Small Form Factor Power Amp - Suggestions?
Verb, I'm sensing that you may be a full blown junkie!
I can't argue that! I love it! And, the eagle(s) have landed. FedEx delivered em today! Operation Amp Camp Amp is underway!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I wonder if the Mrs will notice?
Temporary staging, probably have to move em down to either side of the monitor riser, as these little heaters may affect the monitor!
But rather inconspicuous, I may say!
You made a great choice Dave. I think you'll enjoy them.
Thanks Skip! Still keeping an eye on those Ampinos!
Waiting on a review
I don't, sorry.
Not a clue. No markings on the outside. Would the internals tell ya? I can certainly pop the hood on em!
Ok I just had to look! Popped the hood! Very elegant in it's simplicity.
Some markings:
Hopefully that'll help! Let us know professor!
Looks are all that matter. Studies show that is 85% of sound. -
Some markings:
Sez "1b" and 2013 -- so I assume that's the original morph (6-ish watts).
You know the story of this design, yes?
http://www.firstwatt.com/pdf/art_amp_camp_1.pdf
Current version is 1.6
https://guides.diyaudio.com/Guide/Amp+Camp+Amp+V1.6+Build+Guide/5
Just bits and pieces. Now that I’m a proud owner, time to get my read on! Thanks for the links Mark!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
It it/they are good sounding.
An educational experience to hear a soiled solid state amp that is designed (in many respects) like -- and that measures like -- a classic single-ended vacuum tube (triode) amplifier. The sound is more similar than different, and the heat produced by a single-ended transistor amp like the ACA is a good reminder that it is not the filaments that make vacuum tubes hot, it's the power that the plates dissipate
Is that in the ballpark? -
IIRC, they’re 35 hundie brand new.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I've noticed that for what ever reason there doesn't seem to be shortage of them on the used market even though they're a fairly new amp. I can only guess they're not meeting the owner's expectations? -
Well I finally had a chance this week to transform my office rig. Installed the new monitor riser on my desk. And now retired are the Marantz AMP-1, and CD-1, which are very nice pieces BTW!
My new rig
EAR 834L Pre-Amp
EAR Acute CD Player
PASS ACA Monoblocks
NS Intenso DAC
WW Spaceport Power Conditioner
Everything else remains the same (speakers, cables, etc.)
All I can say is wow! The EAR 834L really increases the 3D image of my nearfield! Running Tidal through the NS DAC is, well, again wow! Of course more impressions to come, but for now, enjoying it!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
So, been playing this rig for over an hour, and yes the little PASS amps are pretty warm on top! Sides are fine. That's class A for ya! As a precaution, I'm gonna a piece of oak board underneath each, so as not to affect the desk!
Get you some marshmellows to better use that excess heat
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
we made s'mores last night, come to think of it -- not on the SE 2A3 amp, though.
It would be possible, however.
Might not be necessary? Heat rises, right? Then again, an ounce of prevention is worth a pound of cure. Maybe something less ignitable than wood for a base, like some ceramic tiles?HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
They do fit in there just about perfect.
Yep mostly! I lifted one of the little heaters and tested the surface of the desk. Not bad, but still warm. Over time it may deteriorate the wood finish, maybe, but better safe than sorry!
Oak will be fine. It takes a LOT of heat for it to ignite. Besides it will give the marshmallows a nice smokey flavor.Gustard X26 Pro DAC
Absolutely, I agree 100% measure once, cut twice.
