Protecting speakers from cats
Hi all, just a a small kitty as a present to my kids. I do like cats but I am predicting that it will go after my floor-standing speaker grilles and claw it at some point.
I just wondering if any of you could share your experience and have a good recipe to deter them, any answers or tips will be appreciated beyond the obvious shock the cat or get rid of it, etc...
  • BlueFox
    BlueFox Posts: 15,250
    I have four cats, and they don’t bother the speakers. Other than screaming at them if they appeared to be looking at the speakers I didn’t do anything.
  • OleBoot
    OleBoot Posts: 3,135
    edited December 2019
    We've had a constant succession of cats, and none of them seemed to be interested in the speakers either. We did have one cat, however, that would sit in front of them when music was playing and rock gently from side to side !
    EDIT: But beware of keyboards
    Post edited by OleBoot on
  • oldrocker
    oldrocker Posts: 2,590
    BlueFox wrote: »
    I can relate to that with Hazel... :D
  • halo
    halo Posts: 5,618
    I have had issues with the 2 cats here. One toppled a bookshelf speaker and I had to replace a dimpled tweeter. Another jumped to the top of 2 different floorstanding speakers, didn't quite make it all the way to the top, and dug their back claws into the drivers for purchase, ruining 2 midrange drivers on each respective speaker.
    The easiest fix was to figure out why the cats were jumping up there in the first place which was to get to the top of a bookshelf next to the speakers (some cats like to be high up!). Moving the speakers away from the bookshelves helped but I also got some scratching posts on the floor right in front of the speakers to keep them, and their claws, grounded. The scratching posts on the floor did the trick for me.
    https://chewy.com/smartcat-bootsies-combination/dp/49130
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • maxward
    maxward Posts: 1,710
    We’ve been similarly lucky. Our current cat is too old to bother, but over time, none of the four cats we owned (and one guest cat) went after my Magnepans. The guest did tear up my DIY sound absorbing panels.
    Clipdat Posts: 13,100
    If they show an interest in the speakers, just put one of these next to the speakers and they will use it instead: https://www.amazon.com/4CLAWS-Wall-Mounted-Scratching-White/dp/B015Y4HVTO/
    Worked for me when my cat scratched on my vinyl collection a few times. Put this next to it and now he always uses this.
  • halo
    halo Posts: 5,618
    Clipdat wrote: »
    Agreed! The scratching post that I linked to above can also be mounted on the wall :)
    pitdogg2 Posts: 27,203
    I had to put double thick cardboard sheets that covered the front of my sda1 signature with velcro that went all the way around to attached to the back of the speaker.
  • verb
    verb Posts: 10,176
    I love cats, grew up with them, but the Mrs is kinda allergic to em. Problem solved.
    Now I did catch Walter mark his territory on some floor standers at the old house, but that would be a different thread. :smile:
  • marvda1
    marvda1 Posts: 4,958
    get a gal milk jug, put some pennies in it and when the cat even goes near the speakers shake the jug and scare the h3ll out of it :D
    Puritan PSM156
    marvda1 wrote: »
    If you never leave the house Marvin that may work..... or a red rider
  • delkal
    delkal Posts: 764
    Get a recording of dogs barking, introduce your new cat to the speakers, then crank it up while they are sniffing them. You shouldn't have a problem after that.
  • boston1450
    boston1450 Posts: 7,758
    When we had Buddy Fat Cat he got close to the grills one day. I took it off & chased him with it. Then, if he entered the room & even looked at the speakers I would point at the grills & he would haul a$$. Never a issue after that. He would sit there & listen to music for hours. Buddy is sadly missed RIP
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    Viking64 Posts: 7,604
    Post signs on the grilles that say the Latin equivalent of "Keepa You Hands Off!".
  • skrol
    skrol Posts: 3,456
    I have 4 cats that rarely bother my speakers. However, I do use either a cat deterrent spray on the carpet around the speakers and dried rosemary wrapped in a thin cloth or tissue and placed behind the grill. I used the dried rosemary because I didn't want to spray anything on the grills that might discolor or stain.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • DaveHo
    DaveHo Posts: 3,582
    Bookies on stands plus something on top of them to deter the cat from jumping up. Currently using 703's with a pair of stuffed teddy bears perched on top. Seems to be working. My 705s haven't seen the light of day in almost a year. :'(
  • DaveHo
    DaveHo Posts: 3,582
    skrol wrote: »
    ... However, I do use either a cat deterrent spray on the carpet around the speakers...
    Link? I've heard of home remedies using vinegar, but I really don't want the place to smell like it.
  • Just a dude doing dude-ly things
  • halo
    halo Posts: 5,618
    marvda1 wrote: »
    I think that's more of tactic for dogs
  • pawelmwo
    pawelmwo Posts: 137
    So the best bet is to fill your house with scratching posts. They are fairly cheap and easy to replace. Other than that, cats hate sticky things. What I do every now and then is get some clear packing tape and roll it so all edges are sticky. Then I place a few strips around where the cats would normally scratch or try to mark the territory by drooling all over it giving it 'bumps'. Then they hit that sticky piece they avoid it and after a while it gets programmed in their brains to avoid it.
  • jdjohn
    jdjohn Posts: 3,377
    Is de-clawing said cat(s) not an option? Too cruel???
    jdjohn wrote: »
    It's incredibly inhumane.
  • BlueFox
    Yes. I composed a rant reply to the de-claw comment, but deleted it.
  • I put upside down car floor mats around the speakers
  • shs
    shs Posts: 105
    The problem I had was a cat peeing on a subwoofer, amplifier and other equipment. A pet shock pad (seemed to solve the problem at the subwoofer and now all my equipment is inside a closed cabinet. I have also had a dog scratch the driver on my center channel speaker as he goes crazy when a dog or other animal appear on the screen. Now days I use a grill as they are replaceable.
    Pet shock pad I used: https://www.amazon.com/gp/product/B07CTNRPD9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
    shs wrote: »
    Maybe something like this might work for @afterburnt's wife? Good Christmas gift idea here.
  • jdjohn
    jdjohn Posts: 3,377
    Some might argue that keeping cats (only) inside is inhumane.
    audioluvr Posts: 5,982
    Oops! Posted in the wrong section.
