Custom SDA Circuit Boards
Last chance to get your 4th & 5th Gen SDA/SDA SRS boards, I sent David (@westmassguy) at DHS Speaker Service the last of my boards. So when there gone they will be gone for Good.
Just a refresher:
These are bare boards (no components) and were designed to use bigger Caps & Resistors like Sonicap & Mills and will only work for the following 4th & 5th Gen SDA/SDA SRS's with a single board crossover and a Pin/Blade I.C. cable.
(* denotes early transitional model.)
*SDA 2B (1987 Blade/Blade I.C. with single board crossover)
SDA 2B/CRS+ (Pin/Blade I.C.)
*SDA 1C (1987 Blade/Blade I.C. with duel board crossover)
SDA 1C
SDA SRS 2 (1987 Pin/Blade I.C. with single board crossover)
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Check with David (@westmassguy) at DHS Speaker Service David can even build them for you, You would need to contact David at DHS Speaker Service about doing this and the cost. His work and reputation are above reproach. He is highly recommended.
Also check out the support the support site www.gimpod.com for parts list, parts placement guide, assembly tips, schematics and more.
A Big thanks to David (@westmassguy), Trey (@VR3), Polk for there help & letting me do this and of course everyone who purchased a set.
Top View
Bottom View
Just a refresher:
SDA 1C
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Let's all try and be excellent to each other always. JMO
Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
"Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
"50% Why... That's almost half."
"I know, I'm sick and need help."
Gimpod Custom 4th & 5th Gen SDA Circuit Boards
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
Thanks for the work involved in getting the boards designed & fabricated and for making your site as useful and informational as it is--a big gift to those of us with passion for SDA.
SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8 (x2)
Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
