In need of some construction advice.
I am torn on this decision, and would like some input from you guys, as I hold a great deal of respect for your opinion.
My conundrum lies in the door swing in the home theater I am building. In the sketches below, you can see that the entrance to my new theater room is in the front right corner (I would have preferred a mid-wall entrance, but that was not an option). If I have the traditional in-swing door (32”), that leaves only 70” between the front speakers, after allowing for the door swing and rest against the front wall, and symmetrical speaker placement.
What I want to do, is install the door as an out-swing, which easily allows for about 88” between the speakers. I know it is not traditional for the door to a room to swing out into the hallway, but in this application, I think it makes a lot of sense. I checked local codes, and this poses no violation. The hallway is not narrow at all, at 40”, so the door resting out there would pose no constriction of movement into the room.
As an added bonus, I already have a 32” right hinge door, so this would save $70 on construction.
What think you all? Is this something I will regret later, or should I go for it?
Too much stuff to keep track of.
Currently enjoying: Legacy Focus 20/20, McCormack DNA 225, Bill D C1, Oppo 105
  • michaeljhsda2michaeljhsda2 Posts: 1,937
    Any way to install a pocket door?
    SDA SRS 1.2TL's
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 2B TL's w/RD0198-1's
    Yaqin MC-30L integrated tube amp
  • daddyjtdaddyjt Posts: 1,101
    Unfortunately no:-(
    Bummer. Too bad you can't relocate the light switches to the wall to the left of the door.
    SDA SRS 1.2TL's
  • Tony MTony M Posts: 8,375
    edited July 9
    I like your idea. B)
    Just put PULL and PUSH plaques on the door. You'll be fine and you're doing great by planning ahead "on paper". ;)
  • verbverb Posts: 8,240
    Go for it! Out swing into the hallway, no big, IMO.
    Basement: Polk SDA SRS, Cary SLP-05 Pre, Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Silnote Morpheus Ref2 Digital Cable, Marantz SA-14 SACD, McIntosh MC300 Amp, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: , Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub
  • JayMXJayMX Posts: 246
    @daddyjt - if you need lighting let me know. I work as a factory rep for many lines of lighting and controls. Can get you factory direct pricing. Happy to help if I can! Fun project. I built out my basement a couple of years ago. Super rewarding when it’s all done. And for what it’s worth, I think the outswing would be the best solution!
    Current Collection:
    Monitor 4a (Peerless), Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL2000), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s, Dynamat, Sonicaps, Mills, H-nuts), SDA CRS+ (SL2000), RTA12c (194's), SDA SRS 2 (SL2000)
    Repair pile: SRS 3.1TL (198’s), RTA 11T's, (1) lonely RTA 11TL to become a center channel... someday...
    Pairs that have passed through:
    Monitor 5b (SL1000), Monitor 10a (Peerless), Monitor 10c (3x pair), RTA8, RTA8TL, SDA2, SDA2a, SDA1b, SDA SRS2
    ...and more to come, it’s a sickness.
  • EmlynEmlyn Posts: 2,530
    Nothing wrong with an outswinger. I have one for a smallish bedroom that makes the room easier to use.
    A question though. Do you really need a door at all? Unless the room is sound proofed, chances are the sound produced in the room will be heard throughout the house regardless of whether a door is there or not.
    Looks like it'll be a nice space!
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Sonic Frontiers Line 3 Preamp; Classe Model 25 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio Power Director; MIT S1 Cables
    3. Polk LSiM703; Parasound JC2BP and A21; Sony 48" 4K TV; Wyred4Sound DAC 2; Oppo 203; Squeezebox Touch; MIT S3 cables
  • EndersShadowEndersShadow Posts: 16,936
    JayMX wrote: »
    Define lighting? Like Insteon.... Phillip Smart bulbs, etc...
    JayMX wrote: »
    Thanks jay - are there any cool options for LED can lights and dimmers? I have six cans in the ceiling, arrayed in pairs (front, mid and rear), each pair with their own switch...
    Emlyn wrote: »
    Although I did insulate every wall with R13, and R19 in the ceiling, it will be far from soundproof - that ship sailed about 5 amps and two velodyne subs ago, lol. I insulated more for deadening the walls for the sound inside the room. I want a door more for acoustics, I think, to keep sound reflections as equal as possible between L+R. On that note, I HATE the small intrusion above he door from the HVAC, but I didn’t want to run the drop down the entire width of the room. The perils of basements...
    How about a sliding "barn-door" type?
    Now that’s an idea I hadn’t considered... I know what I’ll be googling tonight.
    Any experience with them, or suggestions?
  • mrbironmrbiron Posts: 5,148
    Friendly GC here ;)
    The swing on the door does not matter one bit. Actually, an outswing door would be considered “better” for a means of egress in case your HT catches fire and you need to get out in a hurry.
    Install it whichever way you want. It’s your home and not a commercially ADA/FHA complaint space.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Crack w/Speedball, Senn's MD HD600
  • pitdogg2pitdogg2 Posts: 14,923
    daddyjt wrote: »
    All the rage now that totally slipped my mind as well
  • BlueFoxBlueFox Posts: 12,294
    That is the door type in my bedroom’s bathroom.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
  • kharp1kharp1 Posts: 3,411
    daddyjt wrote: »
    I think this is a great idea.
    Main System:
    Joule-Electra LA 100 MKIII Upgraded by Rich Brkich Pre
    Butler Audio TBD 2250 Amp
    PS Audio DirectStream DAC and MemoryPlayer Transport
    LSA-1 Statement
    SVS SB4000 & SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
    Backup Gear:
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
  • aprazer402aprazer402 Posts: 1,542
    Doors that swing out would be fine. :)
    BlueFox wrote: »
    No Bud that is a pocket door.
    Well, it slides closed and open. What is a sliding door?
    Lumin X1
    Sony XA-5400ES SACD
    Rails are outside of the wall, like on barns all hardware is exposed
  • nooshinjohnnooshinjohn Posts: 21,586
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds.
    Saying that it's "too hard" to pursue your dreams is no different than admitting to yourself that you are too lazy to achieve them.
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
    They're very popular right now. Many styles to choose from. Shaker cabinets are popular now too.
    Okay. For what the question was about it appears the pocket door would be the best option. Learn something every once in a while on Club Polk. :)
    Lumin X1
    Sony XA-5400ES SACD
    BlueFox wrote: »
    Yes but due to construction probably it is not possible according to @daddyjt
    What's in the little room between the hallway and "closet" in the media room? Is that a bathroom, or, a closet? That could be an option for entry.
    Main System:
    LSA-1 Statement
    SVS SB4000 & SB2000
    Secondary Rig:
    Analysus Plus Oval
    Backup Gear:
    Marantz SA-14S1
    kharp1 wrote: »
    That’s the closet for the guest room - not really an option for entry.
    To have the full 16’ length in the HT, that room had to be at the end of the basement - the guest room is only about 12’5” x 14’, as the 3’6” hallway runs that span. Media room (closet) is 5’x8’, and guest closet is about 5’x5’.
    Hippie beads
    Yet another option I had not considered :smile:
    Might be fun seeing how much they move during the club scenes in John Wick...
    edited July 10
    Any and all! Primarily commercial, so if you need an explosion-proof exit sign I can hook you up! 😂
    daddyjt wrote: »
    In my basement I used some LED downlights from Juno that dim to warm like an incandescent would and they dim very low - almost to a candlelight glow with no flicker. They also offer several nice trim options.
    https://juno.acuitybrands.com/products/detail/660670/juno/ic1rled-600lm-wd-remodel-housing/warmdim-led-4in-round-remodel-housing
    I like using the remodel cans because you can easily remove them from below for service or replacement and if you plan your A/V cable paths, they provide a good way to access things if you need to re-pull wiring or make changes. If you want to see them dim, you’re welcome to stop by for a demo, but you can’t make fun of my poor man's audio rig!
    That said, from your photo above it looks like you may have already installed some (6” ?) cans. If so, you can get 6” retrofit LED modules from Juno with the same warm dim technology.
    https://juno.acuitybrands.com/products/detail/660784/juno/j6rl-wd-trim/warmdim-led-6in-round-retrofit-downlight
    If you’ve used a different diameter, let me know and we'll explore other options.
    For wallbox dimming, Lutron is usually the best route. Their Caseta line is very nice. https://www.casetawireless.com/ I can check on compatibility with the Juno fixtures if you want to explore them. I’ve also heard good things about Legrand's Radiant line as well. https://www.legrand.us/radiant/products/smart-lighting.aspx?gclid=EAIaIQobChMIo4CRx8mp4wIVA9vACh1N2g5wEAAYASADEgIgpfD_BwE
    Both of those systems can be tied to Alexa/Google/HomeKit for that extra bling factor.
    We have tons of options if these don’t float your boat. Happy to help out a neighbor and fellow junkie!
    Current Collection:
Howdy, Stranger!
