Mobile/Full Site Issue
F1nut
If you are having a problem accessing the full site in your mobile device (I am) please know that Vanilla has been made aware of the issue. Hopefully, they will get it fixed tomorrow because this mobile site SUCKS!!!
And it still dont work. The mobile site is the only one I can even log in on since last falls mishap. I cant log in with any computers, or tablets. I can only log in with my phone and now the Mobile/full site dont even work, might as well just head on over to the Hoffmann forum where everything works properly. I cant beleive all the issues Vanilla has encountered since the change over.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
I was wondering if I was the only one having this problem since no one else said anything.
Vanilla asked for more info from me today about the problem because they didn't see the problem at their end. This isn't the first time we've had this particular issue either.Political Correctness'.........defined
President of Club Polk -
Jesse I just tried on my phone and I can’t access the full site either. FYI I’m trying with a new iPhone XR so it isn’t an older device.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Works fine for me on my iPhone 7, iPad Mini, and iPad. However, I use the normal computer view, not the mobile view.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It was suggested to me to clear my browser history/cookies. I did and still can't access the full site on my phone. Works fine on my computer though.Political Correctness'.........defined
For the last 2-3 days it does not work on my phone also...
Randy/Maine -
Hard reset does not work either. Mobile (at least on Android) is down for the count.
Samsung note 8, chrome, mobile and desktop versions working correctly- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I just tried to access the full site. It says I'm in the full site, but I'm not. When I hit the back to mobile site all that happens is I'm directed back to the categories.
The full site is down. -
It just worked fine for me on iPhone XR FYI...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
And I’m back to mobile...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
I'm not having any problems. Maybe vanilla is trying to weed out the flakes...
Kidding. Try turning off your phone for at least thirty seconds. Then turn it back on. That often resets them and clears out a lot of cr apGustard X26 Pro DAC
My browser does not keep anything. When I close it all cookies and other junk in it are nuked.
I did just turn off and back on for shiggles... same full site no workie for me.
If it make a batturd difference I have a tracfone and it rides on Verizon...
Ok, it's obvious to me that Vanilla has a problem, the same problem they had in November 2018, which they eventually fixed.Political Correctness'.........defined
I have a suggestion for Polk and Vanilla, get rid of the mobile site option. It's beyond horrible anyway.Political Correctness'.........defined
Could be a browser issue too in which case you may have to wait for an update for the latest update or try uninstalling and reinstalling (which is a huge PITA) and then not doing auto updates for a while.Gustard X26 Pro DAC
The full site doesn't work for me either...Remember, when you're running from something, you're running to something...-me
I just flipped back to full...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
And back again...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
https://youtu.be/jKE3ZLj7_V8
https://youtu.be/p8Izxkm-e7s
It never be workin when it oughta should they waste your time they wasting mine. Yep still no worky.Home Theater
No issues from my older Android. Switched to full site...don't really immediately see any diff. But still working ok.
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements." -
I’ve only ever accessed the site via iPad or phone. I’m not sure I’ve ever seen the “full site”....
This is what I see:
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn -
That is the full site Mark.
I have a suggestion for Polk and Vanilla, get rid of the mobile site option Vanilla. It's beyond horrible anyway.
I have a better ideaSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
C'mon Vanilla, can't be that hard of an issue to fix.Political Correctness'.........defined
Not seeing this issue. I'm able to flip flop back and forth between mobile/normal, no problem.
Others most definitely are having the problem.Political Correctness'.........defined
I can’t get the full site on my iPhone 📱Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Yep I’m the same way.
