Will my system work?
1356789
    Clipdat Posts: 13,100
    I still suggest just purchasing a quality subwoofer for now, and try running the speakers off the AVR first. If it's lacking in some major way, then get a 3 channel amp for the front speakers.
    F1nut Posts: 51,959
    edited May 2019
    Your AVR is your pre-amp.
    If you're dead set on SVS the SB4000 is more than enough.
  • kharp1
    kharp1 Posts: 3,453
    edited May 2019
    Clipdat wrote: »
    I agree with this. You will probably hear a considerable improvement by adding a high quality sub. Look at Rythmik, SVS and HSU as they are all good quality subs at reasonable prices. Do this first and then tell us what it sounds like to you.
    If you still want an amp at that point, well, there are a bunch of them available on the pre owned market. You'll have your pick.
    You eat an elephant one bite at a time.
  • mrloren
    mrloren Posts: 2,474
    edited May 2019
    Either the SVS SB4000 or SB16u will work. these are not small subs. I helped setup a 16U once, almost didn't pass the wife acceptance factor. The bass that came out was fantastic.
    The Outlaw amps are nice amps. I'd stay away from the Monolith stuff, get Emotiva way before Monolith.
    Get the sub before and amp or just go for broke and get em both. With a sub in the mix set the Cross Over on the AVR to 80HZ and let the sub do the low end. This will save a lot of power on the AVR.
  • cfrizz
    cfrizz Posts: 13,415
    Either one of those Outlaw amps will allow your speakers to operate to their full potential, as will either of those subs it just depends on how much money you want to spend.
    Your Yamaha will serve as your pre-amp.
    You will have one slamming system that you can enjoy for years when you are done.
  • Romo11
    Romo11 Posts: 101
    edited May 2019
    Ok, it looks like I’ll go with the sub first with the majority opinion going this way. Since this is my last system, I’m sure, do I get either the SVS SB4000 or the SVS SB 16 Ultra? Or do I go for two SVS SB 4000’s? It’s cheaper to get one of the SVS SB 16 Ultras but depending on your advice I will make my selection.
    You guys sure are a great help. Thanks!
    I forgot to mention that my room is 20X 24 going into the foyer and front door and steps up and down on one side. My house is a tri level and the only room (home theater) is on the second level. The foyer is small, only 6 X 5 on one 20 feet wall.
    Rob
    Post edited by Romo11 on
  • DaveHo
    DaveHo Posts: 3,583
    How open is your room to other areas of the house?
  • ken brydson
    ken brydson Posts: 9,019
    Romo11 wrote: »
    Rob
    Call SVS and tell them what you're looking for. They won't try to oversell you I guarantee. 45 day return policy with free shipping both ways if you don't like it.
  • kharp1
    kharp1 Posts: 3,453
    edited May 2019
    This is where we ask you about room dimensions. What are the approximate measurements and shape of the room? Closed or open? Any open areas like vaulted ceilings or stairways? Funky shapes such as alcoves?
    Sometimes they (SVS) offer a small discount if purchasing two subs. Also, check their outlet, you can save some there if you don't mind a minor blemish or two. All outlet items come with same warranty and trial/return policy.
    Call SVS and tell them what what you're thinking and they can offer some assistance. They are great to deal with.
  • Romo11
    Romo11 Posts: 101
    DaveHo wrote: »
    I just added the size to my corrected post above. I just realized I hadn’t posted the size in a good while after you asked. Thanks.
    Rob
  • kharp1
    kharp1 Posts: 3,453
    I would say with that size room, and some open area to steps, that two 4000's would do well. I realize that's more monies than 1 16-ultra, but, would give you better coverage, and, once dialed in, would be easier to have more even coverage across a wider area.
    I'd give SVS a call. We're all here to help you spend some money :)
  • mrloren
    edited May 2019
    WOW Dual SB4000 will rock.
    Some pictures of the layout would be helpful. What part of the country are you in? If you're in the San Diego area you're welcome to come over for a demo of my system.
    Just my two cents here. Being the HSU fan boy I am, I'd go with dual VTF3-MK5 and a Emotiva XPA-3 and call it done for close to the same money as the dual SB4000. The SB4000 is the better sub but I'm cheap. My single VTF3 makes dishes rattle 15' away. Then again if I did have the extra funding I'd have the SB4000.
  • Geoff4rfc
    Geoff4rfc Posts: 2,934
    edited May 2019
    This is a beautiful sealed sub...……
    https://www.powersoundaudio.com/products/S3010
    A dual opposed 15" driver sub. with lots of punch power.
    Set up: 11.2 HT + 2ch
  • rooftop59
    rooftop59 Posts: 8,120
    mrloren wrote: »
    This would be my strategy....call HSU and tell them that you are tempted by the svs but would like to give the HSUs a try. See if they offer you a deal or an in home trial.
    I personally cannot imagine needing more than two HSU VTF-3.5s, but that’s just me!
    Game Room 5.1.4:
    Bedroom 2.1
  • Romo11
    Romo11 Posts: 101
    mrloren wrote: »
    Thanks for the offer. You are too kind!
    Actually, I’m in North Carolina, about a mile from Charlotte Motor Speedway. You will know quite well where that is if you are a nascar racing fan. If not, about 30 miles northeast of Charlotte. If you ever get this way, just swing by. Maybe I’ll be setup by then.
    Rob
  • Romo11
    Romo11 Posts: 101
    kharp1 wrote: »
    Thanks for the response. I think I’ll take the advice and give them a call. It won’t cost me anything and I need all the knowledge that I can absorb.
    Rob
  • kharp1
    kharp1 Posts: 3,453
    I'd reach out to HSU and Rythmik as well, see what sense you get from each of them.
  • lightman1
    lightman1 Posts: 10,797
    Romo11 wrote: »
    mrloren wrote: »
    Rob
    Well sheet fire! I'm in Mooresville. VR3 is in South Concord. I sense an NC get together coming up soon....
  • lightman1
    ....as soon as I finish working in Indiana.
  • Romo11
    Romo11 Posts: 101
    lightman1 wrote: »
    Romo11 wrote: »
    mrloren wrote: »
    Rob
    That is unbelievable! I debated whether to put out my specific location but I’m sure glad I did.
    We may need to have a get together sometime!
    Rob
    lightman1 wrote: »
    Wow, I would love to see some pros setups!
  • mrloren
    Yes call the 3 dealers.
    When I called HSU for my VTF3 they tried to talk me out of it because my VTF2 is still a darn good sub. I did sell it to a friend and got my VTF3 anyway.
    HSU is a good dealer but the customer pays shipping. SVS pays for both ways shipping. The HSU subs even with sipping are hard to beat. PB2000 and the VTF3 cost about the same, my opinion is the VTF3 is better than the SB2000. Yes I've heard both.
    Emotiva has good customer service. I called to order my amp, they said straight up that ordering through them takes a week till I get it. The CS rep asked if I had prime (yes I do) she said Amazon has some ready built for Amazon. Two day's later I was rocking.
  • Geoff4rfc
    Romo11 wrote: »
    Good folks on here. Ken Brydson lives in my area and has come by for a listen. He was too kind...….not that he complemented my set up, but he brought over some tasty cold ones :D
  • kharp1
    kharp1 Posts: 3,453
    @Romo11 you will find we are very much like a family here, sure, we'll be opinionated at times, get in little squabbles, but, at the end of the day you'll find a bunch of great people that are ready to step up and help. I've heard great stories of amazing things done by one polkie for another. Often for no recognition and no compensation...just because they're great people.
  • joecoulson
    joecoulson Posts: 4,943
  • ken brydson
    Geoff4rfc wrote: »
    Romo11 wrote: »
    Fun times. We need to get together again soon!
  • Geoff4rfc
    Yes sir indeed! I'm free on the weekends. Every other actually. This one coming up is good :)
  • Romo11
    Romo11 Posts: 101
    Ok everyone, I have the speakers, Polk Audio( LSiM 707’s- 2, LSiM 6 center-1, LSiM 703’s-2 rears, and LSiM’s 702-2 surround rears, and on the way, 2 SVS SB 4000’s)
    Now, I’m trying to decide between the Outlaw 7700 ( been around for a good while, ( 200watts per 7 channels), or Outlaw 7220 ( 220 watts per 7 channels) new product. The write up says that the 7220 has a built in breaker of 20 amps and reccommends a 20 amp breaker in house. It appears it’s not required but, who knows? I don’t see what the amperage requirement for 7700 is but I don’t know and need advice. I like everything about the 7220 but it is new and some have said it has a low hum in certain owners homes. It appears that the 7700 is tried and true but I’m concerned. Will 20 watts make that much difference. I don’t want to screw up over $300.00. It’s not a lot in the whole realm of things.
    Rob
    Is there some reason why you are opposed to hooking them up to the Yamaha AVR first, before purchasing a 7 channel amplifier?
  • mrloren
    Outlaw's are nice amps either will do you good. I'd go for the 7700 and save the $300 for some good RCA cables and speaker wire.
    Two SB4000, dude you are getting serious bass there.
    Clipdat wrote: »
    I'd say get a good 3 channel amp. the AVR can handle the other 4 speakers
  • Romo11
    Romo11 Posts: 101
    edited May 2019
    Clipdat wrote: »
    I haven’t ordered the amp. I’m just trying to get an idea so I will know if I’m not happy.
    Hoping to get everything up and running with the speakers, Yamaha and subs when it all gets here. No, I listened to everyone who said to hook up first to AVR. I’m just getting excited and know, if needed, what I want.
    Thanks for your and everyone’s advice and concern. I feel like a kid at Christmas and trying to get my list right. I can’t wait to get everything together!
    Rob
    Sorry Clipdat, I meant to quote you also.
