I just pulled the trigger on a new tüübed pre....this one should be pretty sweet!
135678
    pitdogg2 Posts: 27,200
    edited January 2020
    yes very nice Tom
    I went out looking at that manufacture, they have some sweet looking gear!!
  • TEAforONE
    TEAforONE Posts: 1,069
    Congrats Tom! Looking forward to your impressions. That pre is gorgeous!!!
  • george daniel
    george daniel Posts: 12,096
    Congratulations
    treitz3 Posts: 20,069
    Well, gentlemen. I have it hooked up. Lookin' good but now I have to diagnose a nasty and rather loud ground hum of the 120Hz style. Time for an adult drink and off to dive in for diagnosis.
    Never had a ground hum before in any of the kits I have had over the years, with the exception of the vinyl part of the rig (easy to take care of), so no initial impressions yet. Sorry guys.
    I did reconfigure the rig and swapped some stuff around. Shouldn't be too hard to figure out (in theory). More later...
    nooshinjohn Posts: 25,973
    Look at the connection between the pre and the power supply, and the output tube. Is the noise across both channels or just one?
    Both.
  • BlueFox
    BlueFox Posts: 15,250
    Are you using a single circuit for pre and amps, or dedicated circuits for each? If the circuits are separate try grounding all the chassis together. If just a single circuit, no ideas.
    Single circuit. Removing the ground plug on the pre didn't work. Ain't this fun?
    I turned everything on and will leave it this way for about 10 minutes, hum going. Gonna take a break and come back in and see if it resolves itself. The Canary has been at room temperature for over 24 hours now, FYI. I have no idea when the last time she was cranked up was.
    BTW, it does not change when the volume goes up, so (again...in theory), it should be a simple fix. Just got to nail the bastage that is causing it.
  • joecoulson
    joecoulson Posts: 4,943
    edited January 2020
    Hum with nothing connected? (IC’s XLR’s etc) just power cable?
  • BlueFox
    Now we know why the original owner sold it. :)
    Good luck.
    Just thinking here, but even with a single circuit try grounding all the chassis together. If it isn’t a hardware problem then it sure seems like a ground loop issue.
    VR3 Posts: 29,520
    Unhook the subs
    Subs not in the equation right now. Input into the pre's disconnected? Same issue.
  • joecoulson
    Unhook everything and slowly hook each wire up then check so on and so forth.
  • joecoulson
    Reseat the tubes?
  • marvda1
    marvda1 Posts: 4,958
    joecoulson wrote: »
    Reseat the tubes?
    rectifier tube for sure.
    Puritan PSM156
    Deoxit the pins and sockets, then start swapping tubes one by one.
  • BlueFox
    Sounds like a few more reasons to not use 19th century technology in audio gear. Good luck.
    Whoa, slow down guys. It's just a small issue I need to diagnose. No need to reinvent the wheel here.
    I think I will take a step back for tonight and sleep on what I have done. Wake up and think about a methodical approach to chasing this noise problem. If the noise does not change with the volume or input selection (even disconnected of the pre)? Then the suspect is most likely not the pre. It has to be (logically) down stream.
    With that said, the only thing new introduced into the system was the pre....so, logic dictates otherwise.
    Looks like I have my work cut out for me and this wasn't as "simple" as I thought it would be. I was honestly expecting to be back up and running in 15 minutes or less.
    Who knows? The Canary might have an issue with going through the Richard Grey Power Supply. Besides going into the unit (Canary) itself....that's my last culprit. I have already moved it away from the rest of the gear.
    Ain't this fun? (Not)
    joecoulson wrote: »
    Yes.
    mhardy6647 Posts: 35,187
    edited January 2020
    treitz3 wrote: »
    EDIT: None of this will probably be news, nor particularly helpful -- but I'll share these thoughts, just in case.
    * Start with the simplest, dumbest system configuration to troubleshoot.
    * Run every component direct from a wall outlet for troubleshooting purposes -- skip any fancy-pants power conditoning.
    * Get a bag of clipleads and jumper component grounds together -- component to component -- systematically (EDIT Not helpful advise if the system is humming sans preamp connected).
    * Try a ground lift cheater on the power cord (if it's a three-wire cord).
    * Swap (i.e., try some different) 'interconnects' -- maybe one of them has an 'issue' (loose internal connection) that was exacerbated during the install.
    NB Just read the 'without the pre' comment before I posted -- that does sound like an unfortunate, coincidental 'issue' with an interconnect (?). If you have hum even sans interconnects (I assume this would be with just power amp & loudspeakers), and if you can safefly short the amp's inputs (some components don't like that -- I learned this from an unfortunate event I catalyzed for poor ol' @clipdat), try that and see if the noise is related to the inputs or not.
    PS and FWIW I am empathetic -- chasin' a noisy active preamp issue here myself albeit very slowly.
    49363581777_4aacf41927_b.jpgDSC_8089 by Mark Hardy, on Flickr
    Where do you stand on this now Tom?
    Hi, John. Thanks for asking. I spoke with John at Canary Audio multiple times today. I have a couple of more things to check but it looks like she's headed back to Canary at this point. We have determined that it is not an impedance mismatch issue and apparently it wasn't as simple as I thought.
    I dumbed the system down to literally this - Pre>amp>speakers. The pre was on a PC with the ground pin removed and both the amp and the pre were on the same outlet, both plugged directly into said outlet. No IC's from any other component and no other gear used in any shape, form or matter.
    Same thing.
    I'll take a look inside before I send it off and see if there is anything obvious. Just didn't feel like rushing my day again to find the time to deal with it again, truth be told. I'm not even going to bother with it tonight. Just don't feel like F'n with it right now.
  • joecoulson
    Thomas so disappointing, very sorry that you’re having to deal with that. Nothing worse than getting in something you have spent a lot of coin on and very excited about only to be let down by an issue like this. Hope you get it fixed soon.
    On a sidenote I don’t think I’m going to be able to make it this time around as I have to rush back home to go out of town with the wife. But I will tell you that I’m going to be up here very frequently with what we have planned for this market so there will be plenty of times in the next coming months for us to get together
  • lightman1
    lightman1 Posts: 10,797
    Yep.... Less than a week..
    Clipdat Posts: 13,100
    @treitz3 did you try removing and re-seating the tubes or different rectifier tube(s)?
  • GlennDog
    GlennDog Posts: 3,157
    I don’t know whatcha got on the digital side of things. This will fit in nicely . . .
    https://www.audiogon.com/listings/lis9e9fb-canary-audio-kd-2000-tube-dac-brings-analog-heaven-to-digital-da-converters
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    edited January 2020
    Hi, Glenn. I am actually fine with DAC's at the moment. The one that is in the Marantz SA-7S1 is one of the best I have ever heard in my travels and the one I have for the server is kind of overkill for the server itself...(Photo below taken from random image off of the internet)
    My weak link in the network gear would currently be the Blue Node2. I typically don't listen to the network gear in the sweet spot, usually only when I'm in the office working (in another room) or doing other things around the house. Pretty much the only other exception is when I want to try new music that I don't have the "physical" media for. In other words, not really a priority for me. It's just a nice luxury to have (to me).
    Drew, I have not yet fiddled with the internal components within the two units. Hopefully I can find some time tonight. I exhausted every other test this morning and that's all that is left to check on.
    Then one final test before shipping off to double check my amp just in case it happened to fail the very moment I hooked up the pre (not likely and I'm not a believer in coincidences but I will check it anyways just for S's&G'ls).
    Just kind of overall bummed about the whole deal at the moment, TBT.
    No tubes.
