Interconnects - Help me pick new cables!
Inspector 24
LSiM 707 trigger has been pulled. Time to upgrade my cable game too!
Current interconnects are generic-nothing-special so I'm sure anything will be an upgrade! Do not feel the need to spend a lot, just want something that will compliment my existing gear and the new 707's. Use is 75% movies, 25% music, but music is 200% more critical.
I may have a hookup for Audioquest cables, and they seem to be popular in the Polk crowd, but neither their site or places they're sold are helpful in differentiating how the cables may sound or very clear about how they're terminated, IE single channel cable, pair siamesed etc. Certainly not married to Audioquest, open to all suggestions.
Gear:
RTiA9 LSiM707 - CSiA6 LSiM 706c - FXiA6 - Dual HSU VTF-15H Mk2
Panasonic dmp-bdt500
Speaker cables are bi-wired 12ga banana plugs.
Thanks in advance for your thoughts and opinions!
Gear:
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
Down
Post edited by Inspector 24 on
Signal Cable, Cullen Cable, Kimber Hero, Wireworld, DouglasConnection"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
All great brands! Doesn't actually help narrow things down though!
Not interested in trying a bunch of cables, but am curious about experiences! Up
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
I would go with entry level Shunyata cables. Of course if you do then you will be so amazed that you will start thinking of getting even better Shunyata cables.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
What is your system? I can’t see sigs on my phone.
Gear:
Speaker cables are bi-wired 12ga banana plugs.Up
Down
I'm sure! Though my budget is more LSiM quality at 75% off. Champange taste on a Beer budget!
Up
Down
You won’t find them but PNF is king for cheap cables. They’re gone and those who have them don’t sell them. Outside of that, I think Wireworld or Kimber would be good options for budget friendly options. Douglas’ cables are very high quality too but with a multi channel could get expensive. Doug’s entry cables from what I remember will roll off the top end a bit so if you need that, they’ll be a great fit.
Particular line or cable you'd lean toward? Or maybe a feature to look out for?
Just looking to upgrade left/right channels at this time, maybe the center should I notice a large enough difference.
Up
Down
If you are on a tight budget ZU Mission cables on eBay, good stuff cheap.
Idolizing a politician is like believing the stripper REALLY likes you. -
Get ahold of Doug at Douglas Connection... they will be the very best solution for your needs, bar none.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Morrow Cables seem to get good reviews.See my profile for list of gear.
motorhead43026 wrote: »If you are on a tight budget ZU Mission cables on eBay, good stuff cheap.
Wow those are cheap! Barely more than a Douglas Connection DIY kit!
Up
Down
nooshinjohn wrote: »Get ahold of Doug at Douglas Connection... they will be the very best solution for your needs, bar none.
I'm looking at them now. Built price is $120/1m. DIY is $48 shipped! I can build cables… So long as I solder them correctly, would that not be the biggest bang for the buck? Is there a $85 benefit to paying them to build them?
Up
Down
Doug's work is among the finest I have seen, and he stands behind them like a devoted father... a great guy to work with all around.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Cable trigger pulled. Doug's DIY kit. Price seems unbeatable. I think I used to know about his DIY kits, and haven't considered any upgrades for so long I forgot! Have to start small-ish again, but this may be the kickoff of a new round of upgrades. I mean I dumped money on the speakers so why not.Up
Down
Inspector 24 wrote: »Cable trigger pulled. Doug's DIY kit. Price seems unbeatable. I think I used to know about his DIY kits, and haven't considered any upgrades for so long I forgot! Have to start small-ish again, but this may be the kickoff of a new round of upgrades. I mean I dumped money on the speakers so why not.
Nicely done! I did a 7.0 set up with DIY from Dougs using the Furez R10BCS silver connectors.
Doug gave me some basic instruction and presto, high end I.C.s for less.
Doug gives a small discount for polk members. Send him an email and your polk name boom discount
Thanks! I’ll hit him up.
Hopefully they arrive in advance enough of the 707’s to get them built! He has a great video showing just how to do it.
https://youtu.be/AuC9tfNj6eg Up
Down
He doesn’t show in the video how to attach the braided jacket, and I couldn’t figure it out. The barrel with the screw wouldn’t fit over the heat shrink and the jacket, is it supposed to go under the red/black heat shrink?
Up
Down
Inspector 24 wrote: »He doesn’t show in the video how to attach the braided jacket, and I couldn’t figure it out. The barrel with the screw wouldn’t fit over the heat shrink and the jacket, is it supposed to go under the red/black heat shrink?
typically yes I would put it under the shrink tubing. -
I didn't use the heat shrink with my projects, just electrical tape. That holds the techflex down really well when inserting it into the barrel.
As you have found out by now, heatshrink and techflex makes for a pretty super tight fit.
Hope it's going well for you. -
Venhaus diy finesilver IC’s - incredible sounding"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
