Interconnects - Help me pick new cables!
Inspector 24
Inspector 24 Posts: 1,308
edited September 2019 in Speakers
LSiM 707 trigger has been pulled. Time to upgrade my cable game too!
Current interconnects are generic-nothing-special so I'm sure anything will be an upgrade! Do not feel the need to spend a lot, just want something that will compliment my existing gear and the new 707's. Use is 75% movies, 25% music, but music is 200% more critical. ;)
I may have a hookup for Audioquest cables, and they seem to be popular in the Polk crowd, but neither their site or places they're sold are helpful in differentiating how the cables may sound or very clear about how they're terminated, IE single channel cable, pair siamesed etc. Certainly not married to Audioquest, open to all suggestions.
Gear:
RTiA9 LSiM707 - CSiA6 LSiM 706c - FXiA6 - Dual HSU VTF-15H Mk2
Panasonic dmp-bdt500
Speaker cables are bi-wired 12ga banana plugs.
Thanks in advance for your thoughts and opinions!
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
Post edited by Inspector 24 on
  • Signal Cable, Cullen Cable, Kimber Hero, Wireworld, DouglasConnection
  • All great brands! Doesn't actually help narrow things down though! ;) Not interested in trying a bunch of cables, but am curious about experiences!
    Up
    Down
  • BlueFox
    BlueFox Posts: 15,250
    I would go with entry level Shunyata cables. Of course if you do then you will be so amazed that you will start thinking of getting even better Shunyata cables.
  • Inspector 24
    DSkip wrote: »
    What is your system? I can’t see sigs on my phone.
    Gear:
    Up
    Down
  • BlueFox wrote: »
    I'm sure! Though my budget is more LSiM quality at 75% off. Champange taste on a Beer budget! :D
    Up
    Down
  • DSkip wrote: »
    You won’t find them but PNF is king for cheap cables. They’re gone and those who have them don’t sell them. Outside of that, I think Wireworld or Kimber would be good options for budget friendly options. Douglas’ cables are very high quality too but with a multi channel could get expensive. Doug’s entry cables from what I remember will roll off the top end a bit so if you need that, they’ll be a great fit.
    Particular line or cable you'd lean toward? Or maybe a feature to look out for?
    Just looking to upgrade left/right channels at this time, maybe the center should I notice a large enough difference.
    Up
    Down
  • motorhead43026
    motorhead43026 Posts: 4,031
    If you are on a tight budget ZU Mission cables on eBay, good stuff cheap.
    nooshinjohn Posts: 26,009
    Get ahold of Doug at Douglas Connection... they will be the very best solution for your needs, bar none.
  • TEAforONE
    TEAforONE Posts: 1,079
    Morrow Cables seem to get good reviews.
  • If you are on a tight budget ZU Mission cables on eBay, good stuff cheap.
    Wow those are cheap! Barely more than a Douglas Connection DIY kit!
    Up
    Down
  • Inspector 24
    I'm looking at them now. Built price is $120/1m. DIY is $48 shipped! I can build cables… So long as I solder them correctly, would that not be the biggest bang for the buck? Is there a $85 benefit to paying them to build them?
    Up
    Down
    Doug's work is among the finest I have seen, and he stands behind them like a devoted father... a great guy to work with all around.
  • Cable trigger pulled. Doug's DIY kit. Price seems unbeatable. I think I used to know about his DIY kits, and haven't considered any upgrades for so long I forgot! Have to start small-ish again, but this may be the kickoff of a new round of upgrades. I mean I dumped money on the speakers so why not.
    Up
    Down
  • Geoff4rfc
    Geoff4rfc Posts: 2,978
    Nicely done! I did a 7.0 set up with DIY from Dougs using the Furez R10BCS silver connectors.
    Doug gave me some basic instruction and presto, high end I.C.s for less.
    pitdogg2 Posts: 27,377
    Doug gives a small discount for polk members. Send him an email and your polk name boom discount
  • Thanks! I’ll hit him up.
    Hopefully they arrive in advance enough of the 707’s to get them built! He has a great video showing just how to do it.
    https://youtu.be/AuC9tfNj6eg
    Up
    Down
  • He doesn’t show in the video how to attach the braided jacket, and I couldn’t figure it out. The barrel with the screw wouldn’t fit over the heat shrink and the jacket, is it supposed to go under the red/black heat shrink?
    Up
    Down
    typically yes I would put it under the shrink tubing.
  • Geoff4rfc
    I didn't use the heat shrink with my projects, just electrical tape. That holds the techflex down really well when inserting it into the barrel.
    As you have found out by now, heatshrink and techflex makes for a pretty super tight fit.
    Hope it's going well for you.
  • drumminman
    drumminman Posts: 3,396
    Venhaus diy finesilver IC’s - incredible sounding
