Custom Power Cords
Grimster74
Grimster74 Posts: 2,564
I received my new SVS PB16-Ultras yesterday as many know. My question is, who makes decent power cords for a decent price. Reason I ask is SVS sent a 6' 14 gauge power cord and due to the placement of my subs I could really use a 8' power cord. Trying not to break the bank here, just payed for the subs themselves, lol! Any help/recommendations would be greatly appreciated?
  • marvda1
    marvda1 Posts: 4,871
    edited June 2020
    what's your budget for the two cords?
    http://www.cullencable.com/red-series/
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
    VR3 Posts: 28,020
    Signal cable would be hard to beat price wise
    VR3 Posts: 28,020
    Also supra makes extremely good cables for the money, I personally use the lorad
  • Grimster74
    VR3 wrote: »
    Wasn't even sure if SC was still in business or not. The 4' power cords used on my old SVS's were SC power cables. I'll have to check them out again!
    pitdogg2 Posts: 24,560
    Or make your own from raw cable and male end from a local HD, Menards or Lowes. You would need to buy the IEC end off the internet.
    https://www.google.com/search?q=Marinco+320IEC+15A&rlz=1C1GCEV_enUS853US853&oq=Marinco+320IEC+15A&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8&safe=active&ssui=on
  • tophatjohnny
    tophatjohnny Posts: 4,163
    Doug still in busines?
  • DaveHo
    DaveHo Posts: 3,480
    marvda1 wrote: »
    I second this suggestion. Have a couple of Patrick's cords. Hard to beat for the money. They are also nice & flexible which is a plus in my book.
    DaveHo wrote: »
    marvda1 wrote: »
    Those are super reasonable
  • halo
    halo Posts: 5,616
    Douglas Connections our Pangea are also good quality and reasonably priced. DIY available with Douglas Connections too
  • Jazzhead
    Jazzhead Posts: 523
    If you are into DIY you could build the DIY version of the VH Audio Flavor 4 cable:
    http://www.venhaus1.com/diymains.html
    Polk Audio first generation RTA-12s; 12 inch Polk Stands; DHS Speaker Service upgraded crossovers w/ Sonicap/Mills; the "westmassguy anti-lobing mod" (hyperdamped outer drivers/mirror imaged); tweeter anti-diffraction mod; Cardas binding posts; Neotech UPOCC internal wire; foam-lined inner driver baskets; xschop phase plugs; deleted fuses; Hurricane nuts; Sonic Barrier; Dynamat Xtreme
    Ayre K-5xeMP preamplifier
    Cambridge Audio 840C CD player; Herbie's Audio Lab Super Black Hole CD Mat
    D-Sonic Custom Audio M3a-600M monoblock amplifiers
    NAD 4155 FM/AM tuner
    Silnote Audio Morpheus Reference II Series II balanced interconnects; Virtue Audio single-ended interconnects
    Kimber 12TC speaker cable w/Furez connectors; VH Audio Flavor 4 power cables w/Furutech connectors
    Herbie's Audio Lab system isolation: Tenderfeet, Big Fat Dots, Grungebuster Dots, Little Fat Gliders
    Dedicated 20A/10 AWG circuit; Furutech GTX-D (G) outlet; Furutech eTP80; Shunyata Research Venom Defender; Synergistic Research Orange fuses
  • delkal
    delkal Posts: 764
    edited June 2020
    I made some power cords similar to the unshielded type-2 without the separate hose. I used 12 ga milspec PTFE conductors twisted together, an oppositely twisted ground and a set of Sonarquest plugs. I am not sure how they rate against higher end cables but their was definitely a difference compared to the cheap stock cables. If you are DIY on a budget I will recommend Sonarquest plugs. They don't have the heaviest plastic parts but they use pure copper connectors with solid connections where it matters. And they are only $20 shipped. I bought a couple from this guy. I offered $36 for 2 pairs and he accepted the bid.
    https://www.ebay.com/itm/SONARQUEST-SE-RP-B-SE-RC-B-Red-Copper-Power-Plug-IEC-1-set/123202049886?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
  • Jazzhead
    Jazzhead Posts: 523
    A friend has high praise for the Sonarquest silver-plated plugs he uses on his power cable builds. I prefer the sound of gold, but either way the Sonarquest plugs are a great value. And Chris VenHaus' power cable recipes are the bomb.
