Fluance Reference Series Turntables
13
    mhardy6647 Posts: 35,134
    Why do you want exactly 1.8?
    FWIW, I'd suggest either of the following approaches.
    1) Set the tracking at the high end of the manufacturer's specified range. IMO/IME that's usually "best" -- the low number is for bragging rights, not for best performance :p (again, IMO).
    or
    2) Set it to 'close' to 1.8 and dial it in, iteratively, to the what sounds best/tracks best to you. Feel free to torture test the system (e.g., highly modulated passages of the last track on an album).
    If you really want 1.8 g; get a good VTF scale. I don't think the calibrations would be terribly trustworthy if one really wants a specific value.
    Just my 2 cents, you know?
  • scubalab
    scubalab Posts: 3,105
    Leave it to Doc to chime in with some common sense! B)
    For 6 bucks for the scale, I'm curious how close I got it. But yeah, makes sense to err on the side of a slightly higher VTF (within the recommended range) if not using a scale!
    I think that tip/advice was worth 3-4 cents minimum!
  • scubalab
    And Chumlie… UNBOX that beauty already! :D
  • chumlie
    chumlie Posts: 8,658
    edited August 2019
    scubalab wrote: »
    Will do. On my list for the weekend. Looking at phono pre's. Any suggestions ? $400 or less.
  • stangman67
    stangman67 Posts: 2,328
    For under 400 bucks you probably can’t touch the lounge LCR. I’ve used multiple Cambridge’s and have been underwhelmed. The lounge was a definite step up ( especially in background noise, I found both Cambridge’s to be quite noisy but the lounge was silent)
  • halo
    halo Posts: 5,616
    chumlie wrote: »
    Bottlehead Reduction 1.1 $369
    Schiit Mani $129
    Art DJ Pre II $65
    The Schiit Mani is the most versatile as it can handle a wide variety of MC & MM carts. The ART DJ Pre II sounds better than it has a right to (at that price) and it includes a rumble filter!
    The Bottlehead is a solid choice but you'll have to add the cost of tubes to it if you want to "upgrade." It goes on sale from time to time and you may be able to snag the kit with the Integration upgrade for less than $400. It's DIY so you have to build it yourself or know someone who can assist you.
    Clipdat Posts: 13,098
    stangman67 wrote: »
    By "noise" do you mean an audible buzzing coming through the speakers when nothing was playing?
  • stangman67
    Correct. White noise when the needle was not dropped
    hifihaven recently did a round robin of the Lounge LCR -- it's a fine sounding phono preamp, especially for the $.
    https://hifihaven.org/index.php?threads/lounge-audio-lcr-phono-preamp-member-test-sign-up-here.3650/
    The worst thing I can say about it is that it's not adjustable. I used it with an SUT to listen to the DL-103 and was not in the least disappointed in the quality, even though the Lounge LCR costs about a quarter of the phono preamp I usually use.
  • Dr_Wu
    Dr_Wu Posts: 356
    The ability to adjust and the gain range sold me on the MoFi StudioPhono. MM/MC capable. I've been very happy with it.
  • displayname
    displayname Posts: 1,228
    If it was my money going towards new gear I'd likely spend it on the mofi or a Vincent Pho-8. The LCR is another strong selection too. I've also read that you can have the internal wiring redone on the LCR as a nice upgrade for a reasonable cost.
    I really enjoyed my iFi iPhono2 which came in at $500 new when I had it, but unfortunately people started having issues with them dying after a couple years (or less) so I wouldn't recommend them anymore. Especially not used.
    If you're willing to go used, be patient, and maybe go a little over budget, you could keep an eye out for a Sutherland KC Vibe. Everyone I know that's gotten a Sutherland has either stuck with what they got, or moved further up the Sutherland chain. The KC Vibe would be a killer step up if you can find one for the right price.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
  • chumlie
    Thanks folks, I believe I will go with the MoFi.
  • SIHAB
    SIHAB Posts: 5,474
    Um, you tried it?
  • chumlie
    SIHAB wrote: »
    Um, you tried it?
    Not yet. Haven't even ordered it yet. Or un-boxed the turntable.
  • pawelmwo
    pawelmwo Posts: 137
    edited August 2019
    I've been playing the RT-83 for over a week and very happy with it so far. Picked up a bunch of records at a thrift store which cleaned up really nice. Some records sound great but some give me a significant amount of crack and pops which can go away as the stylus makes it toward the middle. I'm guessing they are a bit warped on the outside or damaged?
    Would placing a weight on the center help at all with that? I have balanced the turntable a few times even using an actual contractors level both front to back and side to side, including on the path of the tone arm. Tracking and anti skip still playing with those 1.8 - 2.5 range. I've considered getting that tuning record but $50 is a little much to spend on that. Anyone care to share their tuning method? Keep in mind this is my first turntable so there is a chance I'm doing it wrong :)
  • chumlie
    My 85 is still in the box. Hoping this weekend.
  • displayname
    pawelmwo wrote: »
    Crackle and pop can be caused by a few things, static, dirt, scratches, and sometimes it’s just a bad pressing.
    A weight has benefits, but it’s not going to fix any of those issues. A weight really doesn’t “fix” anything except very very minor warps. It really just helps tighten up specs by a small amount.
    I find that running the tracking force at close to the top end of the cartridge range tends to consistently work a little better. You can buy a digital tracking force scale on amazon for $10-15, it’s well worth the investment because it lasts forever and is much more accurate then the markings on the counter weight.
    Cleaning and dealing with static will give you the greatest instant improvements. Some records require more than one cleaning (even new records).
    Discogs
  • pawelmwo
    pawelmwo Posts: 137
    pawelmwo wrote: »
    Any specific scales you can recommend? I was looking briefly and there are of course a bunch of them. I do use an Audioquest brush several times before lowering the stylus the record. I've not looked into anything to deal with static but do try to remove the records slowly out of the (Mofi master) sleeves.
  • displayname
    pawelmwo wrote: »
    pawelmwo wrote: »
    This is the same one I have. Zero issues.
    https://www.amazon.com/Neoteck-Digital-Turntable-Backlight-Cartridge/dp/B01HRJ9NAY
    The antistatic sleeves like you have are really the best thing you can do for static. What are you doing for cleaning?
    Discogs
  • pawelmwo
    pawelmwo Posts: 137
    pawelmwo wrote: »
    pawelmwo wrote: »
    Thanks for the scale recommendation. So far I have only cleaned the thrift store $1 records. I might get some slack for this but I use lukewarm water and dawn. My cleaning routine is:
    1) rinse the record with tap water on both sides without getting much water on the label
    2) put a drop of dawn in a bowl of lukewarm water. Using a 100% cotton round pad apply the water dawn solution to the record following the grooves of the record on both sides in a clockwise motion. Wait a few seconds
    3) from the center in a clockwise motion following the grooves work the cotton again towards the outside of the record.
    4) repeat in process in a counterclockwise motion.
    5) rinse both sides thoroughly
    6) using a new dry cotton round wipe away the wet spots following the record grooves, in clockwise motion.
    7) remove any lint after it dries with the Audioquest brush.
    8) insert into new Mofi master sleeve
  • displayname
    It’s better than nothing, that’s for sure. My main tips would be do your final rinse with distilled water and use a lint free microfiber cloth for the final dry. That should help cut down on the clicks and pops.
    Discogs
  • pumpkinman
    pumpkinman Posts: 10,258
    IMHO you should never ever use tap water while cleaning your precious LP’s
    Because I am The Pumpkinking
  • SIHAB
    SIHAB Posts: 5,474
    Right. Use distilled water.
    Also use natural dish liquid like 7th generation.
    Before I got my RCM, I used the floor sweeper to remove the
    excess water and then let them dry the rest of the way in a
    dish rack. The hose attachment that is. I didn't run over them. :#
  • tonyp063
    tonyp063 Posts: 1,135
    pawelmwo wrote: »
    ...Picked up a bunch of records at a thrift store which cleaned up really nice. ..
    Let's not forget this is where poster is.
    I don't think his cleaning method is inappropriate. IMO.
  • SIHAB
    SIHAB Posts: 5,474
    Oh I agree. I thought about that.
    Just thought I'd toss out some unsolicited advice.
    msg Posts: 10,452
    I agree on the use of distilled, if possible. Paint pads are good on a budget, too.
    I used to finish with extra plush microfiber towels, thinking I was doing well, until I discovered the benefits of immersive wash, rinse, and drip dry - zero static.
  • halo
    halo Posts: 5,616
    The squeaky clean record cleaning machine that I have uses a wet/dry vac to suck up the water + cleaning fluid + dust + gunk that isn’t removed by the paint pads. I typically finish with a microfiber towel just to be sure they’re dry before they go back in a MOFI sleeve. There’s still a ton of static when handling the albums.
    msg Posts: 10,452
    Maybe see what happens if you let them air dry in a stand instead (a vinyl coated dish rack would be my choice for this). I've tried a bunch of different cleaning methods, all finished with the microfiber, thinking I was doing a good thing. All staticky.
  • pawelmwo wrote: »
    pawelmwo wrote: »
    I've received the scale. The lip seems angled up and didn't offer a lot of clearance for the stylus. Is yours more flat wondering if it's defective ? The scale seemed accurate per 5 gram calibration weight. I set my tracking force to 2 grams which was just a little over the 1.5 setting on the actual markings on the turntable. The 2 marking was closer to 2.5 grams.
