How to unsubscribe from a thread?
Synomenon
I must be blind. Can someone please show me how to unsubscribe from a thread?
Upper right hand corner of your comment is a star, uncheck it to unsubscribe.SDA SRS 1.2TL's
SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
SDA 2B TL's w/RD0198-1's
Yaqin MC-30L integrated tube amp
Yaqin MS-20L integrated tube amp -
Hmmm, I don't see any stars on the upper right hand corner of any of my posts.
- You have to click on My Bookmarks under your profile (unless you’re using the mobile version, which has a very different layout). This will list all your subscribed threads.
- Next to the title of each subscribed thread, you’ll see a yellow ⭐️ icon. Click on the star to unsubscribe. The star should change color (white).
Alea jacta est! -
what kex said...SDA SRS 1.2TL's
There's no "upper right HAND corner".
It's just the "upper right corner".
What is this "hand" nonsense? -
Your quote of me is wrong, I didn't type hand in all caps. You obviously have a lot of time on your "hands"...SDA SRS 1.2TL's
Ok, when I go to Bookmarks under my profile, it says I don't have any bookmarks.
In that case, you should be fine. You are not subscribed to any threads.Alea jacta est!
The “hand” in “upper right hand corner” might be superfluous, but it is perfectly acceptable (and common) usage.Alea jacta est!
No fu(king $hit, Sherlock.
I keep getting email notifications though for the "Polk Signature Series Official Discussion" thread. -
Yeah, how come no one ever says lower left foot corner?
I think I'm going to start using it, trendsetter-wannabe that I am...
http://audiomilitia.proboards.com/ -
What does unsubscribing from a thread mean? Of course, then what does subscribing to a thread mean?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
1. Open your profile, and click on the Edit Profile button:
2. On the right hand side of the screen, click on Notification Preferences:
3. You probably have the option to be notified about discussions that you have commented in checked.
Alea jacta est! -
Alea jacta est! -
BUT WHEN I DO I USE IT IN THE UPPER RIGHT HAND CORNER
Using his left hand...SDA SRS 1.2TL's
This has gotten out of hand. HAND. Go stand in the corner.
