Focal JM Lab Mezzo Utopia modification
2456789
    pitdogg2 Posts: 27,327
    VR3 wrote: »
    I used the t14 on my super towers and was very pleased. I would check out the t14 versus the 14 awg hook up wire, not a big price difference.
    OK I'll keep it in mind but I do not need the jacket and it's the same internal wire. Does the jacket bring anything to the party?
    https://silversonic.com/products/hookup-wire/ofh-14/
    VR3 Posts: 29,550
    edited March 2019
    Imo, yes, the wire is twisted which has advantages and the filler reduces vibrations.
    I much prefer to keep internal wiring in the jacket versus separated. In fact...when I do internal. Wiring, I try to keep as much as I can in the jacket to maintain the Helix twist of. The 4 conductor.
    I also change the wiring of sda speakers to reduce the amount of wiring needed.... There's some redundancy when you use the original wiring harness. Ie, you can actually reduce the 1.2tl tweeter wiring to 5 wires verus 8. Just like the 2.3tl.can be done with 4 wires versus 6... Etc this also allows a complete Helix.
    VR3 Posts: 29,550
    From focal
    Yes, this was factored in, in the case of the Mezzo.
    In this particular case, the energy transmitted from one to the other is a non-issue, so sealing it would not make any substantial difference.
    In some other models, the channel is about the same size as the wires passing though it and sealed, but the Mezzo doesn't need it.
    Cheers !
    So I will likely seal mine
    @jdjohn yours are the very first run of utopia, you may have the version mentioned with smaller channels
    VR3 Posts: 29,550
    Just sent this off to the fabricators for a quote... hmmm NL4 baby!8cjqjkeqteae.jpg
    VR3 Posts: 29,550
    EMailed WBT about sourcing the missing pieces of the binding post, they are sending them to me for free, holy moly! Customer service on 20 year old parts, love it!
    VR3 Posts: 29,550
    Came out nice!
    VR3 Posts: 29,550
    Now those are some coils
    VR3 Posts: 29,550
    The no rez arrived and the internal wiring for the highs and mids are here. Planning to use the q 10 for the lows.
    Tony M Posts: 11,728
    :o
    VR3 Posts: 29,550
    Ah yes!
  • joecoulson
    joecoulson Posts: 4,943
    Trey time for you to host. I wanna come hear them when you’re done.
    VR3 Posts: 29,550
    I may be down for a small gathering, but it would probably be end of the year or beginning of next... :)
  • joecoulson
    Count me in if you are so inclined.
    VR3 Posts: 29,550
    Of course, never met an audiophile I didn't like!
    VR3 Posts: 29,550
    You must admit, not all people in this hobby are audiophiles. Someone who does this because they enjoy the reproduction of music. I think you know what I mean.
  • joecoulson
    edited April 2019
    I probably fit that category
    VR3 Posts: 29,550
    Bass network
    VR3 Posts: 29,550
    Portion of midrange circuit that will go in midrange cabinet
    VR3 Posts: 29,550
    Tweeter circuit, built so that there is only one wire run, shortest signal path possible
  • HzTweaker
    HzTweaker Posts: 1,041
    joecoulson wrote: »
    Me too!
  • jdjohn
    jdjohn Posts: 3,384
    VR3 wrote: »
    Came out nice!
    Uhhh, am I gonna need these as well?
    VR3 Posts: 29,550
    edited April 2019
    You don't... have... to do it...
    But... We don't really have.... to do anything!! hehehehehe
    Are you doing the inductors too?
    VR3 Posts: 29,550
    Already changed up the tweeter network layout... didn't quite like how that was going. Ordered some stainless threaded rod and will stack everything directly behind the tweeter with the inductor right at 8" away. That telar magnet is super strong. My desk is 1.25" wood and the magnet can hold a screw on the other side of where it is at!
    Cant wait until the 25uf caps arrive! so I can put these babies back together!
  • jdjohn
    jdjohn Posts: 3,384
    I see now. Since you're going NL4, you needed those new plates. Email me about the inductors please.
    VR3 Posts: 29,550
    Much better, add some heat shrink here and there... Clean up everything else with some isopropyl... Rock N roll
  • joecoulson
    Dude. That’s bad ****
    VR3 Posts: 29,550
    Thank you!
    I like that there is only one wire run
  • joecoulson
    No doubt. I’m going to work on getting a set of xtra xovers for the Elacs so we can get started.
    VR3 Posts: 29,550
    yes sir, will be a fun one
