Ordered a PS Audio S300 today ....
gyosa
gyosa Posts: 699
Took the plunge ...
Gonna use it on the Salks ....
Should be here sometime next week ......
I appreciate everyone’s input.....
BK
Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
PS Audio S300 - sitting in the closet for now …
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
«13
    Clipdat Posts: 12,608
    Congrats, nice choice. What preamp will you be using with it?
  • gyosa
    gyosa Posts: 699
    Maybe my ps audio 4.6 .... have always used it in straight wire mode ...
    Maybe nothing .....
    May just connect the wxc-50 directly to the amp .... that’s what the straight wire mode on the 4.6 does anyway.....
    May connect it to the Onkyo’s pre-outs......
    Problem is it’s going in the den which is where the tv is ...
    Currently running tv and Blu-ray player thru the onkyo ... wife is electronically illiterate, so she likes the functionality of the hdmi ARC and using one remote to control everything ...
    May put a switch between onkyo/S300 and speakers to switch the Salks between onkyo and s300 depending on whether using tv or dedicated 2 channel music ....
    Dunno , gonna have to play with it and see what works best ....
    Bk
  • joecoulson
    joecoulson Posts: 4,943
    Do you have a harmony remote?
  • gyosa
    gyosa Posts: 699
    edited July 2019
    No ,
    That’s not the issue ....
    Need to run the s300 and salks as a dedicated 2 ch system , and also need to run the tv and stuff on the salks as well ... switch will do the trick ...just switch speakers between s300 and onkyo as needed ...
    Issue is volume control when in 2 ch mode , as well as switching between tv , streamer , chromecast and blue ray- with DISH remote .... all equipment is in cabinet with doors ...
    Onkyo has HDMI ARC / CEC control and will control ALL components as is set up now - even streamer...
    Gonna try hooking up s300 to onkyo pre-outs first - run salks off of s300... onkyo amp section will be dormant - I hope - and then I gain all the functionality of the onkyos preamp/processor...
    If that sounds like **** , I’ll use a switch .... prob get better 2 ch sound that way anyway...
    what I need is a 2ch preamp with HDMI ARC/CEC - at a reasonable price- but apparently they don’t exist....
    my streamer , Yamaha wxc-50 , has an optical input .... could do that for tv - run everything into tv , then fron tv to Yamaha via optical .... but then the dish remote won’t control it ..... this is how the bedroom system is set up .... works great , but less than ideal for wife .... she can’t figure it out !😊
    As I said , wife and kid are hifi illiterate ....
    They need easy peazy....
    Bk
    joecoulson wrote: »
    Post edited by gyosa on
  • gyosa
    gyosa Posts: 699
    edited July 2019
    I think we can do that ....👍
    Arlington , right ?
    I’m in M Streets ... lower Greenville av....
    Bk
  • gyosa
    gyosa Posts: 699
    edited July 2019
    My goal was to have decent amplification for these outstanding Salks without breaking the bank - got a wife ya know - for 2 ch listening...
    A21 will not fit in cabinet
    Most of my listening is done either in bedroom or poolside - not the den ...
    Bedroom system is fantastic with the A21 and 1c’s.....
    Pool is fantastic as well - for a pool - with the B&K and BA’s...
    So the den is primarily TV , but I want an amp that will do the salks justice for music....
    AVR’s suck
    Bk
  • halo
    halo Posts: 5,616
    gyosa wrote: »
    AVR’s suck
    Bk
    A dedicated preamp with an HT pass through is what you need. You'll get the best of both worlds for your dedicated 2-channel listening and the ease of use on the HT for your wife :)
    gudnoyez Posts: 8,066
    edited July 2019
    Is the only reason the A21 is being replaced is due to it not fitting in the cabinet? I have read some good reviews on that S300. Looking forward to hear your thoughts on the results of the S300 and your A21 once hooked up to your Salks.
  • displayname
    displayname Posts: 1,133
    edited July 2019
    gyosa wrote: »
    Arlington , right ?
    Bk
    Can I crash this party? Always wanted to hear these.
    I'll bring beverages :)
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
    I thought about that S300, Audio Advisor had a demo unit for sale a while back that I was interested in. I will be waiting for the OPs impressions on it once he gets it hooked up.
  • jdjohn
    jdjohn Posts: 3,004
    DSkip wrote: »
    After you get it in and broken in, I hope you'll consider bringing it over one afternoon so I can put it through its paces. o:)
    And rip it a new one, Skip? ;)o:)
  • kharp1
    kharp1 Posts: 3,453
    I'm interested in you hearing it, Skip. I've always enjoyed our conversations on audio gear. We often hear things the same, with a few exceptions, and I trust your ear and honesty. I know you'll be able to relate it to something we've both heard and can give me what I would consider a "best next to my own ears" synopsis.
  • gyosa
    gyosa Posts: 699
    I think what I’ll do is hook it up to pool system for couple hundred hours to burn in 10 hrs a day or so .... then hook up to den ...
    Don’t really have interest in it till it’s broken in ...😊
    But , yeah , let’s let skip put it through it’s paces on some high quality gear ....
    The more the merrier , especially if alcohol is involved ......
    Bk
  • marvda1
    marvda1 Posts: 4,873
    i can bring some cups B)
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • gyosa
    gyosa Posts: 699
    edited July 2019
    Sounds like a party !
    BK
  • gyosa
    gyosa Posts: 699
    Hey ,
    120 posts !
    Only took 18 months !
    Am I family now ?
    Bk
  • jdjohn
    jdjohn Posts: 3,004
    kharp1 wrote: »
    I feel this way with Joe and Drew. We have, all three, gone all-in on this PSA gear, and shared our experiences on- and off-line compared to other gear.
  • kharp1
    kharp1 Posts: 3,453
    jdjohn wrote: »
    kharp1 wrote: »
    Yeah, but you guys don't REALLY count...isn't one of you Canadian, or something? :)
  • joecoulson
    No not at all, we are just normal and down to earth. Quite different it seems.
  • GlennDog
    GlennDog Posts: 3,087
    gyosa wrote: »
    Took the plunge ...
    BK
    Following...
    jdjohn wrote: »
    I might be joining the 3 amigos!
    Or moving on to something similar/cool running for the summer months.
    No one really thinks of Michigan as a warm climate. But when summers temps and heat index are close to triple digits and humidity is 85% . . . it can be a little like south Florida at times.
    All these tubes don’t generate this much heat in the winter!!
    (I know they do!)
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    gyosa wrote: »
    Hey ,
    120 posts !
    Am I family now ?
    Bk
    For sure brother, although you gotta pick up the pace a bit! We expect at least 100 posts from you just on this S300! Pics too! :smile:
  • gyosa
    gyosa Posts: 699
    Showed up today .....
    Bk
  • joecoulson
    nooshinjohn Posts: 25,101
    Open the damn box already!
  • gyosa
    gyosa Posts: 699
    Ok ......
    Ha ha ...
    Bk
    It appears you selected the wrong color, I am terribly sorry for your grave mistake.
  • gyosa
    gyosa Posts: 699
    Just kidding on that last one 😊
    Damn ,
    Heavier than I expected .....
    Question is .....
    Which is OFF , “0” or “-“ ?
    Appears to be very solidly well built...
    Bk
  • gyosa
    gyosa Posts: 699
    edited July 2019
    Yeah ...
    He had a spare silver one on hand at a lower price than black .....
    Gonna go in a cabinet anyways, so no one will see my mistake !
    Bk
    Clipdat wrote: »
    edited July 2019
    gyosa wrote: »
    Question is .....
    Which is OFF , “0” or “-“ ?]
    0 = off
    - = on
    And use the balanced XLR inputs if at all possible.
  • joecoulson
    See Drew, I’m not the only one. 😂
