Sonic Barrier Damping Sheets/Rolls
jdjohn
It had been awhile since I last ordered Dynamat, and apparently now, Sonic Barrier butyl damping sheets with foil backing are the way to go. Parts Express doesn't even carry Dynamat products at this point.
Today I received my order for a roll of the Sonic Barrier damping sheet material, and it looks good. I cut a test strip and stuck it to a woofer basket frame...works a treat!
I don't recall PE ever carrying Dynamat. You can get a from a zillion places including Amazon, Crutchfield and even directly from Dynamat.
You may be right about Parts Express never carrying Dynamat, but it seems options for Dynamat in general have shrunk a bit...at least for the butyl foil-backed sheets/rolls. And when you find it, it's expensive compared to other options. Maybe a patent ran-out for Dynamat?I don't recall PE ever carrying Dynamat. You can get a from a zillion places including Amazon, Crutchfield and even directly from Dynamat.
Parts Express has a 25sq/ft roll of Sonic Barrier for $60.
I found 36sq/ft options for Dynamat on Amazon, and at Crutchfield, for $160.
I'll let you do the math."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I've used Nioco 80 mil in cars with very good results. The Dynamat Extreme is probably a little better but us much more expensive. The Noico also works great on speaker baskets.Stan
Main 2ch:
HT:
Other stuff:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dynamat+wedge+pack&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=dynamat
Been buying it off eBay for yearsHome Theater/2 Channel:
dhsspeakerservice.com/ -
Yep ebay has been my go to for dynamat- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'm probably set for life now with my 25 sqft roll
Shoulda thought that one over a little more first. "This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
