Will my system work?
I still suggest just purchasing a quality subwoofer for now, and try running the speakers off the AVR first. If it's lacking in some major way, then get a 3 channel amp for the front speakers.
Your AVR is your pre-amp.
If you're dead set on SVS the SB4000 is more than enough.
President of Club Polk -
I agree with this. You will probably hear a considerable improvement by adding a high quality sub. Look at Rythmik, SVS and HSU as they are all good quality subs at reasonable prices. Do this first and then tell us what it sounds like to you.
If you still want an amp at that point, well, there are a bunch of them available on the pre owned market. You'll have your pick.
You eat an elephant one bite at a time. -
Either the SVS SB4000 or SB16u will work. these are not small subs. I helped setup a 16U once, almost didn't pass the wife acceptance factor. The bass that came out was fantastic.
The Outlaw amps are nice amps. I'd stay away from the Monolith stuff, get Emotiva way before Monolith.
Get the sub before and amp or just go for broke and get em both. With a sub in the mix set the Cross Over on the AVR to 80HZ and let the sub do the low end. This will save a lot of power on the AVR.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Either one of those Outlaw amps will allow your speakers to operate to their full potential, as will either of those subs it just depends on how much money you want to spend.
Your Yamaha will serve as your pre-amp.
You will have one slamming system that you can enjoy for years when you are done.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Ok, it looks like I’ll go with the sub first with the majority opinion going this way. Since this is my last system, I’m sure, do I get either the SVS SB4000 or the SVS SB 16 Ultra? Or do I go for two SVS SB 4000’s? It’s cheaper to get one of the SVS SB 16 Ultras but depending on your advice I will make my selection.
You guys sure are a great help. Thanks!
I forgot to mention that my room is 20X 24 going into the foyer and front door and steps up and down on one side. My house is a tri level and the only room (home theater) is on the second level. The foyer is small, only 6 X 5 on one 20 feet wall.
RobPost edited by Romo11 on -
How open is your room to other areas of the house?
Rob
Call SVS and tell them what you're looking for. They won't try to oversell you I guarantee. 45 day return policy with free shipping both ways if you don't like it. -
This is where we ask you about room dimensions. What are the approximate measurements and shape of the room? Closed or open? Any open areas like vaulted ceilings or stairways? Funky shapes such as alcoves?
Sometimes they (SVS) offer a small discount if purchasing two subs. Also, check their outlet, you can save some there if you don't mind a minor blemish or two. All outlet items come with same warranty and trial/return policy.
Call SVS and tell them what what you're thinking and they can offer some assistance. They are great to deal with. -
I just added the size to my corrected post above. I just realized I hadn’t posted the size in a good while after you asked. Thanks.
Rob
I would say with that size room, and some open area to steps, that two 4000's would do well. I realize that's more monies than 1 16-ultra, but, would give you better coverage, and, once dialed in, would be easier to have more even coverage across a wider area.
I'd give SVS a call. We're all here to help you spend some money
WOW Dual SB4000 will rock.
Some pictures of the layout would be helpful. What part of the country are you in? If you're in the San Diego area you're welcome to come over for a demo of my system.
Just my two cents here. Being the HSU fan boy I am, I'd go with dual VTF3-MK5 and a Emotiva XPA-3 and call it done for close to the same money as the dual SB4000. The SB4000 is the better sub but I'm cheap. My single VTF3 makes dishes rattle 15' away. Then again if I did have the extra funding I'd have the SB4000.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
This is a beautiful sealed sub...……
https://www.powersoundaudio.com/products/S3010
A dual opposed 15" driver sub. with lots of punch power.Set up: 11.2 HT + 2ch
Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
This would be my strategy....call HSU and tell them that you are tempted by the svs but would like to give the HSUs a try. See if they offer you a deal or an in home trial.
I personally cannot imagine needing more than two HSU VTF-3.5s, but that’s just me!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks for the offer. You are too kind!
Actually, I’m in North Carolina, about a mile from Charlotte Motor Speedway. You will know quite well where that is if you are a nascar racing fan. If not, about 30 miles northeast of Charlotte. If you ever get this way, just swing by. Maybe I’ll be setup by then.
Rob
Thanks for the response. I think I’ll take the advice and give them a call. It won’t cost me anything and I need all the knowledge that I can absorb.
Rob
I'd reach out to HSU and Rythmik as well, see what sense you get from each of them.
Rob
Well sheet fire! I'm in Mooresville. VR3 is in South Concord. I sense an NC get together coming up soon.... -
....as soon as I finish working in Indiana.
Rob
That is unbelievable! I debated whether to put out my specific location but I’m sure glad I did.
We may need to have a get together sometime!
Rob....as soon as I finish working in Indiana.
Wow, I would love to see some pros setups!
Yes call the 3 dealers.
When I called HSU for my VTF3 they tried to talk me out of it because my VTF2 is still a darn good sub. I did sell it to a friend and got my VTF3 anyway.
HSU is a good dealer but the customer pays shipping. SVS pays for both ways shipping. The HSU subs even with sipping are hard to beat. PB2000 and the VTF3 cost about the same, my opinion is the VTF3 is better than the SB2000. Yes I've heard both.
Emotiva has good customer service. I called to order my amp, they said straight up that ordering through them takes a week till I get it. The CS rep asked if I had prime (yes I do) she said Amazon has some ready built for Amazon. Two day's later I was rocking.
Good folks on here. Ken Brydson lives in my area and has come by for a listen. He was too kind...….not that he complemented my set up, but he brought over some tasty cold ones
@Romo11 you will find we are very much like a family here, sure, we'll be opinionated at times, get in little squabbles, but, at the end of the day you'll find a bunch of great people that are ready to step up and help. I've heard great stories of amazing things done by one polkie for another. Often for no recognition and no compensation...just because they're great people.
@treitz3 also lives in CLT
Fun times. We need to get together again soon! -
ken brydson wrote: »Fun times. We need to get together again soon!
Yes sir indeed! I'm free on the weekends. Every other actually. This one coming up is good
Ok everyone, I have the speakers, Polk Audio( LSiM 707’s- 2, LSiM 6 center-1, LSiM 703’s-2 rears, and LSiM’s 702-2 surround rears, and on the way, 2 SVS SB 4000’s)
Now, I’m trying to decide between the Outlaw 7700 ( been around for a good while, ( 200watts per 7 channels), or Outlaw 7220 ( 220 watts per 7 channels) new product. The write up says that the 7220 has a built in breaker of 20 amps and reccommends a 20 amp breaker in house. It appears it’s not required but, who knows? I don’t see what the amperage requirement for 7700 is but I don’t know and need advice. I like everything about the 7220 but it is new and some have said it has a low hum in certain owners homes. It appears that the 7700 is tried and true but I’m concerned. Will 20 watts make that much difference. I don’t want to screw up over $300.00. It’s not a lot in the whole realm of things.
Rob -
Is there some reason why you are opposed to hooking them up to the Yamaha AVR first, before purchasing a 7 channel amplifier?
Outlaw's are nice amps either will do you good. I'd go for the 7700 and save the $300 for some good RCA cables and speaker wire.
Two SB4000, dude you are getting serious bass there.Is there some reason why you are opposed to hooking them up to the Yamaha AVR first, before purchasing a 7 channel amplifier?
I'd say get a good 3 channel amp. the AVR can handle the other 4 speakersWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
I haven’t ordered the amp. I’m just trying to get an idea so I will know if I’m not happy.
Hoping to get everything up and running with the speakers, Yamaha and subs when it all gets here. No, I listened to everyone who said to hook up first to AVR. I’m just getting excited and know, if needed, what I want.
Thanks for your and everyone’s advice and concern. I feel like a kid at Christmas and trying to get my list right. I can’t wait to get everything together!
Rob
Sorry Clipdat, I meant to quote you also.
