Looking forward to L800 but have concerns, what are your thoughts?
Excuse me, the Marantz MM7055 is apparently $1,199. Yet, unless I'm remembering it wrong the L800's received glowing reviews at RMAF hooked up to it.
nooshinjohn wrote: »Looking at the specs for the Cambridge, I have my doubts that it was up to the task. Not saying it is a bad piece of gear, but if the Polks are that demanding, it may simply [have not] been a good pairing is all.
So a connecting a $6k pair of speakers to a 54lb $6k integrated that does 100wpc into 8ohm and 200wpc into 4ohm isn't "a good pairing"?
At RMAF, Polk had them connected to a Marantz HT processor and a MM7055 multichannel HT amplifier. (https://www.audioadvice.com/marantz-mm7055-5-channel-power-amplifier.html) - They could've used anything and they used this pedestrian amp.
You seem to be hung up on the equipment or setup at Skip's Polkfest event being a culprit for what people heard and ignoring the fact that keeps getting mentioned about how the Polk representative was present and confirmed several times that the L800s were performing as intended.
Please try to accept and respect what people heard at the event and their opinions on the sound, instead of looking for any excuse as to why something wasn't "right" with the setup.
Too much to pick apart here, but that is not my intention. All I said was there may... MAY have been some sort of synergy issue with that setup. The review also pointed out issues with the room... the exact issue that was at Skip’s house. All I am saying is a professional reviewer caught the same stuff you guys reported, then set about citing the SAME concerns I had and cited Polk’s own manual for these speakers to show the requirements for the speakers were not met in his listening space. He also said he went through hell looking for synergy before he found it.
The Polk rep was out of his mind if he said they were set up properly when the manual itself says they were not.
I am going to state here that I fully accept what was heard at Skip’s as fact, and the review in the video confirms all that you guys said. I see that, but you should also see what I was saying as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I did say if I ever had the opportunity to hear them in an ideal environment I would gladly do so. But I've only seen the L800 at two places (only listened at one), and neither had symmetry. Like so many things in audio they are hard to come across in person.
When it comes down to ownership, it's still not something I'd consider. In their price range there are other speakers that I like the sound of that are far less particular than the L800. I do think they would be hard to live with for most people.Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
nooshinjohn wrote: »Looking at the specs for the Cambridge, I have my doubts that it was up to the task. Not saying it is a bad piece of gear, but if the Polks are that demanding, it may simply [have not] been a good pairing is all.So a connecting a $6k pair of speakers to a 54lb $6k integrated that does 100wpc into 8ohm and 200wpc into 4ohm isn't "a good pairing"?
In this case, apparently not. Synergy is a biotch.At RMAF, Polk had them connected to a Marantz HT processor and a MM7055 multichannel HT amplifier. (https://www.audioadvice.com/marantz-mm7055-5-channel-power-amplifier.html) - They could've used anything and they used this pedestrian amp.
Because the synergy was right, perhaps?You seem to be hung up on the equipment or setup at Skip's Polkfest event being a culprit for what people heard and ignoring the fact that keeps getting mentioned about how the Polk representative was present and confirmed several times that the L800s were performing as intended.
I could care less about the gear, as it sounds like synergy was not achieved, and therefore any listening was a challenge to start with. Did he also say they sounded as intended? Seems to me you guys said some sort of partition was half-hazardly cobbled together to try and create a reflection point.Please try to accept and respect what people heard at the event and their opinions on the sound, instead of looking for any excuse as to why something wasn't "right" with the setup.
Based upon the review video, it seems to me that the creator of said review encountered many of the same issues you guys did and said the same things I did with regards to set up.
Not disputing at all what you heard, but I accept the reviewer's position that these are one of the most demanding loudspeakers to set up correctly and pair with the proper gear, and they are the most difficult loads for an amplifier to control that Polk has ever created.
I do not understand why Polk chose to create such a demanding speaker. To me, all this does is add value to the original SDA-SRS line.
He also said on the same album even after his matching, some sounds sounded great and some did not. We experienced that as well.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Understood, and I accept all of that. IMHO, no speaker should be that particular. Synergy is a biotch, but it would appear that these may be on an entirely different level of difficulty. Another possibility is that they are the same demo pair and they have a problem.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Wow harsh. I agree with amp being picky. My LSiM 707 works great with balanced differential amplifiers MC452/PM-10. But with L800 not so, SDA was weak. As far as recordings, I agree poor recordings just don’t do well. Not sure about his room setup and treatment but I have mine in a decent sized 16dx25w and love them.
Everything else is just hurtful. Wow and that was a paid Polk review.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
I have yet to hear a poor recording sound good on anything... SDA or not.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Not paid, but certainly not what Polk was hoping for I'm sure.Wow and that was a paid Polk review.
Discogs -
Ok will edit. Misread that disclaimer.
I’m still at a loss to understand how this guy can think the L800 is the most difficult load to control that Polk has ever created yet they sounded great with an $1,199 Marantz MM7055 multichannel HT amp? Too many statements floating around that lack foundation.
You better hurry up. You're almost out of time.
And he said a pro-ject intigrated was his choice for synergy. That kind of suprised me.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
C'mon gents, like you guys never came across a speaker before that was power hungry and picky about placement. This is by far not unique to the l800's. Like Doc said, many highly regarded speakers suffered the same criticism.HT SYSTEM-
lsi 9's -
This is why reviews should be taken with a grain of salt. Some may deserve a bit more weight than others, depending, but the only opinion that matters is going to be yours. On your gear, in your room, with your ears.HT SYSTEM-
lsi 9's -
It's hard to believe something like the MaiA S2 at 38wpc @ 4 ohms had the best synergy. In fact, it puts into question his entire review.Political Correctness'.........defined
President of Club Polk -
Bingo JessHT SYSTEM-
lsi 9's -
he did say it's not about the number of watts but current.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
That is why I want to get my amps on a pair. High watts and high current should be a match made in heaven, and may just be what solves some of these other issues. I will be happy to travel within 150 miles and bring the amps with me just to hear how that sounds.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
….Most people just listen to music and watch movies. I EXPERIENCE them.
High watts and high current does not equal synergy. I think it best that you not comment further until you have actually experienced it. Everything you have said so far is baseless assumptions. So stop offending everyone that did experience it.
You know? I have never relied on some magazine or some online review.
Buy a pair man. -
Never said high watts and high current would equal synergy either, but it does sound like a good place to start... As far as commenting goes, I will say what I like. I don’t agree with every review or magazine I read either, nor do I trust anybody else’s ears but my own.
I especially don’t trust ears that heard a pair of speakers not set up properly, according to the suggestions and guidelines of the manufacturer and have at best, a couple hours (and less time in the sweet spot) of experience with them in an unfamiliar space.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Never said high watts and high current would equal synergy either, but it does sound like a good place to start... As far as commenting goes, I will say what I like. I don’t agree with every review or magazine I read either, nor do I trust anybody else’s ears but my own.
You mentioned synergy in your previous posts. So I thought I would mention to get clarity.
Yes. Say what you like but it is still baseless assumptions. You have a voice but don’t talk when you have not experienced it. It gives zero credibility. You could talk all day about your high end DIY amp among other things. It contributes absolutely nothing.
Buy a pair man. -
@Viking64 yikes missed it, I had to leave to go to a Division 2 raid.
One thing for sure at lest with my experience true balanced amplifier + L800 = under performing SDA.
Even Stu in the other thread eluded to it with the demos using a Marantz PM-KI Ruby, an excellent ncore digital integrated amplifier but single ended not fully balanced like the Marantz PM-10.
Here is what I wonder to solve for that problem. Can I run both Left/Right amplifier channels to each speaker and isolate the crossovers feeding the main drivers and SDA drivers? The SDA cables carry the respective + signals to each other but carry no return path instead rely on the common ground of a single-ended design. If I can feed discrete balanced differential to each of the isolated SDA crossover I can achieve nirvana.
Balanced amplifier one +signal push amplifier two -signal pull no shared common grounding plane
Single-ended one amplifier +signal push/pull relative to common ground- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
Buy a pair man.
John's been experiencing "SDA" Polk speakers for decades!
I think he could be called highly educated in the Polk SDA set-ups and definitely has thousands of hours with listening to them with his own ears in many locations.
John has tried to offer "advice from experiences" and he is getting attacked for some weird reasons.
And his DIY amps are something to admire and inspire others just what is possible with the right intelligence and desire.
I'd take John's advice on Polk SDA speakers and tube amps any day of the year!
Buy a pair man.
You do realize these are new SDA’s right? Your comment is like someone saying some car built some decades ago was great. So it must be great now too.
Tell me. What experience does he have with the new SDA’s? I got money, any amount you want to put down and could afford. He doesnt.
As for you being John‘s personal public relations person is funny. CNN much? -
Also since you are his spokesperson. I was going to say spokesman. But it may offend you jelly beans.
You want me to pull up his posts on SDA’s when he first joined? Lol. -
Why are there teachers and professors then?Most people just listen to music and watch movies. I EXPERIENCE them.
Are you trying to say nooshinjohn is the equivalent of a teacher or professor? LOL. What school is that?
Three 20 amp circuits. -
Alright. Bottom line. Don’t turn this Polk forum into one of those sites that claim amps, dacs, cables, make no difference.
They never experienced it. Same as the new SDA here. But the ones that have. Said what they did.
Even the Polk rep.
Damn. If I talk anymore I will start talking about build the wall. You effing socialist.
