How to unsubscribe from a thread?
I must be blind. Can someone please show me how to unsubscribe from a thread?
  • michaeljhsda2michaeljhsda2 Posts: 1,928
    Upper right hand corner of your comment is a star, uncheck it to unsubscribe.
    SDA SRS 1.2TL's
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 2B TL's w/RD0198-1's
    Yaqin MC-30L integrated tube amp
  • SynomenonSynomenon Posts: 14
    Hmmm, I don't see any stars on the upper right hand corner of any of my posts.
  • KexKex Posts: 3,589
    1. You have to click on My Bookmarks under your profile (unless you’re using the mobile version, which has a very different layout). This will list all your subscribed threads.
    2. Next to the title of each subscribed thread, you’ll see a yellow ⭐️ icon. Click on the star to unsubscribe. The star should change color (white).
    Alea jacta est!
    edited October 18
    what kex said...
    SDA SRS 1.2TL's
  • Viking64Viking64 Posts: 4,360
    There's no "upper right HAND corner".
    It's just the "upper right corner".
    What is this "hand" nonsense?
    Your quote of me is wrong, I didn't type hand in all caps. You obviously have a lot of time on your "hands"...
    SDA SRS 1.2TL's
    Ok, when I go to Bookmarks under my profile, it says I don't have any bookmarks.
    In that case, you should be fine. You are not subscribed to any threads.
    Alea jacta est!
    The “hand” in “upper right hand corner” might be superfluous, but it is perfectly acceptable (and common) usage.
    Alea jacta est!
    Kex wrote: »
    No fu(king $hit, Sherlock.
    Kex wrote: »
    I keep getting email notifications though for the "Polk Signature Series Official Discussion" thread.
  • polrbehrpolrbehr Posts: 2,405
    Viking64 wrote: »
    Kex wrote: »
    Yeah, how come no one ever says lower left foot corner?
    I think I'm going to start using it, trendsetter-wannabe that I am...
  • BlueFoxBlueFox Posts: 12,176
    What does unsubscribing from a thread mean? Of course, then what does subscribing to a thread mean?
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    edited October 18
    Synomenon wrote: »
    You need to edit your notification preferences in your profile.
    1. Open your profile, and click on the Edit Profile button:
    2. On the right hand side of the screen, click on Notification Preferences:
    3. You probably have the option to be notified about discussions that you have commented in checked.
    Alea jacta est!
    BlueFox wrote: »
    It bookmarks the thread so you can find it easily from the bookmarks menu, or get notified about replies to it (although, as shown above, you can still get notified without a bookmark).
    Alea jacta est!
  • HermitismHermitism Posts: 2,568
    Viking64 wrote: »
    Kex wrote: »
    I DON'T ALWAYS USE THE WORD "HAND"
    BUT WHEN I DO I USE IT IN THE UPPER RIGHT HAND CORNER
    2.0/3.0 - Marantz: PM8005 w/HT Bypass, NA8005 | Polk: LSiM703, LSiM706c | PS Audio: Duet, Power Port Classic, PerfectWave AC5 x3 PC | Wireworld Equinox 7 IC | AudioPrism Quietline MkIII x7 | Sanus UF30 | Acoustic Panels, GIK Soffit Traps
    6.1 - Pioneer Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | PS Audio: Quintet, Power Port Classic | DCF124BW x3 SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate x2 HDMI | M850SW | Acoustic Panels, GIK Soffit Traps
    Using his left hand...
    SDA SRS 1.2TL's
  • kharp1kharp1 Posts: 3,385
    This has gotten out of hand. HAND. Go stand in the corner.
    Main System:
    Joule-Electra LA 100 MKIII Upgraded by Rich Brkich Pre
    Butler Audio TBD 2250 Amp
    PS Audio DirectStream DAC and MemoryPlayer Transport
    LSA-1 Statement
    SVS SB4000 & SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
    Backup Gear:
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    polrbehr wrote: »
    Viking64 wrote: »
    Kex wrote: »
    :p
Howdy, Stranger!
