Focal JM Lab Mezzo Utopia modification
I used the t14 on my super towers and was very pleased. I would check out the t14 versus the 14 awg hook up wire, not a big price difference.
OK I'll keep it in mind but I do not need the jacket and it's the same internal wire. Does the jacket bring anything to the party?
https://silversonic.com/products/hookup-wire/ofh-14/ -
Imo, yes, the wire is twisted which has advantages and the filler reduces vibrations.
I much prefer to keep internal wiring in the jacket versus separated. In fact...when I do internal. Wiring, I try to keep as much as I can in the jacket to maintain the Helix twist of. The 4 conductor.
I also change the wiring of sda speakers to reduce the amount of wiring needed.... There's some redundancy when you use the original wiring harness. Ie, you can actually reduce the 1.2tl tweeter wiring to 5 wires verus 8. Just like the 2.3tl.can be done with 4 wires versus 6... Etc this also allows a complete Helix.
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
From focal
Yes, this was factored in, in the case of the Mezzo.
In this particular case, the energy transmitted from one to the other is a non-issue, so sealing it would not make any substantial difference.
In some other models, the channel is about the same size as the wires passing though it and sealed, but the Mezzo doesn't need it.
Cheers !
So I will likely seal mine
@jdjohn yours are the very first run of utopia, you may have the version mentioned with smaller channels- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Has to help
Just sent this off to the fabricators for a quote... hmmm NL4 baby!
EMailed WBT about sourcing the missing pieces of the binding post, they are sending them to me for free, holy moly! Customer service on 20 year old parts, love it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Came out nice!
Now those are some coils
The no rez arrived and the internal wiring for the highs and mids are here. Planning to use the q 10 for the lows.
Ah yes!
Trey time for you to host. I wanna come hear them when you’re done.
I may be down for a small gathering, but it would probably be end of the year or beginning of next...
Count me in if you are so inclined.
Of course, never met an audiophile I didn't like!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You must admit, not all people in this hobby are audiophiles. Someone who does this because they enjoy the reproduction of music. I think you know what I mean.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I probably fit that category
Bass network
Portion of midrange circuit that will go in midrange cabinet
Tweeter circuit, built so that there is only one wire run, shortest signal path possible
joecoulson wrote: »Count me in if you are so inclined.
Me too!2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: Magnepan LRS w/Magna Riser stands -
You don't... have... to do it...
But... We don't really have.... to do anything!! hehehehehe
Are you doing the inductors too?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Already changed up the tweeter network layout... didn't quite like how that was going. Ordered some stainless threaded rod and will stack everything directly behind the tweeter with the inductor right at 8" away. That telar magnet is super strong. My desk is 1.25" wood and the magnet can hold a screw on the other side of where it is at!
Cant wait until the 25uf caps arrive! so I can put these babies back together!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I see now. Since you're going NL4, you needed those new plates. Email me about the inductors please."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Much better, add some heat shrink here and there... Clean up everything else with some isopropyl... Rock N roll
Dude. That’s bad ****
Thank you!
I like that there is only one wire run- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No doubt. I’m going to work on getting a set of xtra xovers for the Elacs so we can get started.
yes sir, will be a fun one- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
