Polk LSiM 705 & 707 towers just went on sale (7/16/19)! Which to get, and why?
Thanks. The only way to know for sure is to ask Denon, but their reluctance to publish a 5 channel power spec makes me think getting such information from them would be difficult.Proud and loyal citizen of the Digital Domain and Solid State Country!
Not to detail the thread.
Any amp advice for this proposed set-up? -
go by audio concepts in dallas and listen to these.
https://audioconceptsonline.com/portfolio-items/sonus-faber-concerto-domus-speakers/Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Landmonster wrote: »Not to detail the thread.
I think this would make them sing nicely: https://www.ebay.com/itm/Parasound-HCA-1205A-5-Channel-140-watts-Amplifier/183877919639?epid=66783576&hash=item2acffa6397:g:MLEAAOSwxM1dJtiVLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bryston also a good option for the LSiMs.
Skip..tusk tusk
Always peddling the T+A
joecoulson wrote: »Skip..tusk tusk
Keiko worthy... -
I have the 705s & 706 on the way with a cheap Yamaha receiver and was also wondering which amp would be ideal (any options for lower price range?)
Maybe a used ADCOM from CL
Been a while since I paid much attention to HT, but I would get separate pre-amp and amplifier. Figure around $5K for a start. You get what you pay for.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
For new, Emotiva is the starting point and it all goes up from there.
A nice Marantz 8802 pre with a good Parasound amp is idealWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Family Room:LG QNED80 75", Onkyo RZ50 Emotiva XPA3 GEN3 Oppo BDP-93,Sony UBP-X800BM. Main: Polk LsiM 705 Center: Polk LSiM 704CFront High/Rear High In-Ceiling Polk 80F/X RT Surrounds: Polk S15 Sub: SVS SB-17 ULtra
Working Warehouse; Denon AVR-3312ci , Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
@landmonster, did you get achance to go listen to the sonus fabers ?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Can I keep my current tsr 5830 and add either Parasound 2125v2 150w, Marantz MM7025 140w, or Emotiva XPA 2 or 3 Gen3? (will the LSIM 706 need to be on an amp? Sorry, trying to grasp the basics of what I need to get it running with hopefully minimal cost)For new, Emotiva is the starting point and it all goes up from there.
A nice Marantz 8802 pre with a good Parasound amp is ideal -
Welcome to Club Polk Juice. Unfortunately, your Yamaha doesn't have preouts to add a separate amplifier. You will have to save more money, and replace it with a much better receiver. Denon, Marantz, Pioneer are favorites around here. Here are a few to take a look at that would fit the bill.
https://www.accessories4less.com/make-a-store/item/denavrx3400h/denon-avr-x3400h-7.2-ch-x-105-watts-a/v-receiver-w/heos/1.html
https://www.accessories4less.com/make-a-store/item/marsr5012/marantz-sr5012-7.2-ch-x-100-watts-a/v-receiver-w/heos/1.html
https://www.amazon.com/Marantz-SR5013-7-2-Compatibility-Streaming-Automation/dp/B07FMPVMRL/ref=sr_1_3?keywords=marantz+receiver&qid=1563718184&s=gateway&sr=8-3
These will do until you are able to get a separate amp to add to it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Welcome to Club Polk Juice. Unfortunately, your Yamaha doesn't have preouts to add a separate amplifier. You will have to save more money, and replace it with a much better receiver. Denon, Marantz, Pioneer are favorites around here..
Crazy how Amazon is growing with availability!!! Here's another choice from AC4L @juice2544 https://www.accessories4less.com/make-a-store/item/marmm7055/marantz-mm7055-5-ch-x-140-watts-power-amplifier/1.html
Sorry for derailing your thread @Landmonster
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3 -
I have the SR5013 and it’s a great inexpensive HT option.
No worries, and thanks for the input so far. It seems clear that the 707s now will sound better than the 705s, given appropriate amplification. So, that would be my preferred long-term goal.
The problem is, however, is that I can't afford "proper amplification" (ie. an expensive amp) and also 707s at the same time without going into debt. :'( I could swing it sooner with a pair of 705s, since they are about $520 cheaper.... and I could get a decent 2 channel used amp.
As an update, Adorama just dropped the price the on these speakers again. Lol.... see link here:
https://www.adorama.com/g/polk-audio-LSiM-series-sale?sdtid=12992437&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
I'm still trying to make sense of my options, given my budget constraints.
Options:- Get the 707s, wait several months to get an amp.
- Get the 705s, get an amp much sooner.
- Get an amp now to power my 703/706c combo, and wait to get towers later.
Questions:- Does anyone know when these LSiM speakers will truly no longer be available for sale new? I keep hearing rumors that these will be discontinued at some point.
- Would either the 705s or 707s be passable with the Denon? Or would both sound equally frustrating/under-powered/flat, etc?
- Would the 703/706c combo benefit from a power amp? Or does the main benefit of the power amp pertain to the 705 or 707 towers?
I'm sure that is a nice amp, and the price seems good. However, other comments have led me to think the 707s sound best with 250+ real watts per channel.
Edit: However... I'm sure that would be a pretty nice amp for the 703s? One option I haven't fully explored would be to buy more 703s for all around, use an amplifier like that one.... then add a sub sooner. -
Nothing has ever lit up LSiM speakers like the T+A amps. You might be able to find an older amp for a decent price.
What is a T+A amp? I'm not familiar with the terminology there. -
Puritan PSM156 -
Ah ok. The 3000 HV amp comes in at a cool $19,000.
If I had that kind of cash for an amp, I'd probably be looking at speakers better than LSiMs, and a have a dedicated media room with all sorts of treatments. -
This is one amp I was considering. Not sure if it is well regarded here, or not.
https://www.monoprice.com/product?p_id=15593 -
Geesh dude, just buy something.
Put the front 3 on this amp
https://www.accessories4less.com/make-a-store/item/marmm8077/marantz-mm8077-7-ch-x-150-watts-power-amplifier/1.html2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Landmonster wrote: »This is one amp I was considering. Not sure if it is well regarded here, or not.
Monoprice just got into the amplifier market, and as far as I know no one on here owns one. We all have to start somewhere.
It's got good power and 5 channels, which is the most important thing. If you can afford it as well as whichever of the LSIM towers you decide on go for it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I'd get the 707 at that price and save for a good amp. Emotiva are not bad (I use one and like it). I almost got the Monoprice but a couple of reviews saying they get burning hot stopped me.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Monoprice amps are made by ATI.
There's nothing wrong with a class A/B amp getting hot. Generally, that means it's biased to class A, which is good thing. A bad reason for one to run hot is insufficient heatsinks. Looking inside the ATI/Monoprice it's almost all heatsinks, so it must be biased to class A since it runs hot. -
I forgot to mention another reason for an amp like that to run hot. People shove them inside cabinets without allowing for proper airflow. An amp needs a minimum of 6 inches above with the cabinet open front and back.
I recommend Outlaw for about the same money as Emotiva or monoprice.
https://www.outlawaudio.com/products/7000x.htmlOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
