Sonic Barrier Damping Sheets/Rolls
It had been awhile since I last ordered Dynamat, and apparently now, Sonic Barrier butyl damping sheets with foil backing are the way to go. Parts Express doesn't even carry Dynamat products at this point.
Today I received my order for a roll of the Sonic Barrier damping sheet material, and it looks good. I cut a test strip and stuck it to a woofer basket frame...works a treat!
    F1nut Posts: 52,313
    I don't recall PE ever carrying Dynamat. You can get a from a zillion places including Amazon, Crutchfield and even directly from Dynamat.
  • jdjohn
    jdjohn Posts: 3,437
    You may be right about Parts Express never carrying Dynamat, but it seems options for Dynamat in general have shrunk a bit...at least for the butyl foil-backed sheets/rolls. And when you find it, it's expensive compared to other options. Maybe a patent ran-out for Dynamat?
    Parts Express has a 25sq/ft roll of Sonic Barrier for $60.
    I found 36sq/ft options for Dynamat on Amazon, and at Crutchfield, for $160.
    I'll let you do the math.
  • skrol
    skrol Posts: 3,488
    I've used Nioco 80 mil in cars with very good results. The Dynamat Extreme is probably a little better but us much more expensive. The Noico also works great on speaker baskets.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • westmassguy
    westmassguy Posts: 6,850
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    VR3 Posts: 29,704
    Yep ebay has been my go to for dynamat
    pitdogg2 Posts: 27,787
    I used this last time. It's a little thicker and much more tacky. This is way more than you need, but it is an alternative that does the same thing. I was able to buy a few sheets from my local car audio installation shop.
    https://www.ebay.com/itm/Second-Skin-Damplifier-10-sqft-Butyl-Sound-Deadening-Material-1mm-40mil/254267334843?epid=3014404355&hash=item3b3383a0bb:g:bwsAAOSwPqZeVWNO
  • jdjohn
    jdjohn Posts: 3,437
    I'm probably set for life now with my 25 sqft roll :D Shoulda thought that one over a little more first.
