Interconnect cables, where best cables are more important?
I have a few different grades os RCA interconnect cables.
Just wondering, where should the best cables be places to get the best SQ.
1- Dac>Pre amplifier
2- Phono preamp>Pre amplifier
3- Preamp>Power amplifier
What would be the priority and why?
  • kharp1kharp1 Posts: 3,463
    This is just me, but, I think if you believe that cables make a difference (and I do) then they're all important. Trial and error as far as placement.
  • joecoulsonjoecoulson Posts: 4,114
    I agree Kerry and I also agree Skip (amazingly) that replace source-pre-amp with the same brand/type of cables as not to confuse things and get away from cable differences and just focus on source/component differences.
    Auralic Vega G1/Rega TT/Denon SACD - Parasound P6 - PS Audio M700x2 - Elac Adante AF-61 - AQ Niagara 5000 - SVS SB16u
  • corticocortico Posts: 593
    edited May 2019
    Thanks folks! I notice a cumulative effect with the cables; the more I add the better it sounds. The speaker cables made big difference, so did the pre to power amp. I am thinking that upgrading all source cables with matching MIT wire is a no-brainer to me...
  • ClipdatClipdat Posts: 7,604
    Once you go MIT you never go back!
    Oh wait, I did. Nevermind.
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
  • F1nutF1nut Posts: 43,652
    Clipdat wrote: »
    There's no accounting for your tastes.
  • daddyjtdaddyjt Posts: 1,177
    I agree that they are all important, but if you can only do one at a time, I would start with the lowest level signal first, as they are most susceptible to interference and/or distortion.
    Too much stuff to keep track of.
    Currently enjoying: Legacy Focus 20/20, McCormack DNA 225, Bill D C1, Oppo 105
  • tophatjohnnytophatjohnny Posts: 2,765
    edited May 2019
    This forum made me a believer, and while I never doubted the subject "Cables Matter" I never gave it real thought before Club Polk. There are a lot of great choices and trial and error will help only you to decide what your ears are hearing and which ever you decide on will be your best choice because you made that choice. ears don't lie.......they do get old though!!!! lol
  • verbverb Posts: 9,072
    Me too brother! I've come a long way since my home brew 12ga stranded wire speaker cables to the MIT Shotgun's!
    Even going from the MIT T2 to the Shotgun's was a huge improvement!
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
    edited May 2019
    Ah, you fellas make the mortal people feel like no matter what is done we will be condemn to mediocre performance.
    Just got a shotgun s1 interconnects, placed it between Pre and power, moved the T2 for the sources...
    Ok, say it! you just tried something else and the shotguns are [email protected] :D
    Kidding aside, sound got mellowed out, more definition, and dimension, I think.
    Finally can enjoy some recordings I though were bad...
    Try them between your source and pre. Then find another pair of S1's. Make sure you select the proper impedance setting.
    Sure thing. Pre has 30kOhms input impedance on unbalanced inputs and power amp100kOhms. Low impedance setting for the Pre, and Mid or Hight for the Power.
    Pre sounds best on low and power amp on mid impedance setting....
  • BlueFoxBlueFox Posts: 12,632
    That should be how you determine where the cable(s) go. Where they sound best. Of course, at some point you need to get a loom of the same cables between all components, including speakers.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    Stellar performance! missing a matching interconnect between phono pre and preamp, and a good digital coax between CD player and DAC...
  • vishma112vishma112 Posts: 5
    Thanks for sharing valuable information.It will help everyone.keep Post.
    <a href="https://lottoloots.com/kerala-lottery-guessing/">Kerala Lottery guessing</a>
  • mhardy6647mhardy6647 Posts: 24,616
    Spam-o-rama -- and using HTML instead of BB code.
    What is this world coming to?
Howdy, Stranger!
