FR1 subwoofer won't work
I just bought the Polk Audio FR1 soundbar and subwoofer. Got the Soundbar hooked up and working with no problem but can't get the subwoofer to connect. Please help if anyone can.
  • KennethSwaugerKennethSwauger Moderator Posts: 7,164
    I'll forward this to Polk's CS guys.
    "They thought we were too loud, but shoot, I had four army blankets folded over my amp, and the volume level was on 2. I'm used to playin' on 10!" S.R.V.
    Here's their response:
    "The first thing I would find out is if the customer has the wireless dongle that plugs into the back of the bar? If they don’t have that, then the subwoofer will not connect."
    Regards, Ken
  • Yes I have the wireless dongle. I have it plugged into the back of the Soundbar. It seems like it's not getting any power. When I push and hold the sync button no lights come on. I've tried calling customer service twice today and was on hold over 30 minutes both times and never got to speak with anyone. Not sure what to do now...
    I'll give this information to them.
    It would be best to send an email to: [email protected] and explain you are the person I've been working with. He will need the serial number from your soundbar and will, probably, send a replacement dongle, since that seems to be the center of the problem.
  • Hello I have the same problem whit my transmitter how can get a new one or get a replacement?
  • rd2018rd2018 Posts: 1
    Have an FR1 Soundbar & Sub Woofer that I bought from Dish Network about a year & a half ago. It suddenly will not power on. The Sub Woofer is showing a flashing green light
  • basilbasil Posts: 1
    Where can I buy the wireless dongle for fr1
  • lbertlbert Posts: 1
    I have a Polk FR1 that I bought from Dish Network, everything worked fine but recently I noticed there's very little bass and the subwoofer wasn't working and now I can't get the wireless subwoofer to work. I've following the pairing instructions and I get the rapid flashing green light on the dongle but not light at all when I power up the subwoofer. Is there something else that I can do?
  • honwinghonwing Posts: 1
    Subwoofer status light will not turn on. sound bar green light keeps flashing. Purchased from Dish and sounds like the same problem as Ibert
  • I have the same problem flashing light on Soundbar but it won't sync to subwoofer
  • rooftop59rooftop59 Posts: 6,710
    edited December 2019
    wow that is some clever spam right there...reported!
    Living Room 2.1: Dynaudio Contour 1.3mkii; Martin Logan Grotto sub; Musical Fidelity A308; Cambridge Azur 851N
    Game Room HT: Denon AVR-X4200w; Definitive Technology SM450; Definitive Technology LCR2000; Definitive Technology Procinema 800; Mirage Nanasats; Sub - HSU VTF-2 MK5
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology StudioMonitor350; ACI Titan Subwoofer; Squeezebox Touch
  • PixieLaughPixieLaugh Posts: 1
    Same issue here. Bought FR1 via Dish 3 years ago and the subwoofer just died. Can't find a replacement.
  • pmh6868pmh6868 Posts: 1
    Sub woofer died. Got new cords for both sound bar and subwoofer......did not help. Set up says to sync with soundbar sync button.....NO SUCH BUTTON ON MY SOUND BAR. Tried sync with dongle but ....NOTHING. help, HELP, H E L P!
    It would be best to contact Polk at: 1-800-377-7655 and follow prompts for soundbar help. Have the serial number handy when you call.
Howdy, Stranger!
