A McIntosh in Verb's House!
  • lightman1
    lightman1 Posts: 10,801
    Set screw terminals on the back of this small welding machine.... Dan and I had the pleasure of hearing what it can do yesterday. Raw friggin power.
  • verb
    verb Posts: 10,176
    ^^^^^ Sweet! :smile:
  • GlennDog
    GlennDog Posts: 3,158
    lightman1 wrote: »
    That's a BEAST of an amp!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • honestaquarian
    honestaquarian Posts: 3,275
    lightman1 wrote: »
    @lightman1 What speakers?
  • tratliff
    tratliff Posts: 1,891
    lightman1 wrote: »
    I always wanted to give one of those a try but when I picked up a pair of these my search was over. Also, check out the binding post on the new versions of the McIntosh amps.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
  • lightman1
    DSkip wrote: »
    GlennDog wrote: »
    lightman1 wrote: »
    140 lbs. I wasn’t blown away by it but it has good sound and can power a city. The guy who bought mine is using it to power a subwoofer. It would be a great solution for a HT enthusiast who wants good 2ch sound as well.
    Shut up Skip
  • lightman1
    tratliff wrote: »
    lightman1 wrote: »
    I like your style....
  • lightman1
    lightman1 wrote: »
    Bigazz JBL..
    @EndersShadow might know.
  • motorstereo
    motorstereo Posts: 2,422
    tratliff wrote: »
    lightman1 wrote: »
    Great looking 601's. I went from a pair of mc2500's to a pair of mc1201s which is more than likely my best upgrade ever. As nice as the old monsters were honestly there's no comparison imo to the much quieter newer Mac gear.
    EndersShadow Posts: 17,753
    edited March 2019
    lightman1 wrote: »
    lightman1 wrote: »
    Bigazz JBL..
    I do but only because I got curious after we left.
    JBL 250Tis....
    https://audio-database.com/JBL/speaker/250ti-e.html
    Coolest part was on the back...
    You could adjust everything in the crossover by using different jumpers.
    And here’s the crossover info
    The large-sized floor type speaker system developed as a flag ship model which supplies the technology of Ti series and represents the thought and the technology of a JBL loudspeaker
    It calculated to the wide band thoroughly to the location of coexistence of flat frequency characteristic and power response, the phase matching of each unit, the diffraction effect of an enclosure, and a backplane duct, and the form is determined as it.
    LE14H-1 which is 38cmSFG Woofer by the Aqua positive compound cone is adopted as low-pass.
    20cm cone type 118H developed for 250Ti is adopted as inside low-pass.
    104H of a 13cm special polypropylene cone unit is carried in the mid-high range.
    The special filler strip is raising the synthetic for polypropylene to the base sharply. And the same internal loss as polypropylene is maintained.
    The 044Ti tweeter which used the pure titanium diaphragm is carried in the high region.
    The original technology of spraying the fault style of high-voltage nitrogen gas has realized dome molding of 25-micron thickness, and the response which was excellent in the origami work of Japan combining the diamond edge pattern and reinforcement rib which obtained the Tips is gained.
    The strapping busbar scheme with little tone-quality failure is adopted as an Attenuator.
    The round baffle is used for an enclosure in consideration of the influence by the diffraction effect, and high-density particle board is used for the material. Moreover, surface finish is natural teak finish.
    Furthermore, in order to prevent disorder of the response by reflection with a grill frame, the flooring grill using an original floating structure is adopted.
    Scheme 3 ways, 3 loudspeaker bass-reflex scheme, and a floor type
    Using unit
    For low-pass: 36cm cone type (LE14H-1)
    For inside low-pass: 20cm cone type (108H)
    For mid-high ranges: 13cm cone type (104H)
    For high regions: Dome shape (044Ti)
    Frequency characteristic 30Hz - -27kHz six dB
    Allowable input (pink noise) 200W
    Impedance 8ohms
    Cross over frequency 400Hz, 1.4kHz, 5.2kHz
    Output sound pressure level 90dB/W/m
    Dimensions Width 572x height 1321x depth of 362mm
    Weight 68kg
  • GlennDog
    Pretty freak’n cool
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    GlennDog wrote: »
    Pretty freak’n cool
    Yup, they sure were... we got the STORE to flex lol........
  • honestaquarian
    Oh my god I remember those! They also did an entire lineup of speakers including updated versions of the iconic L-100’s. These were the only JBL’s I actually liked as I was never a fan of the very forward JBL sound. This series kind of toed the line between the classic JBL sound and something more refined and “ audiophile”. The L-100’s threw a nice soundstage and were capable of disappearing with the right electronics.
  • verb
    verb Posts: 10,176
    Man this thing is awesome! Makes my MC300 seem, well, a bit small! But, it is bridgeable! Hmm. Dang! You guys got me thinking again! :smile:
  • verb
    verb Posts: 10,176
    From the MC300 manual:
  • honestaquarian
    Upgradeitis*sic*- A side effect of the dread disease called Audiophilia Nervosa, which is a disease of the wallet. It afflicts mostly the male species (but is not exclusive) and there is no known cure. Some have been known to cure themselves, however their methodology remains suspect and it has been suggested they used a well known method of addictions called “ Transferrence”.
  • verb
    verb Posts: 10,176
    Yep. Unobtainium is another one. Try to find another NOS MC300, to match the one I got! But, I dare say, the search is on! :smile:
  • honestaquarian
    A LOT of audiophiles (snobs) have issues with bridged amps. Besides you would probably have more luck (and more fun) if you found a reputable dealer after another trip to Vegas and trade this one in for a newer model(s)
    OR you could simply be happy with the powerhouse that luck brought your way and spend that money on upgrades to the SRS’s instead 👍🏾😉
  • verb
    verb Posts: 10,176
    Yep! All sorts of possibilities for sure! :smile:
  • verb
    verb Posts: 10,176
  • motorstereo
    ^^^^^That's an excellent price on a pair of fantastic sounding end game amps and it can be done to. I bought my 1201's last year after I'd been out of work for 3 months. Zero regrets and I'm still amazed daily at the sound they put out through my 1.2tl's. Just do it Verb!
  • verb
    verb Posts: 10,176
    Have to agree that is a great deal! :smile:
  • verb
    verb Posts: 10,176
    Head’s spinning! :smile:
  • honestaquarian
    WOW😲 JUST LOOK 👀 AT THOSE BINDING POSTS
  • honestaquarian
    There is a make offer option on there as well ;)
  • verb
    verb Posts: 10,176
    Yes Sir! :smile:
  • tratliff
    edited March 2019
    That is a great deal on the 1201’s. But I really doubt you need that much power. If McIntosh is your choice take a look at a 452 or a pair of 601’s and use the extra cash for something else.
    When I first got my 601’s I also had a SLP-05. It was a nice combo. Just food for thought since you just picked up the Cary. Let me know if you would like to discuss how they worked together.
    pitdogg2 Posts: 27,857
    verb wrote: »
    Yes Sir! :smile:
    Awesome see you there.
  • verb
    verb Posts: 10,176
    tratliff wrote: »
    Nice! Good to see another Polkie that has already traveled along the same road! :smile:
  • verb
    verb Posts: 10,176
    verb wrote: »
    Yes Sir! :smile:
    You too my brother! :smile:
