Direct Electrical Line Question
stretchl
I've decided to get a direct electrical line installed between our breaker box and my gear before setting up a pair of Klaus's Odyssey monoblocks. Is there a thread around with some basic information about that to provide my electrician?
Or can anyone give me a quick list of DO vs. DO IF YOU CAN AFFORD IT vs. DON'T DO ?
Thanks, everyone.
Thanks, everyone.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Thanks, Ken.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Machone is an example of Lightman’s work
Not familiar w/the brand/model but perhaps 2 or 3 would be worth the trouble
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
PM sent
PM sent
I’d be interested in your insight too!
Mind making it public?
Thanks Russ 😉AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Due to codes and Russ's electrician's license it might put some liability on him to put in public. Some knucklehead can say hey look I found this on such and such in this guy's the one that said it.
Just thinking out loud here -
Naw, that ain't it. I think Russ just wanted to hit on one last person before he got hitched. Even though the sheep may be public, he does like privacy in certain areas.
True
But then half the Internet should be shut down 😂AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
No worries G-dog....
Just waaaayyyy too many variables to just toss out "Yup! Run three dedicated 20A runs. Piece of cake."
Panel size, location of gear etc....
Didn't want to write an encyclopedia.
Bite my arse, Tom -
Dude, I said that as a compliment. What gives?
LOL
Tony, I'm in Champaign, IL. You're up in Chicago, right? Or is it Indy? Or none of the above? And Merry Christmas to you, too!
- Isaac Asimov
Hi-Fi
Visuals
Sorry. North GeorgiaSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
I just finished reading several articles on your prospective Odyssey purchases and must suggest, no recommend 4 dedicated feeds:
One each for the monos
One for any other higher-draw gear (eg AVR and/or other power amps)
The last to a power conditioner for the low powered stuff (eg preamp, pre/pro, TV, Blu-ray)
Meanwhile Merry Christmas!Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
@stretchl would you mind sharing the resuts with the class when yo get it done?
afterburnt wrote: »@stretchl would you mind sharing the resuts with the class when yo get it done?
Is that like the math test where you must show your work? I hated those. -
Absolutely will do @afterburnt“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
I like your style, Tony....
Complimenting another member's swimwear attire is too personal and wholly inappropriate. -
On a serious note, I too agree with the 4 20A circuits for the reasons stated above. If you are going to go through the trouble of running 3 20A circuits, (2 for monoblocks) and then you end up "clogging up" the 3rd with EVERYTHING ELSE, it seems a shame to not have just ran one more to help balance out the 3rd circuit.
I'm sure that Tony is a handsome chap in his own right...
Chaps? I don't like where this is going, Russ.
Thanks😊! What I’d do in his place. Further, my existing config: 3 20As - wish I ran 4. Will run 5 or 6** from a dedicated panel when I move my system into what used to be a garage.I just finished reading several articles on your prospective Odyssey purchases and must suggest, no recommend 4 dedicated feeds:
**20As & 30As
Stretchl - my best to your choices.
Merry Christmas everyone! Tony
Here is a link to my dedicated circuits.
https://forum.polkaudio.com/discussion/176812/power-circuit-upgrade#latestMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Well if that* refers to my heart - thanks! I’d like to think that’s where my advice comes from.I'm sure that Tony is a handsome* chap in his own right...
Again thanks! To be honest I think the credit does not belong to me.I like your style, Tony....
Merry Christmas, Lk Ch 2. TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
In my humble opinion your power setup has set the standardHere is a link to my dedicated circuits.
Good stuff @machone Im going to send this to my electrician.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
When i did the upgrade i ran two 20 amp lines. Was very worth it especially using multiple amps. In hindsight i should have ran 4. Best of luck!Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Thank youMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
- Isaac Asimov
Hi-Fi
Visuals
