Direct Electrical Line Question
I've decided to get a direct electrical line installed between our breaker box and my gear before setting up a pair of Klaus's Odyssey monoblocks. Is there a thread around with some basic information about that to provide my electrician?
Or can anyone give me a quick list of DO vs. DO IF YOU CAN AFFORD IT vs. DON'T DO ?
Thanks, everyone.
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
  • stretchl
    stretchl Posts: 1,334
    Thanks, Ken.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • gp4jesus
    gp4jesus Posts: 1,969
    edited December 2019
    Machone is an example of Lightman’s work
    Not familiar w/the brand/model but perhaps 2 or 3 would be worth the trouble
    Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • lightman1
    lightman1 Posts: 10,776
  • GlennDog
    GlennDog Posts: 3,085
    lightman1 wrote: »
    PM sent
    I’d be interested in your insight too!
    Mind making it public?
    Thanks Russ 😉
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    pitdogg2 Posts: 24,556
    Due to codes and Russ's electrician's license it might put some liability on him to put in public. Some knucklehead can say hey look I found this on such and such in this guy's the one that said it.
    Just thinking out loud here
    treitz3 Posts: 18,316
    Naw, that ain't it. I think Russ just wanted to hit on one last person before he got hitched. Even though the sheep may be public, he does like privacy in certain areas.
  • GlennDog
    True
    But then half the Internet should be shut down 😂
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • lightman1
    GlennDog wrote: »
    lightman1 wrote: »
    PM sent
    Thanks Russ 😉
    No worries G-dog....
    Just waaaayyyy too many variables to just toss out "Yup! Run three dedicated 20A runs. Piece of cake."
    Panel size, location of gear etc....
    Didn't want to write an encyclopedia.
    Bite my arse, Tom
    Dude, I said that as a compliment. What gives?
    LOL
  • gp4jesus
    BTW @Stretchl, where do you live?
    Merry Christmas! Tony
  • stretchl
    Tony, I'm in Champaign, IL. You're up in Chicago, right? Or is it Indy? Or none of the above? And Merry Christmas to you, too! :smile:
    - Isaac Asimov
    Hi-Fi
    Visuals
  • gp4jesus
    Sorry. North Georgia
  • gp4jesus
    I just finished reading several articles on your prospective Odyssey purchases and must suggest, no recommend 4 dedicated feeds:
    One each for the monos
    One for any other higher-draw gear (eg AVR and/or other power amps)
    The last to a power conditioner for the low powered stuff (eg preamp, pre/pro, TV, Blu-ray)
    Meanwhile Merry Christmas!
  • afterburnt
    afterburnt Posts: 7,892
    @stretchl would you mind sharing the resuts with the class when yo get it done?
  • kharp1
    kharp1 Posts: 3,453
    afterburnt wrote: »
    Is that like the math test where you must show your work? I hated those.
  • stretchl
    Absolutely will do @afterburnt
    - Isaac Asimov
    Hi-Fi
    Visuals
  • lightman1
    gp4jesus wrote: »
    I like your style, Tony.... ;)
    Viking64 Posts: 6,679
    lightman1 wrote: »
    Complimenting another member's swimwear attire is too personal and wholly inappropriate.
    On a serious note, I too agree with the 4 20A circuits for the reasons stated above. If you are going to go through the trouble of running 3 20A circuits, (2 for monoblocks) and then you end up "clogging up" the 3rd with EVERYTHING ELSE, it seems a shame to not have just ran one more to help balance out the 3rd circuit.
  • lightman1
    I'm sure that Tony is a handsome chap in his own right...
    Viking64 wrote: »
    lightman1 wrote: »
    lightman1 wrote: »
    Chaps? I don't like where this is going, Russ. :o
  • gp4jesus
    lightman1 wrote: »
    gp4jesus wrote: »
    Thanks😊! What I’d do in his place. Further, my existing config: 3 20As - wish I ran 4. Will run 5 or 6** from a dedicated panel when I move my system into what used to be a garage.
    **20As & 30As
    Stretchl - my best to your choices.
    Merry Christmas everyone! Tony
  • machone
    machone Posts: 1,473
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • gp4jesus
    lightman1 wrote: »
    I'm sure that Tony is a handsome* chap in his own right...
    Well if that* refers to my heart - thanks! I’d like to think that’s where my advice comes from.
    lightman1 wrote: »
    Again thanks! To be honest I think the credit does not belong to me.
    Merry Christmas, Lk Ch 2. Tony
  • gp4jesus
    machone wrote: »
    In my humble opinion your power setup has set the standard
  • stretchl
    Good stuff @machone Im going to send this to my electrician.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Manticore
    Manticore Posts: 408
    When i did the upgrade i ran two 20 amp lines. Was very worth it especially using multiple amps. In hindsight i should have ran 4. Best of luck!
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • machone
    gp4jesus wrote: »
    machone wrote: »
    Thank you
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • stretchl
    Here’s the estimate, guys. @lightman1 what do u think?
    - Isaac Asimov
    Hi-Fi
    Visuals
