Vintage Monitor and SDA Speaker Deals
They're calling them model "8" also.
@lightman1 set me straight on that one awhile back .
I think I might owe him money.
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Found some Australian polks: https://losangeles.craigslist.org/lac/ele/d/pasadena-polk-audio-speakers-left-right/6932756724.html
my 3.1TLs
I will fix your shifted magnets for free.
SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
Those look nice. -
Michigan Polkies! Not a smoking deal, but looks to be minty 3.1TL's for 8 hundie!
https://www.ebay.com/itm/RARE-Polk-Audio-SRS-3-1TL-Matched-SPEAKERS-ORG-MANUAL-MONSTER-CABLES/333265352265Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Verb has already sent an offer....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Fix from the back side, but they're asking pristine price for something that is less than perfect. Only real thing going for them is the peerless...
I see the tears on both woofers, otherwise, great purchase if the tweeters sound great and the other 2 woofers are ok.
I would've bought them too. Maybe you can seal those tears.
Yea, I thought that might be their demise.
IIRC Midwest Speakers now sells surround kits for the MW’s!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Swap in a CRS XO and make mini 2As (just for giggles).
If the tear is just in the surrounds, midwest audio sells replacements. I had a hole on a woofer for my sda 2bs. I just ordered some rubbers and was good to go.
https://www.midwestspeakerrepair.com/shop/speaker-repair-kits/refoam-kits-by-brand/polk-audio-1-specialty-refoam-kits/polk-audio-6-5-inch-rubber-surround-kit-r6-1/The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I installed a couple of those surrounds while also re-setting the magnets for someone, good quality.
my 3.1TLs
Wow, that's some good negotiating right there! I'd say those stands alone are worth close to $50.Well I took a look at them and sure enough they weren't pristine. Not beat up either, but my biggest issue was the rubber surround. The seller was eager to move them since he was in the process of moving. After some negotiating we settled on 60 dollars and shook hands to finalize the deal.
If you part them out, I'd like to be first in line on purchasing those tweeters. ok?
And I'd like to purchase the stands from you...
And put me in line for mid-woofers please
Looks like a pretty clean pair of 3.1TL's, including new RDO-198's.
https://www.ebay.com/itm/Nice-pair-of-Polk-Audio-SDA-SRS-3-1TL-speakers-with-upgraded-RD0198-tweeters/233291041361?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=8e08ab6f4ffd43139b0ce3ecff6ed2e9&pid=100675&rk=1&rkt=15&sd=233291041361&itm=233291041361&pg=2481888&_trksid=p2481888.c100675.m4236&_trkparms=pageci:0d597630-aa21-11e9-bc52-74dbd1801d65|parentrq:0a36ba5916c0a4e8e0adde42ffec071b|iid:1 -
Mike Reeter wrote: »Looks like a pretty clean pair of 3.1TL's, including new RDO-198's.
Mine now! -
Yes.
Road trip to GA.
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Yep, ever need any magnets re-set just let me know!
my 3.1TLs
Not sure this is really a deal, what would be a good price?
https://sandiego.craigslist.org/esd/ele/d/el-cajon-polk-sda-1a-speakers/6938351273.html
SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200 -
imho too high -
Monitor 10s. NE of Baltimore. $200
No affiliation
https://images.craigslist.org/00303_byPkS9FFsLX_600x450.jpg
Interesting: the price went up since I saw them last.
