hdmi cables.....
French_guy
Hello
Can I expect better picture quality with hdmi cables in the $20/$30 range compared to the "basic" stuff that are under $10 like Amazon Basics and the like?
Or it won't make any difference until i pay > $60 for some AudioQuest Cinamon for example?
Looking for some decent hdmi cable (6ft) that brings a plus without breaking the bank...
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
No surround...yet
You will probably see/hear an improvement with these:
https://www.thecableco.com/pearl-hdmi-2-0-cable.html -
French_guy wrote: »Hello
ThanksFrench_guy wrote: »Hello
Go with the audioquest and don't look back.
Cables are like shoes in my opinion, not a whole lot of difference in the same price ranges, but when you jump up a decent amount, quality shows it's worth.HT SYSTEM-
lsi 9's -
Hi,
I would go with AudioQuest. You will see the difference. I used basic HDMI, but the AudioQuest make really a different.
Greetz
Burt -
+20 on the Audioquest
Wirelogic at Costco are good and made by Audioquest https://www.costco.com/WireLogic-12-Feet-Sapphire-HDMI-Cable-2-pack.product.100376910.html
I either have AQ or the wirelogic in my house.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Interesting ......right now, I have these Costco cables between receiver and tv
Which AQ should I really look for: Pearl, Forest or Cinnamon?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
When I wall-mounted my plasma I needed longer cables, I went with the pearl then cinnamon going from Belden Series FE bonded from BJC.
The belden stuff works fine, but I did notice a slightly cleaner pic going to the Cinnamon when watching Blu Ray.
We have the Pearl on a 2nd plasma and it's a good cable for the price for sure.
I got lucky and found two 2M pair of Carbon for $90 each and jumped all over that CL deal, 1080P material is sharp and the audio is clean...those will be staying for awhile..
@French_guy , what components are connecting? I do agree that you will get an improvement going up the chain. I believe Best Buy has a trade up program within a certain time limit.
You can also try the lending library from The Cable Company.
LG 75" 4k TV to receiver (probably Denon 3400h - need to buy one) to Xbox one S for now but maybe a better 4k player in the futureRTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
The Cable company still has Shunyata Venom HDMI cables on sale. These are extremely close, preformance wise, to AQ Cinnamon HDMI cables.
Are WireLoic Sapphire really made by AQ? Would they be close to the Pearl version then?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
https://www.youtube.com/watch?v=x09bUTmMmIs
@ 13:28 in the video is a wall of AQ products.
I'd say they are close to pearlWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Cool, thanks for sharingRTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
When I first bought my large flat screen TV, I used basic HDMI free cables from the local cable TV provider. I had green, blue, and purple horizontal lines moving up the screen. I then bought Audioquest cables and all was well. You get what you pay for.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
Teac R-919X ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
French_guy wrote: »+20 on the Audioquest
Hard to believe they are made by AQ at that price.Main System 2.2:
Watch the video at 13 min 30 sec.............WireLogic is visible and he mentions itRTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
PM me for some audioquest HDMI cables, I have a few laying around I'm not using and all are 4k HDR Dolby Vision CapableFrench_guy wrote: »Interesting ......right now, I have these Costco cables between receiver and tv
Which AQ should I really look for: Pearl, Forest or Cinnamon?Dan
PM sent......RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
I'll get back to you tonight
Dan
@mrloren there's a "Ruby" version of those Wirlogics out there. What's more valuable rubies or saphires?
I believe rubies for bright speakers and sapphires to enhance bass. Using both means crappy speakers in general.
afterburnt wrote: »@mrloren there's a "Ruby" version of those Wirlogics out there. What's more valuable rubies or saphires?
No idea what so ever. I only have the saphires for use in the kids rooms. My main HT and Bedroom HT are real AQ brand.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
I just ordered a pair of the Rubies. Curious if they make any difference. Using SecurOmax right now which seem fine for video, at least. -
Amazon Basic cables are just as good as the expensive ones. There is no difference. There is no cable that will give you better picture, that’s absurd if you think about it. Google hdmi cables and you will see their has been numerous comparisons and concluded, no difference.
^ WAAAAAAAAAAAAAAAA ^
I went to a website that sells HDMI cables that cost more than Amazon basic cables, but I don’t use Google as a search engine.
I saw and heard an improvement using the more expensive cables, in comparison to the less expensive Best Buy cables that I had.
Maybe using Google to find good cables is the problem, and there really is a difference in the actual cables. -
What you just said is absurd...if you really think about it. If you don't want to pay for more expensive cables that fine, don't try to lay out some technical argument that studies say there's no difference. Some know better from real life experiences. -
Amazing first post.
and last post probably.
________________________________
mrloren, the video was very cool."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
i would think there would be solid proof of superior results by using a very expensive cable rather than the cheap. test results?? of actual signal loss of vid/audio quality ,.etc. i can understand that the most expensive names of cables have or should have much tighter and sturdier pins in the plugs , for a nice solid tight connection between devices using thicker better shielding. but is there any such proof of superior results, concrete evidence. ??? or is the differences only subjective ?
Audioquest Choclates in the HT rig here. I'm sure the Cinamon would do a good job also.Home Theater
