How to unsubscribe from a thread?
Synomenon
I must be blind. Can someone please show me how to unsubscribe from a thread?
Upper right hand corner of your comment is a star, uncheck it to unsubscribe.SDA SRS 2.3TL's
SDA 2B TL's -
Hmmm, I don't see any stars on the upper right hand corner of any of my posts.
what kex said...SDA SRS 2.3TL's
SDA 2B TL's -
There's no "upper right HAND corner".
It's just the "upper right corner".
What is this "hand" nonsense? -
Your quote of me is wrong, I didn't type hand in all caps. You obviously have a lot of time on your "hands"...SDA SRS 2.3TL's
SDA 2B TL's -
Ok, when I go to Bookmarks under my profile, it says I don't have any bookmarks.
The “hand” in “upper right hand corner” might be superfluous, but it is perfectly acceptable (and common) usage.
No fu(king $hit, Sherlock.
In that case, you should be fine. You are not subscribed to any threads.
I keep getting email notifications though for the "Polk Signature Series Official Discussion" thread. -
Yeah, how come no one ever says lower left foot corner?
I think I'm going to start using it, trendsetter-wannabe that I am...
http://audiomilitia.proboards.com/ -
What does unsubscribing from a thread mean? Of course, then what does subscribing to a thread mean?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I DON'T ALWAYS USE THE WORD "HAND"
BUT WHEN I DO I USE IT IN THE UPPER RIGHT HAND CORNER
Using his left hand...SDA SRS 2.3TL's
SDA 2B TL's -
This has gotten out of hand. HAND. Go stand in the corner.
