Cambridge CXN (V2) next acquisition
On the 851N you can cycle the screen to show album cover, song information, or both together.afterburnt wrote: »It's playing with itself right now.
Let's hope the CXN is the only one doing that right now.
I would play some pocket pool but I'm not wearing any pants -
Same on CXN -
@joecoulson which XLR's are you using?
Audioquest Red River. From CXN to PS A stellar
I have the same kind in 3m going from output on PS A to my SVS
It has about a 6db Gain over RCA in this particular setup FYI. -
Also note that with the remote/app, you only have 8 channels for presets, but if you use the admin page to connect, you have 20
joecoulson wrote: »Audioquest Red River. From CXN to PS A stellar
Those are spensive! I am thinking about trying some economical ones with my secondary system so I don't want to spend too much. Probably get some BJC's to replace the BJC RCA's. -
What a piece of kit! This streamer is working surprisingly well with my sortta HT system. Soundstage wide as hell and imaging are crazy and getting better as it plays. Havent run into a tune that it hasn't handled so far. I know I have some dog recordings in there but haven't got to em yet. On a scale of yes to no this is big "buy"! I already want it's big brother. I say "good move" picking thes guy up Skipper!
I haven't managed to unbox mine yet even though it arrived on Tuesday. Hopefully tomorrow.
You guys are making me wanna to pull the trigger on this unit. Can’t wait to hear a review once you got some time on them.Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
Can the CNX V2 pull music from iTunes on a PC ? I've heard tell the V1 could not, did they fix that issue in version 2 ?
Dayglo, I have no idea however it explicity states that the USB port is not for Apple stuff which I find to be very noble.
It may support apple files, from a stick, Nas, but can it pull it wirelessly from a PC ? That's the crux of the matter and a deal killer for some.
No affiliation with Cambridge. This is a sweet piece of kit. I want to rearrange stuff to get my Cambridge spinner on the same system. It is still doing everything with aplomb. Whatever the hell that is.
Not to scab on the thread but what is the difference between the 851N and the CXN?Gustard X26 Pro DAC
$600.00
Or did you want to know about the "Beefy Guts"?
@Clipdat were you the one that had the "Beefy Guts" pics?
Listen up newb. Let me give it to ya straight. If it can airplay, it can pull files from a pc running iTunes airplaying the files to the Cambridge. Capisce? Furthermore, no real audiophile would store their music files in Apple format. FLAC files for the win!!!
Now pardon me while I hide in the bomb shelter...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
afterburnt wrote: »$600.00
Ju talking to me??? Which way?afterburnt wrote: »Or did you want to know about the "Beefy Guts"?
Sure "guts"Gustard X26 Pro DAC
@DSkip had a 851N set up along side my CXN when I went to pick it up from him. He's had a little more time with both units than I had so he could possibly elaborate.Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
Discogs -
displayname wrote: »Not to scab on the thread but what is the difference between the 851N and the CXN?
And aside from better Dacs .. It's built like a little tank. .mine isn't going anywhere soon. I don't move fast with anything😂😂"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
@audioluvr I am really happy with this piece, I think I may end up running it in my main system. That won't happen for a while but I would love to compare it to my Aries Mini head up.
Thanks all!Gustard X26 Pro DAC
afterburnt wrote: »@audioluvr I am really happy with this piece, I think I may end up running it in my main system. That won't happen for a while but I would love to compare it to my Aries Mini head up.
Variables up the wazoo in that heads up comparison, unless you just swap out the 2 for that heads up ear test. Guess that's the only way you could test that out. Curious what you think once ya do it.Post edited by tophatjohnny on"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I thought the 851N is a preamp with a built in dac and streamer?Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
So not needing a new preamp the CXN V2 is the way to go correct?Home Theater
Yes it will do the trick."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Not sure if it matters, but the 851N doesn't support Chromecast. It's an older design vs. the CXN V2 which is newer.
I think the most important consideration though is whether you plan on using the internal DAC or not.
Guts:
851N:
CXN V2:
Discogs
