If you were looking for a new Amp, and Receiver,
Toolfan66
Toolfan66 Posts: 18,053
edited January 2020 in Electronics
What would you buy, and why????
  • joecoulson
    joecoulson Posts: 4,943
    Marantz because I have had the best luck with them (at discounted prices)
    Something class D for amps. I am a fan.
  • BlueFox
    BlueFox Posts: 15,251
    For an amp I would stick with Pass. Not sure who to pick for a receiver, although they would have to offer a tuner/preamp model to get my attention. Currently I have an Onkyo SC5509 pre, and, while old, works and sounds great.
    Viking64 Posts: 7,550
    A Parasound Halo JC 5 because I want one.
    No receiver whatsoever because I DON'T want one.
  • rooftop59
    rooftop59 Posts: 8,121
    I sorry larry: but that for??? 2.1 or more? 5.1 or atmos? Makes a diff!?!
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    It’s for HT, yes Atmos 7-2-2
  • Thorton
    Thorton Posts: 1,324
    Marantz. Audyssey XT32 with the new app works and sounds great. Easy to set-up and adjust. I would not go lower than XT32. A bunch of different amps to choose from based on your needs (2, 3 or 7 channels). For HT, I'd get a Nord or Wyred 4 Sound amp.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • halen
    halen Posts: 717
    I have both the Pioneer Elite SC99 and Marantz 7010. Completely happy with them. I would not buy any new versions and do not care for them.
    So if I did not have anything at the moment I would buy the model before or before that.
    As for amps. I am into low wattage tube amps and speakers so can’t comment there. If I had to choose, it would be Unison Research.
    Cheers.
    nooshinjohn Posts: 25,918
    Arcam AVR550 for the receiver. Best in the game IMHO, and a set of Raven 350 for the amplifiers... easily among the great tube amps of all time.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Viking64 wrote: »
    Well, that would be a terrible system, with an amp and no pre...
    Play by the rules, dude...
    mdaudioguy wrote: »
    Viking64 wrote: »
    I said I didn't want a receiver. That still leaves me open to a pre-amp or an integrated amp.
    Stop trolling.
  • mantis
    mantis Posts: 17,378
    I'd probably been considering the Denon AVR6500H. I would want to do a VS with my current Sony STRZA500ES which is a pretty fine receiver. I also really like the Integra DRX R1.1. It's a beast and after Calibrating 2 of them I'm very impressed.
    Amp wise depending on use. For theater use external amps are nice when if you need them. Depending on the room and speakers I would decide if this is something that is needed or not. 2 channel amps there are so many used options. I'd probably look for a used B&K 200.2 and for a multichannel I'd try to grab a B&K 200.7.
    Buying new amps I'm not sure what I would buy. I'd probably start checking out the new offerings from Monoprice, Emotiva, Outlaw etc as I never got to demo them. Bryston are probably the best overall amps on the market dollar for dollar but they don't offer a 5 or 7 channel model so you left with a stack of 2 and 3 channel amps.
    Parasound and NAD are good choices.
    Dan
  • I would look at Marantz Preamp/Processor and one of the Marantz multi-channel amps. Made for HT.
    Harry / Marietta GA
  • mdaudioguy
    Viking64 wrote: »
    mdaudioguy wrote: »
    Viking64 wrote: »
    Stop trolling.
    Not trolling... just wanting to read about real solutions. What pre-amp? I'm pretty sure he's looking for multi-channel options.
    mdaudioguy wrote: »
    His initial post asked: "What would YOU buy?"
    All information regarding what Larry's plans were came after my comment.
    If he was asking my opinion as to what he should buy, I would still say to get something without an AM/FM tuner.
    Here, I'll start over again so no more feelings are hurt:
    "A Parasound Halo JC 5 because I want one."
  • mdaudioguy
    Toolfan66 wrote: »
    Tough question... For me, it would depend on the speakers I intended to use, in order to determine needed power, unless money is no object... The Marantz (and Yamaha) pre-pro and multi-channel amp options are intriguing, but I'd probably stick with a nice receiver to handle at least some of the surround/Atmos speakers, if not all of them, paired with an amp to help drive the front soundstage. The higher-end options from Denon, Marantz, and Yamaha are most intriguing to me. I'll let others make the amp recommendations.
  • Anything Anthem.
    – Kevin Alfred Strom
  • halo
    halo Posts: 5,616
    Within my current budget, I'd be hard-pressed to find anything better than the Denon PMA-600NE. It checks off all the boxes for me and it got some very good reviews from Steve Guttenberg and Sean at Zero Fidelity. I wouldn't mind the newer version of the NAD C 316BEE V2 but that's more $$$ than the Denon.
  • mdaudioguy
    Viking64 wrote: »
    mdaudioguy wrote: »
    Fortunately, my feelings regenerate at twice the speed of a normal man's.
    Also, fortunately, they weren't ever hurt to begin with...
  • rpf65
    rpf65 Posts: 2,127
    I would get either a Yamaha 20xx or Marantz 70xx series AVR. I like the sound of both manufacturers, and since you only need 9 channels, I would save a little and not get the 11 channel units.
    The calibration programs are better on the flagship units, but I just don’t think it’s worth the extra money. Anthem would be a good choice, but just shy of $4k, out of my price range.
    If it were strictly a HT system, would probably look at something from Outlaw Audio for a 5 or 7 channel amp. Don’t see any problem with an AVR handling the rears and height speakers. If duel purpose I would hold out for a Parasound A 51. Think it would work better for music than the Outlaw.
  • Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
  • joecoulson
    Anything Anthem.
    The one brand in this arena that I would like to try.
  • Joey_V
    Joey_V Posts: 8,600
    Hmm
    Depends on budget
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2020
    New new? Undecided
    Or just new to my house? 3 more Rotel RB-981s
    Poor ma-aybe... can I have all the parts & test equipment to build a special pair of 5 channel amps?!
    *all connected w/Premiere ICs
  • mrloren
    mrloren Posts: 2,474
    New amp and AVR.
    Hmm, Marantz SR8012 and Parasound A31 or A51
  • joecoulson
    That’s a nice combo^
  • mrloren
    joecoulson wrote: »
    Yeah, if only I had the funds
  • mrbiron
    mrbiron Posts: 5,721
    Anything Anthem.
    I may be a bit biased owning 3 pieces of anthem in the past, but that is where I would start. Not to say they are the be-all-end-all, that that would be my starting point.
    Their Pre’s are considered high(er) end and I would match them with a PVA or MC amp to round it out. Get ready to spend some coin.
  • afterburnt
    afterburnt Posts: 7,892
    RX-A2030 and an A-31 I know someone that runs those and he likes em.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2020
    Marantz AV8805
    Sunfire TGA 7401
    Parasound A21+ for Mains.
    Garage | Polk Monitor 5B's
    gudnoyez Posts: 8,161
    edited January 2020
    I would go with that Marantz AV8805 if your not needing the 7 channels that Sunfire provides. I would go with a Parasound A31 along with a A21, but I'm a Parasound fanboy but a yeah that combo should do it.
