I’m not typically afraid of heights, BUT.....
― Aleksandr Solzhenitsyn
  • scubalab
    scubalab Posts: 3,105
    N... F... W...!
  • scubalab
    At 7:17... "Look mom, no hands!"
  • vmaxer
    vmaxer Posts: 5,120
    I assume they are well paid.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • xsmi
    xsmi Posts: 1,804
    Man I made it to 1:53 and I was DONE!!
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • polrbehr
    polrbehr Posts: 2,846
    Worker 1: "You got the bulb?"
    Worker 2: "I thought you had it..."
  • halo
    halo Posts: 5,616
    I believe that lightning strikes can be a major issue.
  • ken brydson
    ken brydson Posts: 9,011
    Pfft, day at the office for Russ... B)
  • sucks2beme
    sucks2beme Posts: 5,689
    I used to do some of that in my youth.
    Waaaay too old for that now.
    treitz3 Posts: 20,041
    Your knees shot because of it? I have a buddy acquaintance that used to do that for decades and all he does is complain about his knees. He blames it on all of that climbing.
  • mrbiron
    mrbiron Posts: 5,721
    My t3sticles got a workout while watching that video.
    nooshinjohn Posts: 25,954
    I was thinking these guys make Russ look like a Wuss...
  • ken brydson
    Well, he'd have to stop halfway for a smoke break 😁
  • motorstereo
    motorstereo Posts: 2,358
    What happens if someone gets halfway up there and has an overwhelming urge to go number two? I'm thinking there's only 2 choices and neither are good ones.
    pitdogg2 Posts: 27,157
    edited February 2020
    BASE jumpers wet dream right there....
    mhardy6647 Posts: 35,145
    Like Steven Wright, I suffer only from a fear of widths.
  • CoolJazz
    CoolJazz Posts: 572
    A little back story on the original video. That came out some time back. Then it was noticed that the guy didn't use the mandatory two safety method that is required by regulations. They pulled back the video, afraid of getting in trouble. But it was already out there and flying around the web and the original post being pulled down didn't work.
    Required is two safety latches. One hooked at all times while you move the other. Now, climbing up the pole steps, that's about impossible. But to film it and put it out there is another matter.
    In more recent times, all over the country there is a television "repack" going on. So antenna systems put up for HD, not many years ago, are now being literally trashed well before end of life and probably before ever being paid off. But with congress passing out tax money, which is of course unlimited, they are blowing past that problem to squeeze frequency space away from television and be able to resell it to the cell companies.
    So the big work going on for the last couple years is pulling off antenna's and installing new ones at different frequencies. Often, this is done with industrial helicopters. Remove the old antenna, taking it down. Also lower off a section of the tower where the super strong mounting is for the top pole. Refurb or replace that top of the tower section. Then by chopper, raise up that top section and then the top pole or antenna, depending on the design.
    And here happens to be a long video showing that type of work going on. Think about tying yourself off and trying to stay hanging up there.....directly under the wash from the chopper and then trying to do the work to un-attach and re-attach sections that normally weigh tons! Set back and watch this kind of work...
    https://youtu.be/pitEq8gjNj8
    CJ
    PS...at just after the 20 min mark they actually have an accident happen. All ok though.
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • Nightfall
    Nightfall Posts: 10,083
    I get scared climbing a ladder and walking on the roof of a regular house, let alone that. :#
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Willow
    Willow Posts: 11,242
    I get scared climbing the front porch steps... you couldn't pay me 1mil to climb that. When we stayed in San Francisco we were way up in our hotel room. To get from the elevators to our room we had to cross a glass hallway. Many times I would walk fast or run across. To close the curtains, I would grab the stick/ handle and back away from the window and close them. It was the Loews hotel it was called the Mandarin at the time. We were on the 42nd floor.
  • sucks2beme
    treitz3 wrote: »
    Knees are shot but not because of that. I moved on pretty quickly.
    Years in IT crawling around under desks
    sucks2beme wrote: »
    treitz3 wrote: »
    TMI...
  • TEAforONE
    TEAforONE Posts: 1,064
    I was in a panic watching that clip!! I have a stress test in a few weeks. I'll watch it again,and they can gather their data.
    ZLTFUL wrote: »
    The steel erection....
    In my day it was called a Woodie....
    audioluvr Posts: 5,973
    CoolJazz wrote: »
    Looks like fun.
