The Polk Legend Series is coming
145791013
  • verb
    verb Posts: 10,176
    verb wrote: »
    I didn't watch the unveiling -- cut the grass instead.
    Do "we" know if any or all of the new Legend series loudspeakers are US made, or assembled in the US?
    Just curious.
    Designed in the USA, built in China.
    That settles it! :)
    Did you doubt me?
    Never! :)
    F1nut Posts: 51,749
    When will Raife start work on the next-gen Dreadnaught? Larry's rings? New boards from Gimpod?
    New boards? Have you seen the crossovers, there won't be any new boards.
    nooshinjohn Posts: 25,916
    My post was in jest... LOL :p
    pitdogg2 Posts: 27,035
    Yep seem to be a lot of little yellow things that over the years of Polk ownership I've ...umm .. disappeared them.... :D
    Like the marker of the real values.
    Good stuff I'm gone about 5hrs and its pandamoanium on club Polk
    LOVE IT!!
    SAL WHO???
    tonyb Posts: 33,072
    Ha, might as well price out replacements now. I can see toasted boards from driving those L800's with a 500 buck receiver. I sure hope Polk's material mentions a proper power source. Look what we go through with the LSI's and RTIA9's.
    txcoastal1 Posts: 13,511
    Yeah....Polk will be selling plenty of replacement parts for these
    tonyb Posts: 33,072
    txcoastal1 wrote: »
    Curious....by the look of those crossovers, if they are easily replaceable in home by the average joe, or do you need to ship them back. That could be costly should something go south.
  • BlueFox
    BlueFox Posts: 15,251
    It will be interesting to hear what you can get for $6K. I would expect technology to improve over time while the cost decreases. For example, I would expect them to meet, or exceed, my $10K Aerial Acoustics 7T speakers. If so I might upgrade the HT/spare stereo system.
    tonyb Posts: 33,072
    Yeah well, give me a crack at those 7T's , they're keepers.
  • BlueFox
    If I do upgrade the fronts then the Aerials should go to the rear. However, that is super overkill for movies, and my PSB rears are fine. Let’s see what happens, and then talk.
    mhardy6647 Posts: 34,998
    tonyb wrote: »
    Did you see the specs @F1nut posted?
    Granted, the L800 is conspicuously absent, but, e.g., the little L100 bookshelf is rated for 85.5 dB SPL (presumably at 1 meter) for 2.83 VAC input -- which is 2 watts into its nominal 4 ohm impedance... then it says minimum recommended amplifier power is 30 watts.
    Hmm....
  • Man these look nice, can't wait to get my ears on them and see how they compare to the old 1.2tls
  • boston1450
    boston1450 Posts: 7,758
    Not sure if anyone said this yet. But DAMN with the grills on WOW those look gorgeous.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    edited September 2019
    Rick88 wrote: »
    "Steady state recommended amplifier power" - I'm pretty sure I've never heard it referred that way before.
    I suspect that's a nod to the reality of current-era power claims for many types of audio amplifying equipment :/
    At any rate, I would think (only) 30 watts into a loudspeaker rated for (only) 82.5 dB SPL (per watt) sensitivity would be (will be) asking for trouble.
    EDIT: heh, upon reflection -- yeah, that is a funny way to put it. I assume it means "recommended steady state amplifier power", but maybe they mean the recommendation fluctuates wildly among the staff, but most of the time it is 30 to 160 watts. ;)
    (as y'all can tell, I am totally fascinated by this new line - I really am)
    F1nut Posts: 51,749
    tonyb wrote: »
    Hmm....
    The L800 info is missing because it has its own manual/spec sheet, which I don't have yet.
    tonyb wrote: »
    Hmm....
    That's OK -- although it will be interesting to see what the minimum recommendation for the L800 is. Actually, come to think of it, the recommended range will be interesting, too.
    F1nut Posts: 51,749
    200 watts, of course.
  • BlueFox
    Okay Cfrizz.
    F1nut Posts: 51,749
    Ouch!
  • BlueFox
    Only kidding. :)
    You'll need it
    I think all these new loudspeakers'll need that kind of oompf, given their sensitivity.
    I don't suppose that there's any hope that Polk'll publish impedance curves for any of them, is there?
    Plan B -- I wonder if Stereophile will review one of them? JA will give 'em a good quantitative shakedown.
    I mean, maybe audiosciencereview would test a pair, but Amir's brain would short out when he couldn't figure out how to measure SINAD. ;)
  • halo
    halo Posts: 5,616
    I guess the 40 wpc NAD C 316BEE that I'm using isn't going to be able to drive these to insanely loud listening levels safely (which is ok because I rarely go past a 75 dB average when listening).
    gudnoyez Posts: 8,161
    Is the SDA cable that is included similar to an A1 or will you loose out on the warranty if you choose to set them up to accept the AV1000?
    VR3 Posts: 29,425
    L800 specs -
    ACCESSORIES
    Included Accessories
    (1) Cleaning cloth
    (1) Removable Magnetic Grille
    (4) Rubber Carpet-Spike Covers
    (1) SDA Interconnect Cable (12 ft)
    Optional Accessories
    (1) L900 Height Module Speaker - Drops into top of tower for Dolby Atmos and DTS:X height channels
    SHIPPING CARTONS
    Carton 1151 lbs (68.49 kg)
    L800 FLOORSTANDING TOWER SPEAKER
    Total Pieces1
    Height48.6" (123.44 cm)
    Width17.94" (45.57 cm)
    Depth17.38" (44.15 cm)
    Weight118 lbs (53.52 kg)
    Driver Enclosure TypePower Port Bass Vented with Sealed Midrange
    Driver Complement
    (2) 1" (2.54 cm) d (Round) Pinnacle Ring Radiator - Tweeter
    (2) 5.25" (13.34 cm) d (Round) Turbine Cone - Mid/Woofer
    (2) 10" (25.4 cm) d (Round) Woofer - Mid/Woofer
    Recommended Amplifier Power Setting100W
    AUDIO QUALITY
    Total Frequency Response25 Hz → 50,000 Hz
    Nominal Impedance Range2.8 ohms → 4 ohms
    Sensitivity (1 watt @ 1 meter)87 dB
    Lower and Upper -3dB Limits32 Hz → 38,000 Hz
    CROSSOVER
    Type3-way Orth Crossover (x2)
    Midrange/Woofer Crossover Frequency370 Hz
    Tweeter/Midrange Crossover Frequency2800 Hz
    Power Handling (per channel)25 watts → 300 watts
    A/V Receiver Crossover SettingsLarge (0 Hz)
    EXTERNAL AMPLIFIER
    Peak Power Handling300 watts
    Recommended Amplifier Power Per Channel25 watts → 300 watts
    WARRANTY
    Total Pieces1
    Included Upon Purchase5 years (non-transferable)
    Additional Upon Product Registration5 years (non-transferable)
    F1nut Posts: 51,749
    gudnoyez wrote: »
    No Dreadnought required, they work with non-common ground amps.
    Get an amp :)
  • BlueFox
    LOL. Yikes. That’s a lot to digest.
  • FTGV
    FTGV Posts: 3,650
    Humm new SDA eh? Interesting. Looks like they have limited the dimensional difference signal to the mid band and above. Which IIRC they did with most 2nd gen and later models. Wonder what the actual crossover point is between the midrange and woofers? I assume in the 200-350Hz range. No pressure but we expect Jesse to get the x over schematics and have them posted by next week. :)
    The re-introduction of the dimensional tweeter is also interesting. I understand the use of the tweets in 1st gen SDA's caused some undesirable artifacts. The 800's crossover is busy. A 3 way with steep slopes and an extra mid and tweet puts the parts count up fast. Obviously they had to use rather pedestrian parts to keep costs reasonable. Would like to hear them and the little 2 ways.
    Carton 1151 lbs
    Better than 1/2 a ton apiece... wow :p
