Stacking Subs
afterburnt
afterburnt Posts: 7,892
edited May 2020 in Speakers
I see no way around it, I don't have enough space. I have 2 each SVS PB 2OOO and Rythmik F12. It looks like I have to stack them all side by side in the same front corner I guess with the Rythmiks on top. The only other option still stacked is putting one pair still stacked in front of a floor register aimed at my left ear. Is there a problem structurally with stacking them? And soundwise does it defeat the purpose of having two?
  • afterburnt
    I have to figure this out because once it's done they will never move again. It hurts too much.
  • Gardenstater
    Gardenstater Posts: 4,780
    Uhhh........well.......nevermind..... :#
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • afterburnt
  • afterburnt
    FWIW I have two systems in the same room one 2 channel and one HT. Why? Because I can! I think.
  • afterburnt
    This is gonna be bittchin, you should come over and check it out cept I don't let anyone in my house.
  • afterburnt
    I need a bigger house
  • mlistens03
    mlistens03 Posts: 2,767
    Correct me if I'm wrong but the advantage to having two subwoofers is better dispersion characteristics in the room? If they're in the same place then that ain't gonna change much, AFAIK. Worth a shot to try at least, methinks.
  • afterburnt
    mlistens03 wrote: »
    I agree in theory, I am going to figure out how to split them up and so what if I lose the skin off of the left side of my face it's not my good side anyway. Sitting within a few feet of some fairly powerful subs is probably not a great idea but I don't plan on fathering any more children.
    msg Posts: 10,452
    I think I've seen it done, but not sure whether there should be some kind of isolation between them.
    The sub feet I've seen are squishy vs pointy spikes, so I'm thinking some Sorbothane hemispheres may do the trick if you don't already have feet on your subs. You'd want to monitor the subs to make sure the upper ones aren't walking off the lowers.
    And some testing stacked vs unstacked to see whether there's any noticeable difference to you.
    No sense of convention on whether they should be placed in stereo fashion vs stacks of like-subs. I would imagine factors for consideration would be room layout, equipment placement, and system type, HT vs 2ch.
  • afterburnt
    Scott, stereo looks good but not necessarily optimal but splitting them up aimed at 90 degrees should be better but dialing in the delay will be they key. I figure I can make a deflector to keep the HVAC from blowing on them at least they will be near the door if I have to 86 them. I wish I just had a bunch of "mini vee's" and I wish I knew then what I know now.
  • mantis
    mantis Posts: 17,374
    Possible to post some pics of your room? I could look it over and see if there is a few optional places where 1 or more subs would perform the best.
    Dan
  • afterburnt
    Dan, I will try that but I am afraid you will think that I am crazy LMAO!
    msg Posts: 10,452
    afterburnt wrote: »
    Re: the delay, do you mean from daisy-chaining? Do your sources support dual subs? I think I've read of people using RCA splitter cables to use stereo subs, but no experience with this.
    How's the audio market look in your new place? Maybe you could sell off the bigger subs and pick up some smaller ones. I'd hold onto the bigger ones for a bit though if you plan to test smaller subs. You don't want that kind of seller's remorse.
    But yeah, good question from Dan above, maybe some sense of floor/room layout, dimensions, seating area, etc. Just sketch it out with red or blue crayon on the wall and shoot us a photo.
  • afterburnt
    Guitar neck on left is the cornern the rack will be in the same quadrant 8ij47s8tt5q0.jpg
    This the left side by the register I think it shows the guitar neck for a point of reference.
    Another shot of the side that's not an option.
  • afterburnt
    edited May 2020
    Well that sortta worked can't see what the phone is gonna show
  • afterburnt
    Note the tastefully place black light tubes lol
  • afterburnt
    Man I screwed that up. Second shot is the place at the end of the sofa by the HVAC register.
  • mpitogo
    mpitogo Posts: 516
    edited May 2020
    I've been thinking the same thing. Just because of room layout I can't go bigger but I can go up...
    Also I've found other threads here about it.
    https://forum.polkaudio.com/discussion/173320/stacking-subwoofers
    Nice setup someone posted in that thread
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • afterburnt
    @mpitogo I have two options if I need to get in my room. I am going with stacking the Rythmiks on the SVS
  • Gardenstater
    Are the subs spiked and are they downward firing or forward?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,750
    Aren't you moving shortly?
  • afterburnt
    Rubber feet and using those little blue sammiches.
  • afterburnt
    Jesse, this is the relocation. Sure is easier to build into a room than make the stuff fit when moving.
  • afterburnt
    What, you can't belive I already wrecked my new house?
    msg Posts: 10,452
    Yeah, that's a tough space, Bruce.
    Would you be able to
    1. Move the couch/loveseat to the position from which you're shooting the photo, parallel to your tv?
    2. Nail that closet door shut on the right after filling it with old fur coats?
    3. Throw away that one guitar?
    That would give you room to spread out the speakers, and maybe experiment with the subs either inside or outside of the speakers.
    I have difficult spaces, too. I had a similar setup in my main space at one point in front of my window, but missed the use of the window, so I rotated the system 90° CCW. I've lost the benefit of the side walls in this space, but it's more functional for the living space this way. The big sub helps fill in the bottom end, but it's not a setup that speakers can perform without a sub now. The system performed better overall when I had it set up more like the way yours is. I had almost that same setup going with a loveseat in the same area and the sub in that same corner. Had a little more width, but still not ideal.
    txcoastal1 Posts: 13,512
    I can’t see mixing subs in any room for 2-chnl without a lot of work
    Test what’s best, sell and store the other pair
    msg Posts: 10,452
    Oh, I thought the idea was that they'd be used in two different systems in the same space. Not sure now where I got that idea.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Never heard of stacking but we enjoy a pair of PC 2000's in our living room and they sure are a treat. Our living room isn't huge but it's certainly not small. Stacking the PB's ??? Fired up should boom that spot. As for EQ ..its your ears that need to be happy. I'm not coming over😷
  • mantis
    afterburnt wrote: »
    Aren't we all?
    Dan
  • mantis
    afterburnt wrote: »
    I like the left front corner for one sub but how about a pic of the opposite wall? Not the one your couch is on but basically the right side back corner. That would be ideal in that room.
    Dan
