If you were looking for a new Amp, and Receiver,
Toolfan66
Toolfan66 Posts: 16,929
edited January 2020 in Electronics
What would you buy, and why????
  • joecoulson
    joecoulson Posts: 4,943
    Marantz because I have had the best luck with them (at discounted prices)
    Something class D for amps. I am a fan.
  • BlueFox
    BlueFox Posts: 15,251
    For an amp I would stick with Pass. Not sure who to pick for a receiver, although they would have to offer a tuner/preamp model to get my attention. Currently I have an Onkyo SC5509 pre, and, while old, works and sounds great.
    Viking64 Posts: 6,696
    A Parasound Halo JC 5 because I want one.
    No receiver whatsoever because I DON'T want one.
  • rooftop59
    rooftop59 Posts: 7,981
    I sorry larry: but that for??? 2.1 or more? 5.1 or atmos? Makes a diff!?!
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    It’s for HT, yes Atmos 7-2-2
  • Thorton
    Thorton Posts: 1,324
    Marantz. Audyssey XT32 with the new app works and sounds great. Easy to set-up and adjust. I would not go lower than XT32. A bunch of different amps to choose from based on your needs (2, 3 or 7 channels). For HT, I'd get a Nord or Wyred 4 Sound amp.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • halen
    halen Posts: 677
    I have both the Pioneer Elite SC99 and Marantz 7010. Completely happy with them. I would not buy any new versions and do not care for them.
    So if I did not have anything at the moment I would buy the model before or before that.
    As for amps. I am into low wattage tube amps and speakers so can’t comment there. If I had to choose, it would be Unison Research.
    Cheers.
    nooshinjohn Posts: 25,103
    Arcam AVR550 for the receiver. Best in the game IMHO, and a set of Raven 350 for the amplifiers... easily among the great tube amps of all time.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Viking64 wrote: »
    Well, that would be a terrible system, with an amp and no pre...
    Play by the rules, dude...
    mdaudioguy wrote: »
    Viking64 wrote: »
    I said I didn't want a receiver. That still leaves me open to a pre-amp or an integrated amp.
    Stop trolling.
  • mantis
    mantis Posts: 17,057
    I'd probably been considering the Denon AVR6500H. I would want to do a VS with my current Sony STRZA500ES which is a pretty fine receiver. I also really like the Integra DRX R1.1. It's a beast and after Calibrating 2 of them I'm very impressed.
    Amp wise depending on use. For theater use external amps are nice when if you need them. Depending on the room and speakers I would decide if this is something that is needed or not. 2 channel amps there are so many used options. I'd probably look for a used B&K 200.2 and for a multichannel I'd try to grab a B&K 200.7.
    Buying new amps I'm not sure what I would buy. I'd probably start checking out the new offerings from Monoprice, Emotiva, Outlaw etc as I never got to demo them. Bryston are probably the best overall amps on the market dollar for dollar but they don't offer a 5 or 7 channel model so you left with a stack of 2 and 3 channel amps.
    Parasound and NAD are good choices.
    Dan
  • BlueBirdMusic
    I would look at Marantz Preamp/Processor and one of the Marantz multi-channel amps. Made for HT.
    Harry / Marietta GA
  • mdaudioguy
    Viking64 wrote: »
    mdaudioguy wrote: »
    Viking64 wrote: »
    Stop trolling.
    Not trolling... just wanting to read about real solutions. What pre-amp? I'm pretty sure he's looking for multi-channel options.
    mdaudioguy wrote: »
    His initial post asked: "What would YOU buy?"
    All information regarding what Larry's plans were came after my comment.
    If he was asking my opinion as to what he should buy, I would still say to get something without an AM/FM tuner.
    Here, I'll start over again so no more feelings are hurt:
    "A Parasound Halo JC 5 because I want one."
  • mdaudioguy
    Toolfan66 wrote: »
    Tough question... For me, it would depend on the speakers I intended to use, in order to determine needed power, unless money is no object... The Marantz (and Yamaha) pre-pro and multi-channel amp options are intriguing, but I'd probably stick with a nice receiver to handle at least some of the surround/Atmos speakers, if not all of them, paired with an amp to help drive the front soundstage. The higher-end options from Denon, Marantz, and Yamaha are most intriguing to me. I'll let others make the amp recommendations.
  • motorhead43026
    Anything Anthem.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • halo
    halo Posts: 5,616
    Within my current budget, I'd be hard-pressed to find anything better than the Denon PMA-600NE. It checks off all the boxes for me and it got some very good reviews from Steve Guttenberg and Sean at Zero Fidelity. I wouldn't mind the newer version of the NAD C 316BEE V2 but that's more $$$ than the Denon.
  • mdaudioguy
    Viking64 wrote: »
    mdaudioguy wrote: »
    Fortunately, my feelings regenerate at twice the speed of a normal man's.
    Also, fortunately, they weren't ever hurt to begin with...
  • rpf65
    rpf65 Posts: 2,127
    I would get either a Yamaha 20xx or Marantz 70xx series AVR. I like the sound of both manufacturers, and since you only need 9 channels, I would save a little and not get the 11 channel units.
    The calibration programs are better on the flagship units, but I just don’t think it’s worth the extra money. Anthem would be a good choice, but just shy of $4k, out of my price range.
    If it were strictly a HT system, would probably look at something from Outlaw Audio for a 5 or 7 channel amp. Don’t see any problem with an AVR handling the rears and height speakers. If duel purpose I would hold out for a Parasound A 51. Think it would work better for music than the Outlaw.
  • jeremymarcinko
  • joecoulson
    Anything Anthem.
    The one brand in this arena that I would like to try.
  • Joey_V
    Joey_V Posts: 8,521
    Hmm
    Depends on budget
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • gp4jesus
    gp4jesus Posts: 1,969
    edited January 2020
    New new? Undecided
    Or just new to my house? 3 more Rotel RB-981s
    Poor ma-aybe... can I have all the parts & test equipment to build a special pair of 5 channel amps?!
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • mrloren
    mrloren Posts: 2,454
    New amp and AVR.
    Hmm, Marantz SR8012 and Parasound A31 or A51
  • joecoulson
    That’s a nice combo^
  • mrloren
    joecoulson wrote: »
    Yeah, if only I had the funds
  • mrbiron
    mrbiron Posts: 5,711
    Anything Anthem.
    I may be a bit biased owning 3 pieces of anthem in the past, but that is where I would start. Not to say they are the be-all-end-all, that that would be my starting point.
    Their Pre’s are considered high(er) end and I would match them with a PVA or MC amp to round it out. Get ready to spend some coin.
  • afterburnt
    afterburnt Posts: 7,892
    RX-A2030 and an A-31 I know someone that runs those and he likes em.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2020
    Marantz AV8805
    Sunfire TGA 7401
    Parasound A21+ for Mains.
    Garage | Polk Monitor 5B's
    gudnoyez Posts: 8,068
    edited January 2020
    I would go with that Marantz AV8805 if your not needing the 7 channels that Sunfire provides. I would go with a Parasound A31 along with a A21, but I'm a Parasound fanboy but a yeah that combo should do it.
