Polk LSiM 705 & 707 towers just went on sale (7/16/19)! Which to get, and why?
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Thanks. The only way to know for sure is to ask Denon, but their reluctance to publish a 5 channel power spec makes me think getting such information from them would be difficult.
  • Landmonster
    Not to detail the thread.
    Any amp advice for this proposed set-up?
  • marvda1
    marvda1 Posts: 4,880
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • rooftop59
    rooftop59 Posts: 7,987
    I think this would make them sing nicely: https://www.ebay.com/itm/Parasound-HCA-1205A-5-Channel-140-watts-Amplifier/183877919639?epid=66783576&hash=item2acffa6397:g:MLEAAOSwxM1dJtiV
    Game Room 5.1.4:
    Bedroom 2.1
    Clipdat Posts: 12,620
    Bryston also a good option for the LSiMs.
  • joecoulson
    joecoulson Posts: 4,943
    Skip..tusk tusk
    Always peddling the T+A
  • ken brydson
    ken brydson Posts: 8,658
    joecoulson wrote: »
    Skip..tusk tusk
    Keiko worthy...
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    I have the 705s & 706 on the way with a cheap Yamaha receiver and was also wondering which amp would be ideal (any options for lower price range?)
  • joecoulson
    Maybe a used ADCOM from CL
  • BlueFox
    BlueFox Posts: 15,251
    Been a while since I paid much attention to HT, but I would get separate pre-amp and amplifier. Figure around $5K for a start. You get what you pay for.
  • mrloren
    mrloren Posts: 2,456
    For new, Emotiva is the starting point and it all goes up from there.
    A nice Marantz 8802 pre with a good Parasound amp is ideal
  • marvda1
    @landmonster, did you get achance to go listen to the sonus fabers ?
    Puritan PSM156
  • juice2544
    juice2544 Posts: 22
    mrloren wrote: »
    Can I keep my current tsr 5830 and add either Parasound 2125v2 150w, Marantz MM7025 140w, or Emotiva XPA 2 or 3 Gen3? (will the LSIM 706 need to be on an amp? Sorry, trying to grasp the basics of what I need to get it running with hopefully minimal cost)
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to Club Polk Juice. Unfortunately, your Yamaha doesn't have preouts to add a separate amplifier. You will have to save more money, and replace it with a much better receiver. Denon, Marantz, Pioneer are favorites around here. Here are a few to take a look at that would fit the bill.
    https://www.accessories4less.com/make-a-store/item/denavrx3400h/denon-avr-x3400h-7.2-ch-x-105-watts-a/v-receiver-w/heos/1.html
    https://www.accessories4less.com/make-a-store/item/marsr5012/marantz-sr5012-7.2-ch-x-100-watts-a/v-receiver-w/heos/1.html
    https://www.amazon.com/Marantz-SR5013-7-2-Compatibility-Streaming-Automation/dp/B07FMPVMRL/ref=sr_1_3?keywords=marantz+receiver&qid=1563718184&s=gateway&sr=8-3
    These will do until you are able to get a separate amp to add to it.
  • Geoff4rfc
    Geoff4rfc Posts: 2,165
    cfrizz wrote: »
    Welcome to Club Polk Juice. Unfortunately, your Yamaha doesn't have preouts to add a separate amplifier. You will have to save more money, and replace it with a much better receiver. Denon, Marantz, Pioneer are favorites around here..
    Crazy how Amazon is growing with availability!!! Here's another choice from AC4L @juice2544 https://www.accessories4less.com/make-a-store/item/marmm7055/marantz-mm7055-5-ch-x-140-watts-power-amplifier/1.html
    Sorry for derailing your thread @Landmonster
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • joecoulson
    I have the SR5013 and it’s a great inexpensive HT option.
  • Landmonster
    No worries, and thanks for the input so far. It seems clear that the 707s now will sound better than the 705s, given appropriate amplification. So, that would be my preferred long-term goal.
    The problem is, however, is that I can't afford "proper amplification" (ie. an expensive amp) and also 707s at the same time without going into debt. :'( I could swing it sooner with a pair of 705s, since they are about $520 cheaper.... and I could get a decent 2 channel used amp.
    As an update, Adorama just dropped the price the on these speakers again. Lol.... see link here:
    https://www.adorama.com/g/polk-audio-LSiM-series-sale?sdtid=12992437&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
    I'm still trying to make sense of my options, given my budget constraints.
    Options:
    1. Get the 707s, wait several months to get an amp.
    2. Get the 705s, get an amp much sooner.
    3. Get an amp now to power my 703/706c combo, and wait to get towers later.
    Questions:
    1. Does anyone know when these LSiM speakers will truly no longer be available for sale new? I keep hearing rumors that these will be discontinued at some point.
    2. Would either the 705s or 707s be passable with the Denon? Or would both sound equally frustrating/under-powered/flat, etc?
    3. Would the 703/706c combo benefit from a power amp? Or does the main benefit of the power amp pertain to the 705 or 707 towers?
  • Landmonster
    Landmonster Posts: 79
    edited July 2019
    rooftop59 wrote: »
    I'm sure that is a nice amp, and the price seems good. However, other comments have led me to think the 707s sound best with 250+ real watts per channel.
    Edit: However... I'm sure that would be a pretty nice amp for the 703s? One option I haven't fully explored would be to buy more 703s for all around, use an amplifier like that one.... then add a sub sooner.
  • Landmonster
    DSkip wrote: »
    Nothing has ever lit up LSiM speakers like the T+A amps. You might be able to find an older amp for a decent price.
    What is a T+A amp? I'm not familiar with the terminology there.
    txcoastal1 Posts: 13,134
    DSkip wrote: »
    It's not a term, but a manufacturer of high-end audio.
  • marvda1
    DSkip wrote: »
    https://www.ta-hifi.de/en/?doing_wp_cron=1563739678.2817680835723876953125
    Puritan PSM156
  • Landmonster
    marvda1 wrote: »
    DSkip wrote: »
    Ah ok. The 3000 HV amp comes in at a cool $19,000.
    If I had that kind of cash for an amp, I'd probably be looking at speakers better than LSiMs, and a have a dedicated media room with all sorts of treatments.
  • Landmonster
    This is one amp I was considering. Not sure if it is well regarded here, or not.
    https://www.monoprice.com/product?p_id=15593
    F1nut Posts: 49,848
    Geesh dude, just buy something.
  • cfrizz
    Monoprice just got into the amplifier market, and as far as I know no one on here owns one. We all have to start somewhere.
    It's got good power and 5 channels, which is the most important thing. If you can afford it as well as whichever of the LSIM towers you decide on go for it.
  • mrloren
    I'd get the 707 at that price and save for a good amp. Emotiva are not bad (I use one and like it). I almost got the Monoprice but a couple of reviews saying they get burning hot stopped me.
    F1nut Posts: 49,848
    edited July 2019
    Monoprice amps are made by ATI.
    There's nothing wrong with a class A/B amp getting hot. Generally, that means it's biased to class A, which is good thing. A bad reason for one to run hot is insufficient heatsinks. Looking inside the ATI/Monoprice it's almost all heatsinks, so it must be biased to class A since it runs hot.
    F1nut Posts: 49,848
    I forgot to mention another reason for an amp like that to run hot. People shove them inside cabinets without allowing for proper airflow. An amp needs a minimum of 6 inches above with the cabinet open front and back.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    I recommend Outlaw for about the same money as Emotiva or monoprice.
    https://www.outlawaudio.com/products/7000x.html
