyone who purchased a set.
Top View
Bottom View
Just a refresher:
SDA 1C
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Decided to order a spare pair--I like to envision picking up a pair of 3.1TL at some point in the hazy future and it would be a shame if I didn't have Gimpod boards to make the crossover work neat & tidy! Never regretted for a second having your boards when I did my 2BTL crossovers.
Thanks for the work involved in getting the boards designed & fabricated and for making your site as useful and informational as it is--a big gift to those of us with passion for SDA.Jay
Con Mucho Gusto TonyHome Theater/2 Channel:
dhsspeakerservice.com/ -
Awesome Boards! Thank you for them, and you efforts in making it easy for a beginner to redo their X-Overs
