FR1 subwoofer won't work
I just bought the Polk Audio FR1 soundbar and subwoofer. Got the Soundbar hooked up and working with no problem but can't get the subwoofer to connect. Please help if anyone can.
  • I'll forward this to Polk's CS guys.
  • Thank you
  • Here's their response:
    "The first thing I would find out is if the customer has the wireless dongle that plugs into the back of the bar? If they don’t have that, then the subwoofer will not connect."
    Regards, Ken
  • Yes I have the wireless dongle. I have it plugged into the back of the Soundbar. It seems like it's not getting any power. When I push and hold the sync button no lights come on. I've tried calling customer service twice today and was on hold over 30 minutes both times and never got to speak with anyone. Not sure what to do now...
  • I'll give this information to them.
  • It would be best to send an email to: Ken.Carter@soundunited and explain you are the person I've been working with. He will need the serial number from your soundbar and will, probably, send a replacement dongle, since that seems to be the center of the problem.
  • Hello I have the same problem whit my transmitter how can get a new one or get a replacement?
  • rd2018
    Have an FR1 Soundbar & Sub Woofer that I bought from Dish Network about a year & a half ago. It suddenly will not power on. The Sub Woofer is showing a flashing green light
  • Where can I buy the wireless dongle for fr1
  • lbert
    I have a Polk FR1 that I bought from Dish Network, everything worked fine but recently I noticed there's very little bass and the subwoofer wasn't working and now I can't get the wireless subwoofer to work. I've following the pairing instructions and I get the rapid flashing green light on the dongle but not light at all when I power up the subwoofer. Is there something else that I can do?
  • Subwoofer status light will not turn on. sound bar green light keeps flashing. Purchased from Dish and sounds like the same problem as Ibert
  • I have the same problem flashing light on Soundbar but it won't sync to subwoofer
  • rooftop59
    edited December 2019
    wow that is some clever spam right there...reported!
    Game Room 5.1.4:
    Bedroom 2.1
  • Same issue here. Bought FR1 via Dish 3 years ago and the subwoofer just died. Can't find a replacement.
  • Sub woofer died. Got new cords for both sound bar and subwoofer......did not help. Set up says to sync with soundbar sync button.....NO SUCH BUTTON ON MY SOUND BAR. Tried sync with dongle but ....NOTHING. help, HELP, H E L P!
  • It would be best to contact Polk at: 1-800-377-7655 and follow prompts for soundbar help. Have the serial number handy when you call.
