Does anyone build a decent soundbar?
steveinaz
steveinaz Posts: 19,546
edited October 2019 in Speakers
Looking for recommendations for 2 or 2.1 soundbar system at or under $300. Seems like looking at reviews on a number of different brands----LOTS of problems.
I was looking at Yamaha's offerings. Don't need anything earth shaking, don't need 10 million features and/or Alexa. Just a good/solid 2 channel soundbar that doesn't die in 14 months.
    Good question....the hard part may be "doesn't die in 14 months".
    An alternative could be a slim line receiver and some small bookies. Like a Marantz slim line and a pair of small Elac's.
  • tratliff
    tratliff Posts: 1,820
    I think the biggest problem you will encounter is the budget.
  • joecoulson
    joecoulson Posts: 4,943
    Only soundbar that I think is worth the coin is the Sonos, although it’s not $300.
  • motorhead43026
    motorhead43026 Posts: 4,040
    edited October 2019
    I bought 3 Polk Magnifi Mini 3-4 years ago. Never have I had a problem with either and 2 of these get daily use several hrs a day, all day on most weekends.
    Should be right in your price range.
  • steveinaz
    It amazes me that I have a pair of self-powered computer speakers (JBL) that were $29 bucks, and are now 19+ years old---and still work, but I can't find a damn $200+ dollar soundbar that doesn't die in under 2 years. Frustrating.
  • jdjohn
    jdjohn Posts: 3,402
    I've had my Samsung for years with no problems. It's nothing special, but maybe that's why it has lasted so long. It's a 2.1 with a small passive sub included.
    mhardy6647 Posts: 35,326
    emphases added
    I mean --- I am bad at math, but there's something funny about this endorsement?! B)
    so -- what of the third one, dare I ask?
  • rooftop59
    rooftop59 Posts: 8,120
    edited October 2019
    I would just buy these: https://www.ebay.com/itm/PSB-Alpha-PS-1-Powered-Speakers-Computer-Speakers-Studio-Monitors-PAIR/292035042856
    sub out included: add a small sub at less than $200 and you’ll be really close to budget and have true stereo sound and far better sound quality. Does lack a dac you can pick up a very decent one for cheap these days...
    Post edited by rooftop59 on
    Game Room 5.1.4:
    Bedroom 2.1
  • motorhead43026
    edited October 2019
    emphases added
    My girlfriend owns #3, no problems with it.
    I should have said neither have been a problem.
  • steveinaz
    edited October 2019
    I'm gonna try the Yamaha YAS-108.
    https://www.amazon.com/gp/product/B07D73HMVR/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    My TV audio is already routed thru the Main rig via Toslink, so I just needed an upgrade to the almost non-existent sound coming from the Vizio P65-F1 when I don't want the big setup on.
  • WagnerRC
    WagnerRC Posts: 2,215
    I bought my son the Yamaha that Costco offered. It sounded great. Yamaha is a great choice
  • WagnerRC
    Costco’s price is 149.00
  • mantis
    mantis Posts: 17,574
    Sonos is the only affordable sound bar and sub woofer on the market worth spending money on.
    Dan
    gudnoyez Posts: 8,174
    ZVOX makes a good product this ones 6 years running never an issue you can st up to a 65 inch on top. It has a 75 W amp built in and a down firing sub, also has pre outs so you can hook up a powered sub behind or off to the side for you.
    Has that sound enhancer in it you can you can hear gunshots off to the sides and behind you. Watching watching Jeff Beck live at Ronnie Scott's with it is sure a treat. Nice for a living room or bedroom this baby easily fills a good size room. We often watch movies in the bedroom instead of heading down to the HT room.
    pitdogg2 Posts: 27,456
    I too have heard good things about Zvox. I personally have not had the chance to get ears on one.
    txcoastal1 Posts: 13,519
    ZVOX is really good
  • deronb1
    deronb1 Posts: 5,021
    Get a Woodbourne. Great for TV. Good for music too.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have a Polk soundbar... An SB 5000BT... It works ok ... Have had it for 3+ years. I wish it had HDMI but it don't so use it with optical...The sub is meh....like all polk subs... I wish I could hook up an external sub but haven't taken the time to figure out if but I don't think there is any option. Maybe I can RCA out from the DTV mini to a sub.
    Garage | Polk Monitor 5B's
    Re-reading the title of this thread gave me pause -- it seems to imply that there's a market for indecent soundbars?!?
    I guess those are built with indiscreet components...?
    B)
  • steveinaz
    edited October 2019
    Well, it seems like its almost an impossible feat to build a soundbar that lasts. The biggest complaints seem to be (from many different manufacturers) "my soundbar quit working." You'd think a soundbar would be a pretty simple thing to build with durability, especially with todays digital amp technology. Like I mentioned earlier, how come a cheap pair of powered computer speakers can lasts, but we can't make a soundbar last? My vizio (that died too) had GREAT reviews, was on many "budget best buy" lists, and died after 14 months. It just ceased to work; BUT apparently there is a lucky 60% of owners whose bar has not had a problem. That's a pretty poor failure rate for a fairly simple piece of equipment. I don't even use any of the advanced features, I just simply use it as a better TV speaker system.
    Hopefully the Yamaha will fare better.
    Good luck with it Steve.
    I think part of the conundrum is, one part built in obsolesce, and another part is just form and function over longevity. How many soundbars you gonna sell if they lasted 20 years ?
    It's not just soundbars, but across most consumer products.
    That Zvox thing looks interesting. I've heard of them before but never really looked at any reviews.
    edited October 2019
    One would think -- yes. :|
    Maybe the same issue that plagues powered (Class AB) subwoofers with plate amps (or some A/V receivers, for that matter) is the root cause for many of the soundbar failures? I.e., heat buildup. Yeah, not too much heat generated (i.e., power wasted) by the Class D amps -- but there is some, and presumably there's a CPU and some signal processing firepower inside the soundbars generating heat, as well.
    Then again, maybe they're just carefully and deliberately designed to fail fairly quickly. :(Planned obsolescence is, of course, alive and well in the 'digital age'.
  • decal
    decal Posts: 3,205
    ZVox, but you're gonna have to pony up the cash.
  • Emlyn
    Emlyn Posts: 4,844
    Zvox covers a wider price point than they used to. They have some below the $300 line now and the company appears to have responsive customer service. One cool thing they do now is integrate a special dialogue enhancement feature for people who use hearing aids.
    A one year warranty applies, but reviews of their products on Amazon don’t seem to indicate many break down issues. There are obviously many problems with soundbar electronics caused by cheap engineering and parts. But, I would also not be surprised if some of the problems are caused by users expecting too much of them in terms of trying to get a home theater experience out of a small plastic box. I would not recommend expecting much beyond getting better tv sound out of one unless it’s above the $1K mark.
  • steveinaz
    Yes, the Zvox seem to get really good reviews, and it looks like a quality product. Maybe the "SVS" of soundbars?
  • Emlyn
    Emlyn Posts: 4,844
    If I was in the market, I’d go for this model with a 42 inch TV...
    https://www.amazon.com/ZVOX-SoundBase-Subwoofer-Bluetooth-AccuVoice/dp/B00O96PD9O
    can apparently connect an external subwoofer too.
  • Mikey081057
    I like this one...
    https://www.bluesound.com/products/pulse-soundbar/
    Can also accommodate an external sub as well.
  • halo
    halo Posts: 5,619
    I like this one...
    Way over the OP's stated price cap.
  • Mikey081057
    edited October 2019
    halo wrote: »
    I like this one...
    I said I like it.... Didn't say he should. B)
    steveinaz wrote: »
    They were the first who brought them to market I believe.
