How to unsubscribe from a thread?
I must be blind. Can someone please show me how to unsubscribe from a thread?
  • Upper right hand corner of your comment is a star, uncheck it to unsubscribe.
    SDA SRS 1.2TL's
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 2B TL's w/RD0198-1's
    Yaqin MC-30L integrated tube amp
  • Hmmm, I don't see any stars on the upper right hand corner of any of my posts.
  • Kex
    Kex Posts: 4,892
    1. You have to click on My Bookmarks under your profile (unless you’re using the mobile version, which has a very different layout). This will list all your subscribed threads.
    2. Next to the title of each subscribed thread, you’ll see a yellow ⭐️ icon. Click on the star to unsubscribe. The star should change color (white).
    Alea jacta est!
  • michaeljhsda2
    michaeljhsda2 Posts: 2,165
    edited October 2019
    what kex said...
    SDA SRS 1.2TL's
    Viking64 Posts: 6,646
    There's no "upper right HAND corner".
    It's just the "upper right corner".
    What is this "hand" nonsense?
  • Your quote of me is wrong, I didn't type hand in all caps. You obviously have a lot of time on your "hands"...
    SDA SRS 1.2TL's
  • Ok, when I go to Bookmarks under my profile, it says I don't have any bookmarks.
  • Kex
    Kex Posts: 4,892
    In that case, you should be fine. You are not subscribed to any threads.
    Alea jacta est!
  • Kex
    Kex Posts: 4,892
    The “hand” in “upper right hand corner” might be superfluous, but it is perfectly acceptable (and common) usage.
    Alea jacta est!
    Kex wrote: »
    No fu(king $hit, Sherlock.
  • Kex wrote: »
    I keep getting email notifications though for the "Polk Signature Series Official Discussion" thread.
  • polrbehr
    polrbehr Posts: 2,825
    Viking64 wrote: »
    Kex wrote: »
    Yeah, how come no one ever says lower left foot corner?
    I think I'm going to start using it, trendsetter-wannabe that I am...
  • BlueFox
    BlueFox Posts: 15,251
    What does unsubscribing from a thread mean? Of course, then what does subscribing to a thread mean?
  • Kex
    Kex Posts: 4,892
    edited October 2019
    Synomenon wrote: »
    You need to edit your notification preferences in your profile.
    1. Open your profile, and click on the Edit Profile button:
    2. On the right hand side of the screen, click on Notification Preferences:
    3. You probably have the option to be notified about discussions that you have commented in checked.
    Alea jacta est!
  • Kex
    Kex Posts: 4,892
    BlueFox wrote: »
    It bookmarks the thread so you can find it easily from the bookmarks menu, or get notified about replies to it (although, as shown above, you can still get notified without a bookmark).
    Alea jacta est!
  • Hermitism
    Hermitism Posts: 4,192
    Viking64 wrote: »
    Kex wrote: »
    I DON'T ALWAYS USE THE WORD "HAND"
    BUT WHEN I DO I USE IT IN THE UPPER RIGHT HAND CORNER
  • Using his left hand...
    SDA SRS 1.2TL's
  • kharp1
    kharp1 Posts: 3,453
    This has gotten out of hand. HAND. Go stand in the corner.
    polrbehr wrote: »
    Viking64 wrote: »
    Kex wrote: »
    :p
