If you were looking for a new Amp, and Receiver,
Toolfan66
Marantz because I have had the best luck with them (at discounted prices)
Something class D for amps. I am a fan. -
For an amp I would stick with Pass. Not sure who to pick for a receiver, although they would have to offer a tuner/preamp model to get my attention. Currently I have an Onkyo SC5509 pre, and, while old, works and sounds great.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
A Parasound Halo JC 5 because I want one.
No receiver whatsoever because I DON'T want one. -
I sorry larry: but that for??? 2.1 or more? 5.1 or atmos? Makes a diff!?!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
It’s for HT, yes Atmos 7-2-2
Marantz. Audyssey XT32 with the new app works and sounds great. Easy to set-up and adjust. I would not go lower than XT32. A bunch of different amps to choose from based on your needs (2, 3 or 7 channels). For HT, I'd get a Nord or Wyred 4 Sound amp._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I have both the Pioneer Elite SC99 and Marantz 7010. Completely happy with them. I would not buy any new versions and do not care for them.
So if I did not have anything at the moment I would buy the model before or before that.
As for amps. I am into low wattage tube amps and speakers so can’t comment there. If I had to choose, it would be Unison Research.
Cheers. -
Arcam AVR550 for the receiver. Best in the game IMHO, and a set of Raven 350 for the amplifiers... easily among the great tube amps of all time.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Well, that would be a terrible system, with an amp and no pre...
Play by the rules, dude... -
mdaudioguy wrote: »
I said I didn't want a receiver. That still leaves me open to a pre-amp or an integrated amp.
Stop trolling. -
I'd probably been considering the Denon AVR6500H. I would want to do a VS with my current Sony STRZA500ES which is a pretty fine receiver. I also really like the Integra DRX R1.1. It's a beast and after Calibrating 2 of them I'm very impressed.
Amp wise depending on use. For theater use external amps are nice when if you need them. Depending on the room and speakers I would decide if this is something that is needed or not. 2 channel amps there are so many used options. I'd probably look for a used B&K 200.2 and for a multichannel I'd try to grab a B&K 200.7.
Buying new amps I'm not sure what I would buy. I'd probably start checking out the new offerings from Monoprice, Emotiva, Outlaw etc as I never got to demo them. Bryston are probably the best overall amps on the market dollar for dollar but they don't offer a 5 or 7 channel model so you left with a stack of 2 and 3 channel amps.
Parasound and NAD are good choices.Dan
I would look at Marantz Preamp/Processor and one of the Marantz multi-channel amps. Made for HT."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
mdaudioguy wrote: »
Stop trolling.
Not trolling... just wanting to read about real solutions. What pre-amp? I'm pretty sure he's looking for multi-channel options. -
mdaudioguy wrote: »Not trolling... just wanting to read about real solutions. What pre-amp? I'm pretty sure he's looking for multi-channel options.
His initial post asked: "What would YOU buy?"
All information regarding what Larry's plans were came after my comment.
If he was asking my opinion as to what he should buy, I would still say to get something without an AM/FM tuner.
Here, I'll start over again so no more feelings are hurt:
"A Parasound Halo JC 5 because I want one." -
Tough question... For me, it would depend on the speakers I intended to use, in order to determine needed power, unless money is no object... The Marantz (and Yamaha) pre-pro and multi-channel amp options are intriguing, but I'd probably stick with a nice receiver to handle at least some of the surround/Atmos speakers, if not all of them, paired with an amp to help drive the front soundstage. The higher-end options from Denon, Marantz, and Yamaha are most intriguing to me. I'll let others make the amp recommendations.What would you buy, and why???? -
Anything Anthem.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
Within my current budget, I'd be hard-pressed to find anything better than the Denon PMA-600NE. It checks off all the boxes for me and it got some very good reviews from Steve Guttenberg and Sean at Zero Fidelity. I wouldn't mind the newer version of the NAD C 316BEE V2 but that's more $$$ than the Denon.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Fortunately, my feelings regenerate at twice the speed of a normal man's.mdaudioguy wrote: »Not trolling... just wanting to read about real solutions. What pre-amp? I'm pretty sure he's looking for multi-channel options.
Also, fortunately, they weren't ever hurt to begin with... -
I would get either a Yamaha 20xx or Marantz 70xx series AVR. I like the sound of both manufacturers, and since you only need 9 channels, I would save a little and not get the 11 channel units.
The calibration programs are better on the flagship units, but I just don’t think it’s worth the extra money. Anthem would be a good choice, but just shy of $4k, out of my price range.
If it were strictly a HT system, would probably look at something from Outlaw Audio for a 5 or 7 channel amp. Don’t see any problem with an AVR handling the rears and height speakers. If duel purpose I would hold out for a Parasound A 51. Think it would work better for music than the Outlaw. -
These two...easy choice for me.
http://www.outlawaudio.com/products/976.html
http://www.outlawaudio.com/products/7000x.htmlOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
motorhead43026 wrote: »Anything Anthem.
The one brand in this arena that I would like to try. -
Hmm
Depends on budgetMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
New new? Undecided
Or just new to my house? 3 more Rotel RB-981s
Poor ma-aybe... can I have all the parts & test equipment to build a special pair of 5 channel amps?!Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
New amp and AVR.
Hmm, Marantz SR8012 and Parasound A31 or A51When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
That’s a nice combo^
joecoulson wrote: »That’s a nice combo^
Yeah, if only I had the fundsWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
I may be a bit biased owning 3 pieces of anthem in the past, but that is where I would start. Not to say they are the be-all-end-all, that that would be my starting point.
Their Pre’s are considered high(er) end and I would match them with a PVA or MC amp to round it out. Get ready to spend some coin.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
RX-A2030 and an A-31 I know someone that runs those and he likes em.
Marantz AV8805
Sunfire TGA 7401
Parasound A21+ for Mains.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I would go with that Marantz AV8805 if your not needing the 7 channels that Sunfire provides. I would go with a Parasound A31 along with a A21, but I'm a Parasound fanboy but a yeah that combo should do it.Home Theater
