Mobile/Full Site Issue
F1nut
F1nut Posts: 52,017
If you are having a problem accessing the full site in your mobile device (I am) please know that Vanilla has been made aware of the issue. Hopefully, they will get it fixed tomorrow because this mobile site SUCKS!!!
«13
    gudnoyez Posts: 8,174
    And it still dont work. The mobile site is the only one I can even log in on since last falls mishap. I cant log in with any computers, or tablets. I can only log in with my phone and now the Mobile/full site dont even work, might as well just head on over to the Hoffmann forum where everything works properly. I cant beleive all the issues Vanilla has encountered since the change over.
    F1nut Posts: 52,017
    I was wondering if I was the only one having this problem since no one else said anything.
    Vanilla asked for more info from me today about the problem because they didn't see the problem at their end. This isn't the first time we've had this particular issue either.
  • polrbehr
    polrbehr Posts: 2,852
    Jesse I just tried on my phone and I can’t access the full site either. FYI I’m trying with a new iPhone XR so it isn’t an older device.
  • BlueFox
    BlueFox Posts: 15,250
    Works fine for me on my iPhone 7, iPad Mini, and iPad. However, I use the normal computer view, not the mobile view.
    F1nut Posts: 52,017
    It was suggested to me to clear my browser history/cookies. I did and still can't access the full site on my phone. Works fine on my computer though.
  • boston1450
    boston1450 Posts: 7,758
    For the last 2-3 days it does not work on my phone also.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    treitz3 Posts: 20,131
    Hard reset does not work either. Mobile (at least on Android) is down for the count.
    VR3 Posts: 29,554
    Samsung note 8, chrome, mobile and desktop versions working correctly
    pitdogg2 Posts: 27,356
    I just tried to access the full site. It says I'm in the full site, but I'm not. When I hit the back to mobile site all that happens is I'm directed back to the categories.
    The full site is down.
  • rooftop59
    rooftop59 Posts: 8,120
    It just worked fine for me on iPhone XR FYI...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    And I’m back to mobile...
    Game Room 5.1.4:
    Bedroom 2.1
    audioluvr Posts: 5,990
    I'm not having any problems. Maybe vanilla is trying to weed out the flakes...
    Kidding. Try turning off your phone for at least thirty seconds. Then turn it back on. That often resets them and clears out a lot of cr ap
    edited May 2020
    audioluvr wrote: »
    My browser does not keep anything. When I close it all cookies and other junk in it are nuked.
    I did just turn off and back on for shiggles... same full site no workie for me.
    If it make a batturd difference I have a tracfone and it rides on Verizon...
    F1nut Posts: 52,017
    Ok, it's obvious to me that Vanilla has a problem, the same problem they had in November 2018, which they eventually fixed.
    F1nut Posts: 52,017
    I have a suggestion for Polk and Vanilla, get rid of the mobile site option. It's beyond horrible anyway.
    Could be a browser issue too in which case you may have to wait for an update for the latest update or try uninstalling and reinstalling (which is a huge PITA) and then not doing auto updates for a while.
  • smglbrth
    smglbrth Posts: 1,499
    The full site doesn't work for me either...
  • rooftop59
    I just flipped back to full...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    And back again...
    Game Room 5.1.4:
    Bedroom 2.1
    edited May 2020
    audioluvr wrote: »
    https://youtu.be/jKE3ZLj7_V8
    https://youtu.be/p8Izxkm-e7s
    It never be workin when it oughta should they waste your time they wasting mine. Yep still no worky.
  • CoolJazz
    CoolJazz Posts: 572
    No issues from my older Android. Switched to full site...don't really immediately see any diff. But still working ok.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • daddyjt
    daddyjt Posts: 3,146
    edited May 2020
    I’ve only ever accessed the site via iPad or phone. I’m not sure I’ve ever seen the “full site”....
    This is what I see:
    ― Aleksandr Solzhenitsyn
    That is the full site Mark.
  • daddyjt
    Thanks!
  • polrbehr
    I have a suggestion for Polk and Vanilla, get rid of the mobile site option Vanilla. It's beyond horrible anyway.
    I have a better idea ;)
    F1nut Posts: 52,017
    C'mon Vanilla, can't be that hard of an issue to fix.
    Clipdat Posts: 13,100
    Not seeing this issue. I'm able to flip flop back and forth between mobile/normal, no problem.
    F1nut Posts: 52,017
    Others most definitely are having the problem.
  • vmaxer
    vmaxer Posts: 5,121
    I can’t get the full site on my iPhone 📱
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • rooftop59
    Clipdat wrote: »
    Yep I’m the same way.
    Game Room 5.1.4:
    Bedroom 2.1
